Old 10-25-2011, 03:07 PM   #1
twenzel
Drives: CSG Golf R
My GTI is idling rough. Advice?
Hey folks, need some help. Last night, I was driving normally right after filling up with 93 oct Shell and when I stopped at a light the car stalled. It started right back up and was idling like you see it in the video I've linked. It seems the car drives normal most of the time but I started to get on it it acts up again. Also the exhaust smells like the car is running very rich while the rough idle is present. I've done the throttle body alignment and there are NO CODES present. I am also not blipping the throttle, it is doing that on its own.
Mods:
Carbonio Intake
EuroJet TBE
Any advice is appreciated.
http://www.youtube.com/watch?v=qsrxuJxLAQA
twenzel is offline   Reply With Quote
Old 10-25-2011, 03:12 PM   #2
HatchFanatic06
HatchFanatic06's Avatar
Drives: 2014 STI Hatchback
Are the rpms surging? or were you pressing the gas?
If your rpms are surging and having problems with stalling a potential issue could be your IAC valve is dirty (i had a similar problem on an older car awhile back). Someone posted a similar problem as you and it turned out that his APR stg 2 CAI was disconnected at the rear. Just an idea for you to check.
*correction* I don't believe our cars have an IAC (think that was an ODB1 feature.) To be honest if this is the case i'm not sure what took over its function maybe within the throttle body itself. Hopefully someone more knowledgeable chimes in here.
HatchFanatic06 is offline   Reply With Quote
Old 10-25-2011, 03:14 PM   #3
twenzel
Drives: CSG Golf R
If your rpms are surging and having problems with stalling a potential issue could be your IAC valve. Someone posted a similar problem as you and it turned out that his APR stg 2 CAI was disconnected at the rear. Just an idea for you to check.
The RPMs were surging, I wasnt touching the pedal. Thanks for the quick response. I'll check to make sure all connections on the intake are tight.
Old 10-25-2011, 03:24 PM   #4
kashak
kashak's Avatar
Drives: 2018 Audi RS3 | 2018 Sportwagen AWD
I had funny idles, turned out to be faulty intake manifold - got it replaced under warranty. Car smelled like catless too. It's a TSB and I suggest you visit your dealership to get it fixed.
2018 Audi RS3 Ara Blue
2011 GTI - Gone. Mods: GT28RS | APR tune | Garbagebend | Carbonio | Billy Boat | HPA | Labonte | Íhlins | OZ | H2Sport
kashak is offline   Reply With Quote
Old 10-25-2011, 03:27 PM   #5
HatchFanatic06
Do you have a scanner? do you know if your throwing a soft code? might be helpful in attempting to find the problem
Old 10-25-2011, 03:36 PM   #6
twenzel
Drives: CSG Golf R
I have a code scanner built into the P3 Vent gauge. Its not showing any codes..
I just tried starting again and it started but the rough idle is still happening. It sounds like there is also a super high pitch tone coming from the intake manifold as the rpms drop. Almost electronic sounding. It's a bit hard to explain.
Old 10-25-2011, 03:42 PM   #7
ehancock
Drives: 09 GTI
Can't watch your video right now, but i've been having rough idle on cold starts for a few weeks, now it turned into severe miss under load and i finally threw a code. One of my coilpacks is failing. Might want to check those out
ehancock is offline   Reply With Quote
Old 10-25-2011, 03:46 PM   #8
jmlivid
jmlivid's Avatar
Drives: 2011 2 door CSG GTI
Is the electric sound a beeping? like random sequence morse code? I only have an intake but when I start it up in the morning it does this soft beeping sound.
2011 2 Door CSG GTI, Sunroof, Nav, DSG. Modshack, Some cosmetic, Some VAG, no tune....yet.
jmlivid is offline   Reply With Quote
Old 10-25-2011, 03:47 PM   #9
fatty
fatty's Avatar
Drives: gti 2011
try taking another vid. this time close the doors so the annoying chime goes away and make sure the video shows your feet is no where near the gas pedal.
save it on your laptop and bring it to the dealership but they're probably gonna claim your p3 boost gauge is the problem
VCDS available to locals http://golfmk6.com/forums/showthread.php?t=18285
fatty is offline   Reply With Quote
Old 10-25-2011, 03:48 PM   #10
twenzel
Drives: CSG Golf R
kinda like that yes but I wouldnt stay its any pattern, It makes the tone when the RPMS drop then stops when the RPMs surge.
Old 10-25-2011, 03:49 PM   #11
twenzel
Drives: CSG Golf R
P3 Boost guage doesnt use a boost tap, it plugs into the OBDII port and reads boost from the ECU. I'll try capturing better video.
Old 10-25-2011, 04:16 PM   #12
DRedman45
DRedman45's Avatar
Drives: UG '10 4dr gti(sold)-E86 //M coupe
Send a message via AIM to DRedman45
sounds exactly like a vacuum leak...like kashak said the manifold is a possible culprit...there is a flapper in there and if the motor/sensors go bad it would idle with that surging, but go away at a higher rpms
I will miss my K04 gti
DRedman45 is offline   Reply With Quote
Old 10-25-2011, 05:02 PM   #13
twenzel
Drives: CSG Golf R
Here is a better video. http://www.youtube.com/watch?v=VHIkt3mrvnw
May be a few minutes before its available. I just uploaded.
Old 10-25-2011, 05:09 PM   #14
fatty
fatty's Avatar
Drives: gti 2011
I know but the dealership will still make the stupid warranty void claim. you'll see
2nd part of the video scared the shit out of me. I turned my volume up to hear your car idle while you were switching programs.
Show the video to a dealer before actually bringing it in
