Old 12-08-2009, 08:42 AM   #1
redlulu
Drives: 2010 GTI 4dr DSG Turbo Red
Throttle Pedal Lag/Dead Space
I have a new MKVI GTI ,one month old , and it is my first car with an electronic throttle and turbo. Most of my driving so far has been in the city with many stop signs. I do not get a direct response between my foot pressing and the rpms when starting out at a stop sign. Many times it's count one, two,then it responds.
Even sitting at idle in the driveway if I start "pumping" the pedal and inch or so rapidly the rpms do not change, only the pedal moves.
Is this characteristic of electronic throttles and or turbos? The old direct reponse of a mechanical link throttle may have trained me wrong and I now have to relearn how to drive or should I head to the service department?
redlulu is offline   Reply With Quote
Old 12-08-2009, 08:46 AM   #2
TDR-380
Formula 2 Champion
TDR-380's Avatar
Drives: 2.0 TDI, R
I think you are experiencing "turbo lag". And it is always a few seconds before it kicks in. Nothing too serious. As for the pumping and nothing happening, it may be a characteristic of electronic throttle control.
Old 12-08-2009, 09:57 AM   #3
path
i am coming from a MK5 GTI, and have literally driven the 5 and 6 back-to-back. i can say with a great deal of confidence that there is a fair amount of slop in the throttle pedal. it takes more travel to get the rev response you want in the 6 than it did in the 5, and the spring in the pedal is much lighter. there was almost NO turbo lag at all in the 5. i can't imagine that turbo lag resurfaced in the 6, i think there have been some changes in the ride by wire software that connects the reostat on the pedal to the fuel injectors.
i wonder if revised ECU software from APR or the like will cure this?
path is offline   Reply With Quote
Old 12-08-2009, 11:17 AM   #4
koolgreen
koolgreen's Avatar
Drives: 2011 CSG 6mt detroits
There should be no delay what so ever.
As long as there is pedal movement, the engine revs should change.
The pedal is attached to a rheostat (throttle position sensor) that sends a signal to the ecm. The ecm is the governor that controls the fuel management system vis a vis the injectors and throttle.
Any change in position should cause an rpm change.
Especially if you are sitting in your driveway, in idle not in gear.
Turbo lag would not even be an issue if you are not in gear.
________
New Jersey Marijuana Dispensaries
koolgreen is offline   Reply With Quote
Old 12-08-2009, 05:18 PM   #5
tfcGTI
Drives: MkVI
I thought it was me but my MkVI also has that lag.
tfcGTI is offline   Reply With Quote
Old 12-09-2009, 04:12 PM   #6
MaxHedrm
Drives: 2010 TDI (Ordered) / 2001 Audi TT
Manual or DSG?
The DSGs I've driven all have a bit of a lag from stop signs.
MaxHedrm is offline   Reply With Quote
Old 12-09-2009, 04:37 PM   #7
MonthOLDpickle
Drives: 2010 VW GTI
Its usually more turbo lag than tranny lag.
MonthOLDpickle is offline   Reply With Quote
Old 12-09-2009, 05:40 PM   #8
path
i'm manual...
but it would not surprise me if it was all MK6's...doubtful they have different rheostat/sending units by transmission type
definitely not turbo lag...totally different
its more like extra play for the first fifth of pedal travel, before it tightens up and behaves the way you expect it to.
Old 12-09-2009, 08:15 PM   #9
tfcGTI
Drives: MkVI
Path
You hit the nail on the head. Exactly the same with manual.
Old 12-09-2009, 09:22 PM   #10
KanDyWyte
KanDyWyte's Avatar
Drives: White 5-Door GTI MKVI
I find that when you decided to give it some oomph and then decide to floor it... it doesn't change throttle reaction. I would give it(accelerator) 4/5 press then 5/5 and it's the same, so I went from 5/5 to 4/5 back and forth and it still accelerated as if I was flooring it. Nothing like my old SVT Focus... It would have bogged back and forth.
KanDyWyte is offline   Reply With Quote
Old 12-10-2009, 08:36 AM   #11
redlulu
It seems "throttle lag","dead space","slop". "extra play" is being experienced by many of us with DSG or manual. I hope we keep this topic alive until VW gets the message and has a TSB or recall for a fix. Thanks for all of the responses to my post.
Old 12-10-2009, 08:49 PM   #12
tfcGTI
Drives: MkVI
Having that lag at the wrong time could be tragic.
Old 12-11-2009, 01:44 PM   #13
dthomas53
Drives: MkVI CSG, 2DR, Manual
Yup, definitely notice a little delay when I floor it. Couldn't say for sure if it's "turbo lag" or the pedal, but I definitely notice it. However, since I'm not one to drag race it's really a non-issue for me.
Oh, and mine's a manual trans.
dthomas53 is offline   Reply With Quote
Old 12-11-2009, 05:39 PM   #14
BuchWash
Drives: 2010 VW GTI Mark VI, Carbon, Borbet
Interesting. Mine's a manual but I guess I've noticed this hesitation too. Will report it to the dealer at 90 day service. I get around the lag by giving it some throttle and feathering in the clutch and get off the line OK, but on full tromp there IS a little lag.
BuchWash is offline   Reply With Quote
