Old 03-29-2012, 03:45 PM   #43
f00kie
Drives: TBD
Definitely. Mix it 50/50 with either distilled or tap water. Doesnt make a difference. Distilled might be better and its only about $1-2 at the grocery store
Thanks. And is there a way to figure out the revision of the DV ahead of time without taking stuff apart (lifting on stands is fine)? My car is a 2012 so maybe they put 'D' in there by now?
f00kie is offline   Reply With Quote
Old 03-29-2012, 08:42 PM   #44
jackgti
Drives: vw
damn I wish I had more experience so I could pull this off myself. good work
jackgti is offline   Reply With Quote
Old 03-29-2012, 09:02 PM   #45
grambles423
Limited Activity
grambles423's Avatar
Drives: 2008.5 BMP GTI
Meh you could do it. This was my first turbo install as well.
UnNaturally Aspirated
APR Stage 1- ECS Dogbone
Old 03-29-2012, 09:24 PM   #46
sgessler2011
sgessler2011's Avatar
Drives: Now: MK7 GTI PP, traded in my 2011
Search around my posts you'll find my 2011 has a Rev C piston type diverter the same as the D type. It looks like from 2011 up the cars come with the really robust piston type diverters. Get under the car and check it: its on the turbo (passenger side.)
The ones that failed didn't have a piston, but a thin diaphragm subject to tearing.
Now 2015 GTI SE Performance Pack
Then: 2011GTI Carbon Steel Gray DSG
1992 Corrado SLC VR6
sgessler2011 is offline   Reply With Quote
Old 03-29-2012, 10:41 PM   #47
dave80
dave80's Avatar
Drives: vw
read this diy few times in the last few days. Any specific way to top off the coolant fluid at the end. Wanna make sure I get all the air out of the coolant system.
dave80 is offline   Reply With Quote
Old 03-30-2012, 05:26 AM   #48
grambles423
Limited Activity
You wont loose much coolant in the end. Normally the air will make its way out of the system and into the expansion tank upon that first initial start-up. I fired up my car the first time, waited a little bit, then my MFD told me to fill up coolant. Simple process.
Old 03-30-2012, 09:44 PM   #49
dave80
dave80's Avatar
Drives: vw
ok, thanks for clarifying that. Waiting for the ko4 kit to arrive, and will install it asap.
Old 03-31-2012, 09:17 PM   #50
SuPeR GTi
SuPeR GTi's Avatar
Drives: 12' GTI MT
this is a pretty intense diy. too many variables that can go wrong imo. i would just pay to have it done. props to you grambles for doing this
Old 04-11-2012, 11:06 PM   #51
dave80
dave80's Avatar
Drives: vw
useful link: http://www.goapr.com/support/tsi_k04_installation.pdf
Old 04-14-2012, 11:36 PM   #52
dave80
dave80's Avatar
Drives: vw
Just finished the install. 11 hours total in 2 days, with breaks and a dealer visit to get some g12. I did loose about half of a gallon of coolant, and most of it poured out when I took out the banjo bolt on the coolant return on the turbo (so be ready). Also the nuts on the manifold studs (on the engine block) were 12 mm not 13mm for me. It's also easy to take off the heat shield bolts from the bottom of the car. Just remove the downpipe first.
Old 05-20-2012, 10:40 AM   #53
plac
Guest
Posts: n/a
will all the dreamers in this thread go look at the new never installed APR KO4 kit for sale? he only wants $2000 shipped.. and its local for me. i need someone to buy it so i can stop looking at it. thats a sick price...
http://www.golfmk6.com/forums/showthread.php?t=38374
Old 05-20-2012, 12:09 PM   #54
dave80
dave80's Avatar
Drives: vw
buy it plac.
Old 05-20-2012, 01:05 PM   #55
Ironhorse
Ironhorse's Avatar
Drives: Black Beauty III
have you fallen and can't get up?
damn that's
Ironhorse is offline   Reply With Quote
Old 06-01-2012, 10:43 AM   #56
plac
Guest
Posts: n/a
always wondered this... after you install.. and before you have a K04 flash..
is the K04 on simple stage 1 (or stock) program faster, or do you need the KO4 tune before you start feeling any power increase?
zach in a muscle shirt
