Old 10-17-2011, 10:04 PM   #1
(. )( .)'s Avatar
Drives: Slow
Replace Bixenon Bulbs
Hi All,
I was wondering if anybody has replaced, or know how to replace their bixenon bulbs. I'd like to have a whiter 6000k bulb, rather than the 4300k stock lighting.
Couldn't find the threads here or on the vortex, and the dealership doesn't want to touch my headlights. I'd like to diy, rather than take it to the shop, but if all fails, i may do that.
Anyone?
Thanks in advance!
Edit: This is with the D1S bulbs.
(. )( .) is offline   Reply With Quote
Old 10-17-2011, 10:59 PM   #2
boostedmk6
boostedmk6's Avatar
Not to jack your thread, but you understand that you'll be losing light output by doing this right?
GTI DSG | APR K04
GTA Detailing & Paint Correction
boostedmk6 is offline   Reply With Quote
Old 10-18-2011, 03:54 AM   #3
madbikes
Drives: 2012 Golf 2.5L 5-speed
You're not losing too much for going from 4300K to 6000K, but will still be much brighter than a set of silverstar.
Get Philips 6000K Ultinon bulbs if you choose that color temp. I have them in my current car (not a VW) for 5+ years and still going strong (yes I know HID in reflector is bad). It shines white light with purple hue, but the hue will not be as heavy after you use it for a period of time. I'm told it will appear different on projector, but I haven't seen it yet.
madbikes is offline   Reply With Quote
Old 10-18-2011, 02:55 PM   #4
bluetrep
Drives: 2012 Sunroof/Nav
i wonder if philips or other oem make 6000k bulb
bluetrep is offline   Reply With Quote
Old 10-19-2011, 11:27 AM   #5
mjhubbard
Drives: 2011 GTI DSG Autobahn
dint he just say that???? Philips 6000K Ultinon...
mjhubbard is offline   Reply With Quote
Old 10-19-2011, 12:07 PM   #6
xHeartcoreboyx
xHeartcoreboyx's Avatar
Drives: '10 CW 2DR GTI DSG
I have Morimoto 6000k bulbs...they look way more exotic than oem 4300k IMO
SOLD -> MK7 R
Old 10-19-2011, 12:15 PM   #7
DJEuphoria
DJEuphoria's Avatar
Drives: 2011 6-Spd Black GTI 2-Door
i think the stock xenon bulb size is D1S but i still don't know how to change the bulbs myself.
DJEuphoria is offline   Reply With Quote
Old 10-19-2011, 02:59 PM   #8
madbikes
No joke.
Old 06-02-2014, 11:11 PM   #9
MBorVW
MBorVW's Avatar
Drives: 2015 VW GTI 4dr SE DSG
Does anyone know how to change the stock bixenon bulb?!!! There is literally not one post online that I can find on how to do this
Please help if you've done this job before.
Also: 2012 Tiguan LE 2wd
MBorVW is offline   Reply With Quote
Old 06-02-2014, 11:57 PM   #10
LBCGTI
LBCGTI's Avatar
Drives: 2011 GTI Autobahn
I did mine and it was real Beeaoch. For the driver side i had to remove the wheel and inner fender shroud to get to it. the passenger side was easier and can be accessed without removing wheel or fender liner. It takes is 1/4 turn CCW to remove than pull the connector which fits really tight and 1/4 turn CW to install the bulb. I got the Osram cool blue intense Xenarc D1S bulbs rated @55k these start blue and than burn white once full hot.
2011 GTI Autobahn Candy White DSG: APR STAGE II, 42 Draft Design Turbo Back, Full Carbonio intake, SPM Intercooler,Wheels:VMR,VW101,TSW Jerez, RVC, 25mm NEUSPEED RSB, White line end links, R-tails, KW V3's,vagcom,UNibrace UB,GFB DV,SHAVED Front Bumper/Hood
LBCGTI is offline   Reply With Quote
Old 06-03-2014, 12:15 PM   #11
MBorVW
MBorVW's Avatar
Another forum member is getting ready to post a DIY on xenon bulb replacement. He said that he found a way, I think, without removing anything from the car. It is a huge pain in the arse for sure. The fuse box on the drivers side really makes it nearly impossible.
Old 06-04-2014, 04:09 PM   #12
ShdBluMkVI
Drives: no more GTI
The ultimate bi-xenon/HID lamp.
ShdBluMkVI is offline   Reply With Quote
Old 06-04-2014, 04:13 PM   #13
yunone
Drives: 2012 CSG GTI
http://www.amazon.com/OSRAM-Cool-Int.../dp/B003VNFEKO
ouch! pricey
yunone is offline   Reply With Quote
Old 06-04-2014, 06:02 PM   #14
Teddy Redskinz
Drives: 2012 UG GTI
Originally Posted by (. )( .) View Post
Hi All,
Anyone?
Thanks in advance!
Front bumper will have to be removed slightly to get proper access.
http://www.golfmk6.com/forums/showthread.php?t=16059
http://www.youtube.com/watch?v=S7-BV_Ny-30
IF someone with super small hands can get the proper clearance (without moving the bumper) then all you do is 1) pop off the plastic cap on the back of the assembly 2) disconnect the bulb from the ballast connector 3)twist and remove. Assembly is in reverse order.
Teddy Redskinz is offline   Reply With Quote
