Old 12-29-2011, 12:54 PM   #1
rizzogti
rizzogti's Avatar
Drives: 2010 CW GTI 6sp
titanium plating??
does anyone know a company (midwest area if possible) that would do some sort of titanium/burnt titanium color plating? i have a few parts i wanna do.
here is an example of what im looking for:
http://www.google.com/imgres?q=titan...:429,r:6,s:148
Originally Posted by GTI787 View Post
I LOVE LITTLE BOYS!!!
rizzogti is offline   Reply With Quote
Old 12-29-2011, 12:59 PM   #2
rizzogti
rizzogti's Avatar
only idea i have right now is that the parts would need to get chromed and then heat treated?? but im not positive.
Old 12-29-2011, 01:05 PM   #3
Modshack
Modshack's Avatar
You can get that look with a translucent Powdercoat finish as well but your Powdercoater would have to be GOOD...
Old 12-29-2011, 01:14 PM   #4
rizzogti
rizzogti's Avatar
have any links to some colors?
Old 12-29-2011, 02:53 PM   #5
dustinouch
Drives: 2010 MK6 GTI CSG
So you don't confuse vendors when you get request quotes: it's impossible to plate(deposit) titanium over aluminum. Heat treating is a process to harden the metal structure by introducing carbon, another term I wouldn't use.
I can't tell for sure but those could actually be titanium lips that have been anodized and have a clear coat over to protect it. Why not just buy those wheels, it would be a lot cheaper.
USED wheels finds
My Thread: 034 Motorsport, APR, Akrapovic, Carbonio, Diesel Geek, GFB, Ohlins, SRS-Tec, Stoptech, Tyrolsport, Unibrace, VWR, SSR, Desmond, OEM aero
“Good equipment ain’t cheap, and cheap equipment ain’t good.”
dustinouch is offline   Reply With Quote
Old 12-29-2011, 02:58 PM   #6
Modshack
Modshack's Avatar
http://www.columbiacoatings.com/category_s/5.htm
Check the Translucent, Illusion, and Shimmer colors
More here:
http://www.powderbuythepound.com/Tem...olled_Powders/
Old 12-29-2011, 05:45 PM   #7
rizzogti
rizzogti's Avatar
i know you cant plate titanium on aluminium, but the lips on the gram lights arent made of titanium. its just a burnt titanium look that they have. ultimate racing has it on my exhaust, only its all blue and not all different colors like what i want.. oh and those wheels are about $900+ a pop lol
Modshack thanks for all the help, ill see what i can come up with.
Old 12-29-2011, 05:48 PM   #8
rizzogti
rizzogti's Avatar
looked thru those. unfortunately no one seems to have the multi-colored titanium look that im going for.
Old 12-29-2011, 06:26 PM   #9
dustinouch
I tried searching online about the Gram Light 57 Pro's you posted, you positive the lips aren't Ti? The reason the UR tips are blue are because they are titanium that's been heated with a blow torch, blue is the easiest color to achieve.
The combination of colors on the Rays lips can usually only be done by dipping Ti in an acidic bath with specific currents running through. I haven't seen powder coating that can replicate that range of colors in the same piece.
Even if you were to dip your UR exhaust tip, I'm not sure if the color would be stable because of the heat that its exposed to.
USED wheels finds
Old 12-29-2011, 06:30 PM   #10
rizzogti
rizzogti's Avatar
the UR exhaust tips cant be real titanium.. its welded onto my stainless steel exhaust... Ti can only be welded onto Ti IIRC.... im just trying to find a chrome color with blues, purples, yellows, and greens mixed in. guess this is harder than what i thought it was gonna be lol
Old 12-29-2011, 07:15 PM   #11
dustinouch
The tip could be Ti if it was press fit or riveted to another metal and welded together it's pretty common. I think Akraprovic has a similiar setup since the whole this isn't full Ti.
You can get some pretty wild colors with a bead blaster, torch and some WD-40, but the colors might bleed over time.
I think blue/purple is really you're only long term option
BTW I'm not trying to be a dick with my know-it-all responses, just trying to be helpful is all
USED wheels finds
Old 12-29-2011, 07:29 PM   #12
rizzogti
rizzogti's Avatar
no way man, i totally understand.. i personally have no clue how to go about getting the desired color im looking for. your info has been very helpful. i just wish i could get a clear cut answer from someone as to whether or not i can sandblast my wheels, and have a company do that color on my wheels somehow lol. i've been doing alot of searching today, and so far no luck!
Old 10-04-2017, 09:44 AM   #13
tech54K
Drives: Refurbished
Try to check this website: https://www.reliantfinishingsystems.com/
tech54K is offline   Reply With Quote
Old 10-04-2017, 11:40 AM   #14
EJBGTIVI
Formula 2 Champion
EJBGTIVI's Avatar
LOL, you do realize this tread is 6 years old
Forum Guru/Sticker Police/Stable Genius
Originally Posted by Vancity2Constantinople View Post
this forum just keeps getting more stupider each day.
R.I.P. Shuggie 2.19.2000 - 3.19.2016
EJBGTIVI is offline   Reply With Quote
