Old 01-19-2018, 02:14 PM   #3431
Jeebus
Drives: So many
Edit
Jeebus is offline   Reply With Quote
Old 02-04-2018, 10:30 PM   #3432
Subzeuro
Drives: Mk6 gti
Hi guys, im looking at buying a set of alphards 18x8.5et35 on 215/35 in the front, 18x9.5et40 on 215/40 in the back, im on h&r supersports, was wondering how they would fit, if anyone has similar specs and if id run into any problems
Subzeuro is offline   Reply With Quote
Old 02-09-2018, 06:16 PM   #3433
KDOG
Drives: CSG GTI
Have a great opportunity to buy barely used H&R ultralows extremely cheap want to make sure I won't have issues, will do screw mod but want to make sure I will not have issues with current setup before pulling trigger.
18x8 et50 with conti dw 225/40 r18 will I have issues dropping it 1.5-2in on ultralows? Do I need to roll fenders before install to be safe? Doing screw mod regardless.
KDOG is offline   Reply With Quote
Old 02-10-2018, 09:09 AM   #3434
snobrdrdan
Formula 2 Champion
snobrdrdan's Avatar
Drives: a VW
You'll be 100% fine. Your wheels/tires aren't that aggressive & the negative camber from lowering will help you clear everything
2017 Passat VR6
2017 Passat R-line
Old 02-14-2018, 09:18 PM   #3435
rancheroebay
H&R supersports, stock struts, stock detroits 18x7.5 et51, 225-40-18 tires, 10mm spacers front, 15mm spacers rear, fender screw mod. And i have no fender rub.
Thought i would post a reference picture for those that are looking.
rancheroebay is offline   Reply With Quote
