Old 12-21-2011, 03:00 PM   #1
RIP335
Drives: 2010 CW 2dr GTI
Vibrations in brake pedal
So last week I took my car for it's 30k service, and ever since then I feel a vibration in the brake pedal when I apply the brakes. I also feel it when I start the car and I'm sure the dealership is going to say something stupid because I have a CAI and try to blame that for it.
Batards I don't know what to do...
Gino Lomeli
e|studioG Design
http://estudiogdesign.com/
RIP335 is offline   Reply With Quote
Old 12-21-2011, 03:01 PM   #2
grambles423
Limited Activity
grambles423's Avatar
Drives: 2008.5 BMP GTI
Stage 2 piping is rubbing on the brake lines. This is a common problem in aftermarket intakes.
UnNaturally Aspirated
APR Stage 1- ECS Dogbone
Old 12-21-2011, 03:01 PM   #3
Stuart M
Drives: 2011 GTI 4 door Black
Take it in. Don't see how they could say CAI could cause brake pedal vibration.
Stuart M is offline   Reply With Quote
Old 12-21-2011, 03:31 PM   #4
MKVInce
MKVInce's Avatar
Drives: 2012 CW GTI 6MT, 2007 OB G35 Coupe
+1
Stage 1 can do it too. Some stage 1 intakes (carbonio) sits lower than stock, pulling the flex down touching the brake line and causes vibrations.
Stage 2 intakes pipe touches the brake line causing vibrations. It's very common! A little adjustment will get rid of it.
2004 G35 (sold)
2007 G35 (current)
2012 GTI MK6 (sold)
2013 Evo X (sold)
2015 BMW X3 (current)
MKVInce is offline   Reply With Quote
Old 12-21-2011, 03:44 PM   #5
plac
Guest
Posts: n/a
maybe because that IS the issue..........
Old 12-21-2011, 09:52 PM   #6
Phalanxr
Drives: Lemon
I had this issue for many months, I replaced the EVOMS intake back to stock, still vibrated. Replaced stock with APR, still vibrated. Eventually my brakes failed completely. Fun times.
.:2010 MK6 GTI - Black on Black - Unitronic Stage 2 Tuned - APR Carbonio Intake - Race Land DP:.
Vaders Build
Phalanxr is offline   Reply With Quote
Old 12-21-2011, 10:02 PM   #7
mark986
Drives: 2010 VW GTI
Did yours vibrate when braking?
APR Stage I & 2 Intake | APR K04 | APR Downpipe |APR FMIC | R Tail-Lights | Rev. D
mark986 is offline   Reply With Quote
Old 12-22-2011, 04:22 AM   #8
RIP335
Completely failed? How did you end up finding out?
Gino Lomeli
e|studioG Design
Old 03-29-2012, 10:50 AM   #9
valj
Drives: Golf 6 GTI DSG
Same issue! Just installed my injen CAI
valj is offline   Reply With Quote
Old 03-29-2012, 10:59 AM   #10
TrackStar
Drives: 2010 CW Passat
then you should move it out so its not hitting..
Unitronic > APR Switched from APR to UNI and never looking back
CW '10 Passat 2.0TSI: UNI Stage 2 VMR V705 19x8.5 et45 Podi Boost gauge/pod AWE DV, Turbo Outlet Pipe BSH Boost Tap BillyBoat 3" TBE BFI Stg2 Dogbone/motor mount/trans. mount KW V2 coils Forge Twintake(1st on Passat/CC) JBL W12GTi MKII HEX+CAN vagcom, Podi.ca podi free ship code: NINOSHIP, VMR | Wheels velocitymotoring.com
TrackStar is offline   Reply With Quote
Old 03-29-2012, 10:59 AM   #11
grambles423
Limited Activity
Then fix it!
Old 03-29-2012, 12:38 PM   #12
valj
Thanks, guys!
will do.
What's strange is that it happens only when the car is still cold. After it warms up the vibrations disappear!
Brake lines shrink? :-D
Old 03-29-2012, 12:41 PM   #13
plac
Guest
Posts: n/a
Thanks, guys!
will do.
no. your car shakes more on warmup, and also because the idle is higher for a bit.
Old 03-29-2012, 01:00 PM   #14
Modshack
Modshack's Avatar
I've been shipping out quite a few Bracket kits to solve the (similar) Carbonio problem...Sounds like you either need to re-fit the CAI or do a bracket up to keep it off the lines.
Mounts like this:
