finally finishing up quad retrofit...almost
dubbinit2
Here are a couple pics of my aiming process of my quad set up.
I bought 2 sets of OEM halogen headlights. And after about a month of work I'm about a week out from finishing.
The cut off on the new morimoto's is unmatched. Not even OEM matches up.
grambles423
Automotive Engineer
I love the morimoto Minis. They make retrofitting almost a plug and play setup.
dubbinit2
The most daunting part of a retro fit is def. The aiming/aligning process.
Over engineering is a must. Or the vibrations of daily driving will shake everything loose.
Matt and his crew from theretrofitsource.com have been great guys to buy from. Their customer service is second to none. Tonight I'll be aligning the h15 position. I'll post more pics tonight. I have halo's behind the shrouds. I'll also be adding some led blinkers. This should be a pretty neat set-up when I finish.
dragon69185
Very very nice :thumbsup:
Can't wait to see your finish product man :w00t:
xGaspy
Great work bro! Are you going to be offering a retrofit service for this set up?
dubbinit2
^^^^ FO SHO! i def. want to provide a product that surpasses OEM output and style.
but the most important thing is quality. that is why ill be testing the shit out of these.
stay tuned...
dubbinit2
ive seen some questions asked on PHD's post directed towards me.
components im using in my retrofit were based on fittment and reliability.
also light output is pretty much the same vs. other well known projectors. you can see in my photo showing the beam pattern it doesnt get any better then that. the flicker and cut off are really one of the best around period. Morimoto matchbox bi-xenon projectors were used in the h15 or highbeam position also your day-time running lights. they are the only projectors small enough to do so. you'll see more as i progress.
sweetsandman
That looks amazing!!! Good work!!!
TapaTapaTapaTalk
dubbinit2
^^The possibilities are endless... I'll definitely keep everybody posted.ill be doing something pretty cool with some amber led's. UL see!
kelvillain
Kudos to you man, i need someone like you around my area to get mine retrofitted. I need to see these after!
