Old 09-01-2011, 02:56 PM   #1
Sonny@TireRack.com
GolfMK6 Official Vendor
Sonny@TireRack.com's Avatar
Drives: My kids crazy
Winter Tire Thread
Hello all!
As another winter approaches, it is a good time to go over the facts about winter tires.
How do winter tires work?
Here are a few pictures to illustrate the mechanics involved in winter traction.
If you look closely at a road surface you can tell that it is really not as smooth as represented by the model in this picture
With the high grip rubber compound used in your summer performance tires the contact area conforms to the irregular surface of the road.
That amount of contact can generate a tremendous amount of traction in the summer time but, what if the road in snow covered?
That brings us to the question, what makes a tire a good winter tire? The answer is a three part puzzle and without all three parts traction will be compromised.
Let's look at the first part of the puzzle; tread design
This picture shows a winter tire tread design which, as you can clearly see, utilizes a large number of sipes
When the road gets snow covered the tire is no longer able to conform to the surface.
The siping allows the tread elements to flex under stress create aggressive "biting edges" when braking, cornering or accelerating
Part two of our three piece traction puzzle is tread depth
While deep snow and ice-covered roads are two of the most challenging conditions North American drivers will face, tire developments during the last decade have noticeably advanced wintertime mobility. The technological revolution of dedicated winter tires for drivers in the snowbelt, and the continuing evolution of all-season tires for drivers living on its periphery characteristically offer more grip in snow and on ice than ever before.
However the basics of delivering traction and handling in snow and on ice remain unchanged. Tires must combine three fundamental features to deliver good wintertime performance, including an appropriate tread design, pliable tread compound and sufficient tread depth. If any one of these fundamental features is absent, the other two, regardless of their ability, cannot deliver the desired results! Since engineers can develop cutting-edge tread designs and chemists can develop advanced rubber compounds, it is often the remaining tread depth that is the variable in determining wintertime performance.
In most parts of the world, tires are considered to be legally worn out when they reach 2/32" (approximately 1.6mm) of remaining tread depth. U.S. law requires tires to have easy-to-see Tread Wear Indicator bars running from one side of their tread design to the other when the tire's tread has worn down to the minimum legal limit of 2/32 inch.
However in spite of the legal minimums, Tire Rack recommends that drivers expecting to experience wet conditions consider replacing their tires when they reach 4/32" of remaining tread depth. Tire Rack's tests have shown how shallow treads reduce wet braking traction and increase stopping distances
Tire Rack also recommends that drivers expecting to encounter snow-covered roads consider replacing their tires when they reach approximately 6/32" of remaining tread depth to maintain good mobility. Tires need more tread depth in wintry conditions to compress snow in their grooves and release it as they roll. If there isn't sufficient tread depth, the "bites" of snow that can be processed on each tire revolution will be reduced to "nibbles," and the vehicle's traction and mobility in snow will be reduced.
The third and final part of the puzzle is the rubber compound used. Rubber compounds vary widely from manufacturer to manufacturer but, the task is the same so, you will see similarities between the products. They all typically use compounds which utilize materials designed to remain flexible at cold temps in addition to traction enhancements from silica and other materials which add more bite on ice.
Now, for the next step ... types of winter tires
There are basically three different types of winter tires
#1.) Performance Winter
You want enhanced dry road handling from your winter tires and are willing to trade some snow and ice traction to get it.
Meeting severe snow service requirements and branded with the "Snowflake-on-the-Mountain" symbol, these low profile, H- or V-speed rated tires are designed to suit winter driving on European highways. They are available in many of the low profile sizes used as Original Equipment on sporty imported and domestic cars. Due to their unique designs these tires must be installed in sets of four.
#2.) Studless Ice and Snow
You want to maximize snow and ice traction from your winter tires without the inconvenience of using winter tire studs.
Meeting severe snow service requirements and branded with the "Snowflake-on-the-Mountain" symbol, these Q-speed rated tires feature the latest in tread compound technology to provide winter traction without the inconvenience of tire studs. They trade a little handling for excellent ice and snow traction. Due to their unique tread compounds these tires must be installed in sets of four.
#3.)Studdable Winter
You want the traditional security of studded winter tires for enhanced traction on ice.
Meeting severe snow service requirements and branded with the "Snowflake-on-the-Mountain" symbol, these non-, Q-, S-, or T-speed rated tires feature traditional snow tire tread compounds and studdable tread designs for good snow and ice traction. Due to their unique designs these tires must be used in sets of four. Use of studded tires is often prohibited or restricted. Check with local authorities to confirm legality.
But Do I Really Need Winter Tires?
The primary concern that our customers express is that they don't want to get "stuck" in the snow (or in the ditch) during the winter.
While in cities like Atlantic City, Memphis and Seattle located at the extreme edges of the snow belt, relatively new All-Season tires will probably work just fine. But the odds change as you move further into the snow belt or the All-Season tires have a few years of wear on them. And who wants to gamble...especially when their collision deductible and future insurance premiums are on the table.
We all know that tires are a compromise. One tire can't be the fastest on the track, most controllable in the snow, and longest wearing. The Ultra High Performance tire that grips the track with tread temperatures of 200 is incompetent as its tread compound becomes like "hard plastic" at below 32. Today's 80,000-mile tires require tread designs and compounds that maximize long, even wear... not winter traction. And while many of today's all-season tires (Original Equipment, touring and performance) address some of these issues, they still emphasize longer wear, a quieter ride or greater performance...not winter traction.
Only winter tires are designed to excel in the colder temperatures, slush, snow and ice that many parts of the country experience for three or more months a year.
It's also important to note that the recent advancements in electronic driver aids, such as ABS and traction control don't provide more traction. They only help prevent drivers from over braking or overpowering the available traction of their tires. The only thing the driver can do to increase traction...to actually get more grip and control... is install better tires.
NEW*
Our latest testing videos for your enjoyment
Tire Rack - Why Gamble in Winter When Four of a Kind Beats Two Pair? - YouTube
Tire Rack - Front-Wheel Drive and All-Season Tires Enough for Winter Driving? - YouTube
As in the past, there are 'general use' recommended packages for each model car to be found at TIRERACK.com but, if you would like to discuss other options for your specific needs please don't hesitate to give me a call at 800-428-8355 ext. 4789 or drop me an e-mail
NEW
RALLY ARMOR MUDFLAPS AVAILABLE FOR MK6
Tire Rack recently added Rally Armor mud flaps to the long list of products that we already carry. Designed for, and inspired by the messy fun of rally racing, these mud flaps can also be useful for drivers looking to protect their cars from the slush and conditions of winter driving.
Rally Armor is based in New York with all of their facilities located within the United States. They offer a diverse selection of mud flaps, ranging from basic options to race-ready items. In addition to their universal part numbers that'll fit just about any vehicle with some drilling for proper fit, they offer direct-fit applications tailored for some of the most popular rally vehicles.
Vehicles with bolt-on mud flap applications include:
2012 current Hyundai Veloster (COMING SOON!)
1993 - current Subaru Impreza/WRX/STI/Outback Sport
1998 - current Subaru Forester
2005 current Subaru Legacy and Outback
2013 - current Subaru BRZ and Scion FR-S
2004 current Mazda3 and Mazdaspeed3
2007 - current Mitsubishi Lancer and Ralliart sedan (no Sportback)
2003 - current Mitsubishi Lancer Evolution
Search by vehicle to find the Rally Armor product that works best for your application.
You can also post in this thread but please supply the following information ....
year:
make:
model:
tires only or winter package:
and I will respond directly to your post
I will also be adding to this thread periodically so, check back often
Old 09-01-2011, 03:32 PM   #2
OneHotHatch
OneHotHatch's Avatar
Drives: 2010 CW DSG GTI
Send a message via AIM to OneHotHatch Send a message via Skype™ to OneHotHatch
what kind of deals are we talking on a studless winter tire package?
K04 CLUB MEMBER #69
2010 CW DSG|APR K04 V2|APR SI&II Intake|APR Front & Rear Sway-Bars|Clear Side Markers|20%-15% Tint|Yellow Fog Lights|APR Intercooler|APR TBE|LEDs: License Plate, All Interior|Retro-Fitted Bi-Xenons|Golf R L.E.D. Tails|Euro-Switch|JL12w3|
OneHotHatch is offline   Reply With Quote
Old 09-01-2011, 03:47 PM   #3
Sonny@TireRack.com
The least expensive studless option we would offer without sensors for a 2010 would be:
4- 16x6.5" steelies $56.00 each
4- 205/55R16 Pirelli 210 SottoZero (closeout limited quantities) $91.00 each
$588.00 plus applicable taxes and shipping
Old 09-07-2011, 07:43 AM   #4
MK6_EF9
MK6_EF9's Avatar
Drives: away...
How much for snow tires and steel wheels
year: 2011
make: VW
model:GTI
tires only or winter package: Winter package
MK6_EF9 is offline   Reply With Quote
Old 09-07-2011, 11:42 AM   #5
Sonny@TireRack.com
year: 2011
make: VW
model:GTI
Our preferred package for the 2011 would be 205/55R16 Dunlop Winter Sport 3D with 16x6.5 steelies. The total would be $720 plus shipping and any applicable taxes (quoted without tire pressure sensors which run $53.00 each if you need them)
Old 09-07-2011, 11:54 AM   #6
GunKata
MILFn00dzHunter.com
GunKata's Avatar
2011 doesn't need TPMS sensors..
Everybody knows GunKata > *.*
No GunKata, no care.
Chicago Car Network
I can haz 350z racecar?
Old 09-07-2011, 11:56 AM   #7
Sonny@TireRack.com
There was a mid-year split on the 2011. Some had rubber valve stems with ABS/indirect TPMS (no sensor necessary) and some had metal stems with direct TPMS (needs wheel sensors).
Old 09-07-2011, 11:56 AM   #8
GunKata
MILFn00dzHunter.com
GunKata's Avatar
when was this? I ask because I have one of the first 2011's to hit the shores (got it early August 2010) and I had no TPMS sensors.
Chicago Car Network
Old 09-07-2011, 12:18 PM   #9
Sonny@TireRack.com
We don't have an exact build date from VW (maybe I should not use the term "mid-year":-) ). Unfortunately running the VIN won't necessarily tell the tale either as we have had some come through incorrectly. The only way to be 100% certain is by checking the valve stems.
Old 09-07-2011, 12:28 PM   #10
GunKata
MILFn00dzHunter.com
GunKata's Avatar
hmm, yeah, we've always heard / been told it was a complete change from MY 2010 TO MY 2011. The other way to check is if you have the "reset TMPS" button in the glovebox as well, since the 2010's did not have that.
Chicago Car Network
Old 09-07-2011, 12:50 PM   #11
noname
noname's Avatar
Drives: 2012 GTI 6spd,CW
I have a 2012 GTI and i would like your opinion on the winter setup i am thinking about:
Wheels: ASA GT1 (Black w/Mach Lip)
Offset: 45mm
Backspacing: 6.29"
Bolt Pattern: 5-112
Rec. Tire Size: 225/45-17
I am thinking about putting on 215/50/17's to give me a skinnier profile in the snow, I don't want to go 16's.
Would that wheel and tire combo work, or do I have to go 225/45/17's?
noname is offline   Reply With Quote
Old 09-07-2011, 01:17 PM   #12
Sonny@TireRack.com
Offset: 45mm
Backspacing: 6.29"
Bolt Pattern: 5-112
I would go with the 225/45R17 as the rim width range for all of the winter tires we carry in that size end at 7.5". I would also throw a coat of paint sealant/wax on the whole wheel with some special attention to the machined lip to protect it from snow melt chemicals (the machined lips can sometimes be more susceptible to damage from salt etc...) even though it is pretty small.
Old 09-07-2011, 01:20 PM   #13
noname
noname's Avatar
Originally Posted by Sonny@TireRack.com View Post
I would go with the 225/45R17. I would also throw a coat of paint sealant/wax on the whole wheel with some special attention to the machined lip to protect it from snow melt chemicals (the machined lips can sometimes be more susceptible to damage from salt etc...) even though it is pretty small.
Just curious why you say i should go 225's? Is there a tire fitment issue on the 215?
Old 09-07-2011, 01:24 PM   #14
Sonny@TireRack.com
just edited my post.
