Old 12-09-2011, 01:31 PM   #1
roy_gti
Drives: Golf VI gti
How to remove Grille to replace front VW emblem?
i just received piano black VW emblem, order from blog-sport and i'm wondering how to remove the chrome vw symbol on the back and then put the black one on - i looked in the DIY's but couldnt really find any good info.
roy_gti is offline   Reply With Quote
Old 12-09-2011, 02:44 PM   #2
lon888
Drives: 2012 GTI Carbon Steel Gray 4-door
The grill assembly is held on by some torq fasteners (I'm thinking 4 of them) - they are easily seen when you raise the hood. Remove the screws and wigggle the grill a little, it'll come out.
Valentine 1 / OEM Short Shifter / Euro Dash Cubbie / Euro Seat Cubbie / ECS Torque Arm Insert / Tyrol sport caliper kit / Euro light switch / Dummy button garage door opener / Auto dimming mirror / Stainless Brake Lines / BFI 25mm rear sway bar / euro front and rear cupholders / 42dd Shifter bushings
lon888 is offline   Reply With Quote
Old 12-09-2011, 02:48 PM   #3
Vwfreak
Vwfreak's Avatar
Drives: 2012 CW TDI
Put your fingers in the emblem, and turn slighty clockwise. To put back new one repeat the same steps but counter clockwise. No need to remove the grill.
TDI
Vwfreak is offline   Reply With Quote
Old 12-09-2011, 02:56 PM   #4
michal
michal's Avatar
Drives: 2-door coupe
It can be done just by turning the emblem counterclockwise and pulling it out but if you don't want to brake any of the emblem clips you have to remove the upper grille first.
1) Remove the upper grille ( 4 T25 torx screws off the top of the grille assembly, then press the top of the bumper down, and at the same time pull the grille gently up and out.
2) Turn the emblem counterclockwise (about 20 degrees, you should hear a click) You have to turn the emblem first to align its clips with the “slots”.
3) Turn over the grille
4) Push down the bottom of the net (there are 2 clips holding it on the bottom)
5) Push and slide down the “net” just a little (there are 2 more clips holding it on the top)
You can also do it in a different order #4 and 5 first and then #1 (turn the emblem while watching the clips on the back) if you are afraid you can brake them.
6) Use a small screwdriver or a paint can opener (it has a small hook and it will be easier to pull the clips)
7) Find one of the clips and pulling it toward the center of the emblem, pull down the emblem at the same time (first make sure that the clips are aligned with the “slots”). If not align them first by turning the emblem to the left or right a little.
8) Do the same for the second clip. Usually that’s enough to remove the emblem but you can do it with the third one, too.
9) Put back the “net”
10) Put the emblem back
11) Turn it clockwise to align it (you will hear a click)
michal is offline   Reply With Quote
Old 12-16-2011, 04:12 AM   #5
Halvie
Drives: 2010 Penalty Box
is it clockwise or counter clockwise to get it out...
Old 12-16-2011, 09:57 AM   #6
Vwfreak
Vwfreak's Avatar
Drives: 2012 CW TDI
I remember turning mine clockwise when I had to remove it...
The instruction from Michal are done with the grill removed from the car. To remove the emblem only, you just turn it gently and the emblem comes out.
TDI
Old 12-16-2011, 06:28 PM   #7
ChiGuyGolf2.5
Drives: 2011 Golf 2.5L
Let me just point out the name from the thread "How to remove Grille to replace front VW emblem"
Im confused... which is it, front or back?
ChiGuyGolf2.5 is offline   Reply With Quote
Old 12-16-2011, 07:06 PM   #8
michal
michal's Avatar
In the first few lines of my instruction I stated that you can remove it without taking of the front grill. But I do not recommend it. I did it 3 times by turning the emblem but when I did it for the 4th time I broke 1 clips.
It's definitely counterclockwise.
Old 12-16-2011, 07:08 PM   #9
michal
michal's Avatar
You do not have a rear grille so it's for the front one.
Old 01-09-2012, 10:54 PM   #10
bmallicote
Drives: 2011 Tornado Red Autobahn GTI
I tool the grill off to remove mine. it was a challenge. but better than braking something.
'11 4dr DSG Tornado Red Autobahn, APR stage 2 ECU, APR CAI 1 & 2, APR downpipe, APR Badge, Clear side markers, Blacked out Front emblem, Red led throughout cabin, Euro switch, Golf R tail lights, FK Silverline Coilovers, Cross Drilled & Slotted Rotors.
bmallicote is offline   Reply With Quote
Old 01-16-2012, 04:19 PM   #11
razr390
Formula 2 Champion
razr390's Avatar
Drives: 2013 CW Driver's Edition
I need help! I got the grille off but would anyone care to explain to me how to take the polished front of the grill from the matte part, what clips do I unsnap, etc.?
I'm only 17 and this is my first DIY with this car..
Any help is greatly appreciated!!
razr390 is offline   Reply With Quote
Old 01-26-2012, 05:08 PM   #12
Delta0Medusa
Delta0Medusa's Avatar
Drives: 2011 GTI 6spd
This may be the most difficult thing ive ever done. Im still working on removing the front emblem...going to smash the damn thing with a hammer in a second
Delta0Medusa is offline   Reply With Quote
Old 01-26-2012, 05:09 PM   #13
JDM713
JDM713's Avatar
Drives: 2010 CW GTI DSG
any tips on removing the front GTI badge to replace? I know it has clips, but is removing the grille recommended/necessary?
| APR | Forge | Koni |
| OEM+ | Osir | Magnaflow |
| H&R | SPM |
JDM713 is offline   Reply With Quote
Old 01-26-2012, 05:11 PM   #14
Delta0Medusa
Finally got it off. Complete pain(at least for me) until i finally noticed the clips everyone has been talking about. First coat of Plasti dip is on!
