Old 12-21-2009, 02:31 PM   #1
mdashali
mdashali's Avatar
Drives: 2010 CSG 4D DSG
Question Is 2.0T TSI better than 2.0T FSI?
After reading this forum, I am bit confused
http://forums.vwvortex.com/zerothread?id=3889971
2.0T TSI has been out for over a year, how does it stack up in terms of reliability to 2.0T FSI?
I am new to VW and in the process of getting a MKVI by the end of the year.
mdashali is offline   Reply With Quote
Old 12-21-2009, 04:30 PM   #2
bubuski
El Moderador
bubuski's Avatar
Drives: MK6 GTI 5-door TR
The TSI is the way to go and reliability has been good. I recall it was first seen in North America from March 2008 Passats.
Reading the link you posted though, most people are just debating about the top-sided oil filter spilling gas during an oil change...as well as timing belt change on a transverse TSI engine.
Looking at both similarly spec'd engines (TSI & FSI) at 200hp, the TSI comes out on-top slightly better in power deliverey and realiability.
<thread moved>
Old 12-21-2009, 05:07 PM   #3
mdashali
mdashali's Avatar
The previous link mostly speculated about the reliability of the TSI over FSI given it has timing chain, plastic water pump etc etc....
Here is good post about TSI engines
http://forums.vwvortex.com/zerothread?id=4042736
I know it is too early to have any engine related troubles, I would like to hear from other owners of MKVIs.
Old 12-23-2009, 07:34 PM   #4
mdashali
mdashali's Avatar
TSI High Pressure Fuel Pump (HPFP) failure - Have to watch out for this.
http://forums.vwvortex.com/zerothread?id=4539818
Old 12-24-2009, 11:45 PM   #5
v-dubGTI10
v-dubGTI10's Avatar
i had a quick question guys....would a cold air intake and a blow off valve built to fit mk5 GTI 2.0T would that fit the mkv6 GTI? i just got the 2010 GTI and i was searching online and everything that comes up sayin 2006-2010? but on here u guys are talking about the TSI and the FSI motors..just seein ifu guys would have any idea...thanks
v-dubGTI10 is offline   Reply With Quote
Old 12-25-2009, 06:34 AM   #6
roastpuff
roastpuff's Avatar
Drives: Mk6 GTI
As long as the intake and the blow-off valve is made for the 2008.5/2009 TSI-engine MkV GTI, it should fit. For the intake, it will depend on the layout because I'm not sure if the engine bay shape of the Mk6 is different.
Old 12-29-2009, 10:41 AM   #7
pitbull592
pitbull592's Avatar
Drives: 1979 rabbit VR6,2012 golf r,04 vrod
Both are good imo & each has their own strength & weaknesses.
Instagram @mad_german
pitbull592 is offline   Reply With Quote
