Old 11-29-2011, 07:52 AM   #1
WhyTar
WhyTar's Avatar
Drives: White 2012 Golf .:R
Exhaust actuator flap mod
Hi All,
Has anyone here performed the exhaust actuator mod to their Golf .:R?
If you look under the rear of the car you will see a small black device (looks a bit like a wastegate) attached to the right rear outlet. It also has a black tube attached.
Apparently if you kink the tube and tightly wrap a cable tie around it to close it off while the flap is in the 'open' position (check with a torch up the right exhaust) you get a deeper, louder exhaust note all through the rev range. Not just beyond 3800rmp when it is designed to open.
I'm interested to hear from anyone who has done this. And what they think the difference is?
MY12 Candy White Golf .:R
Black 19" Talla's l DSG l X-Force TBE l REVO'ed l BSH True Seal CAI l Maniac CF Paddles
WhyTar is offline   Reply With Quote
Old 11-29-2011, 10:06 PM   #2
WhyTar
WhyTar's Avatar
Actually, I did this mod overnight and drove to work this morning. The exhaust note was droning at 60kph and really offered no better sound under load. So I will be removing the cable tie tonight when it stops raining outside.
Old 11-29-2011, 10:27 PM   #3
bubuski
El Moderador
bubuski's Avatar
Drives: MK6 GTI 5-door TR
I wonder if we'll get this exhaust in North America or a water downed normal one.
Old 11-29-2011, 10:29 PM   #4
plac
Guest
Posts: n/a
silly mod anyway. keep your low end intact with that flap closed under lighter throttles.
Old 11-30-2011, 01:36 PM   #5
Genesis_R
Drives: Golf R 2010
I swapped my exhaust out for an aftermarket one for quite some time and I've gotten a random workshop to fit the stock one back (for emission inspection purposes) and I'm not sure if the flap is even working or not. It doesn't really matter I guess, or does it?
Genesis_R.
Genesis_R is offline   Reply With Quote
Old 11-30-2011, 05:14 PM   #6
65dunebuugy
Drives: 06 CW GTI
I wonder why VW is putting this on the R models again?? The 2.0T is a totally different sound than the VR6 was????
65dunebuugy is offline   Reply With Quote
Old 11-30-2011, 05:59 PM   #7
xHeartcoreboyx
xHeartcoreboyx's Avatar
Drives: '10 CW 2DR GTI DSG
I agree the 2.0T is nothing special sounds wise, unlike the VR6 in the R32.
| APR [K04,FMIC,CAI,TBE,TCU] | Snow S2 Meth | Neuspeed TOP&TBP | Setrab Oil cooler | Bilstein B14 | 034 Struts Mounts | SuperPro ALK | Stoptech Rotors/Pads/lines | VMR V804/YOKO AD08R | Build thread |
Old 11-30-2011, 08:25 PM   #8
WhyTar
WhyTar's Avatar
I can tell you why they are putting it on the Golf R. As I mention above, I deactivated the flap by kinking the pressure tube and the thing droned like a MoFo at 60kph. I struggled just having a conversation with my passenger.
Re-activated it... and perfect. Beautiful and quite while cruising... but still has the slight note under acceleration.
Old 08-27-2012, 05:42 AM   #9
kirahead
Drives: MK6 GTI adidas edition
Is this possible on the GTI..? never heard of it in my life though
kirahead is offline   Reply With Quote
