#1 |
![]() Drives: MK6 GTI Join Date: Aug 2011
Foggy Window Problem
Is there anything I can spray on the inside windows that wont allow them to get foggy? I don't wanna use the AC duing the winter to defog my windows. Regular heat wont cleat the fog, only when the AC button is on will the windows clear. Infact, if the ac button is not on the car will fog up completely. Help!
2011 GTI 2dr Tornado Red DSG Autobahn | Magnaflow Exhaust | Euro Cup Holder | Rear-View Camera | Auto-Dimming Mirror | ECS Blue Tinted Mirrors | 17" Goals |
#2 |
Formula 2 Champion
![]() Drives: 2.0 TDI, R Join Date: Jul 2009
why don't you want to use the AC to do what it's suppose to? I don't think you can do anything about it.
2009 VW Golf VI TDI 2013 VW Golf VI .:R Soundaktor delete
#3 |
![]() Drives: 2011 UG GTI DSG Join Date: Nov 2011
I have the same problem. It fogs up far more than any of my other cars.
#4 |
![]() Drives: '12 Passat VR6 SEL Premium Join Date: Sep 2011
That's like saying I want to listen to music but I don't want to turn on the radio.
#5 |
Formula 2 Champion
^this
#6 |
Guest
Posts: n/a
hahahah.. the point of A/C is to get the moisture out of the air... no where in "A/C" does it say the temp has to be cold..
#7 |
today it was 24F outside I started my car and turned on the A/C...light was on but it did not work...I knew it is stand by under a certain(don't know excatly what F) ambient temperature.
#8 |
![]() Drives: 2011 GTI CSG DSG 3DR Join Date: Jul 2010
I do not use AC to defog my windows when it is raining or snowing outside. I usually keep the air recirculate button on auto (Climatronic AC). When not using AC, the air is drawn from the outside. When the AC is on, the air is recirculated. Outside air plus some heat (with Climatronic system, around 19 or 20 deg.C setting) and vents set to defog mode (meaning air is coming out of the windshield defog vents), I do not get window fog. When you forget to turn off the air recirculate mode (i.e. your AC system is recirculating cabin air), your windows will fog up quite fast.
So far, so good! I love my MK6 GTI! |
#9 |
yes i think rain x makes a spray for the inside of the windows for fog. autozone/pepboys have it. i actually have been meaning to get it myself. i hate using the a/c in the summer i sure dont want to use it in the winter
|UNI KO4 #20 |Shaved Hood&Grille|APR Intercooler|Carbonio|Peloquin LSD|Brembo GT 330mm|CM FX350| Supreme Power Rear Matching Rotors|CM Methanol Injection|UR Catted/Res'd DP|Borla Catback|NEUSPEED RSe12 Hyper Black,KO4 TDP,TB Pipe,NEUSPEED 25mm & 28mm Sways,Support Brackets & Endlinks|Tyrol DeadSet Kit|R LED Tails|Black R20 BiXenon Heads|S3 Short Shift|Klii Rear Badge Inlay|VCDS Tweaked||SupremePower.com|KMDTuning.com|GSE| |
#10 |
![]() Drives: 2011 GTI Join Date: Jul 2011
Make sure the inside of the windows are extra clean. The dirt on the windows attract condensation moreso than if the windows are clean. Clean the windows, and see if this helps. I run the A/C most of the time, but during the cold periods - I don't use it and I have no issues with fogging - just be sure to not have the HVAC zone selector blowing on defrost.
2011 GTI Tornado Red. Protection Package | Ronal LZ-VT | Clear Bra | BSH TMI | APR Carbonio Stage 1 | APR Stage 1 | S3 SS | AWE CBE | R Tails |
#11 |
![]() Drives: 2012 CSG GTI DSG Join Date: Oct 2011
Mine fogged up constantly when it was new. Now that I have 1500 miles its gotten much much better.
#12 |
![]() Drives: 2012 VW GTI 6MT Join Date: Sep 2011
The windshield comes with a special coating on it from the factory. It will wear off eventually.
#13 |
![]() Drives: 2011 CSG MK6 GTI Join Date: Oct 2010
My A/C is always on. Winter or summer. Defrost mode or regular mode. 60 degree or 80 degree setting. I never have interior condensation. Period.
Oh, and I only use the recirculating setting if I'm behind a truck or car burning oil.
2011 MKVI GTI CSG Autobahn MY MOD THREAD: http://www.golfmk6.com/forums/showthread.php?t=12631 |
#14 |
![]() Drives: 2010 CW GTI DSG Join Date: Oct 2011
usually cracking the windows clears up any fog for me (basically only happens when I get in the car after working out)
APR | Forge | OEM+ | Osir | Magnaflow
#15 | |
Speaking of window coating from the factory.. how the hell do I get the circles off the window from mounting it. They are on the inside and my window cleaner (Stoners Invisible Glass) won't get rid of it and I don't want to rain-x the inside, but I might. Rain-x takes off ANYTHING in case you ever have weird grime on your windows. |
#16 |
![]() Drives: Black Beauty III Join Date: Oct 2011
don't mean to hijack, but is the AC the default when turning the climate control on? whenever I turn my system on it turns on the AC -- would like to change that.
#17 |
![]() Drives: 2012 GTI Carbon Steel Gray 4-door Join Date: Sep 2011
The A/C de-humidifies the air thus making the interior fog go away. Its a good a idea to run the A/C in the winter, it keeps the air-con compressor seals lubricated.
#18 | |
#19 | |
![]() Drives: 2012 GTI 2 door 6SMT/2009 CC Sport Join Date: Oct 2011
LOL same shit I have. Should've been cleaned at the factory. |
#20 |
Formula 2 Champion
I never personally noticed any drain on the power when I have the A/C on. Maybe it's a different feeling on petrol cars, but I drive with the A/C turned on all the time and I still get 4.7L/100km.
| Thread Tools | Search this Thread |
| Display Modes | |
