sgessler2011
For Christmas I received the ECS Tuning VW jack pad kit.
http://www.ecstuning.com/Volkswagen-Golf_V--2.0T/Search/Jack/ES251835/
At first I didn't think it would fit the GTI. Upon second inspection I discovered that the front jack pad location is concealed by a part of the underbody aerodynamic shielding with the dimples on it. Once the small access panels are loosened the factory installed cover that is plugged into the frame can be removed by prying with a flathead screwdriver and the front jack pad can be gently jacked into place within the frame.
The rear install was much easier. Simply pull the rubber plug out of the frame and replace with the jack pad plug by jacking it into the frame slowly. Now when you want to lift the car you can do it with much greater confidence using the factory designed OEM parts.
See the attached photos for help. The ECS install page is pretty bad and doesn't mention the GTI needs the front underbody panel removed to install the front kit.
Steve
Steve
