Old 06-01-2012, 10:52 AM   #57
grambles423
Limited Activity
grambles423's Avatar
Drives: 2008.5 BMP GTI
Originally Posted by plac View Post
always wondered this... after you install.. and before you have a K04 flash..
is the K04 on simple stage 1 (or stock) program faster, or do you need the KO4 tune before you start feeling any power increase?
I was told to either unplug my MAF and drive casually before I got my tune.
Logically, the N75 will react differently on the K04 as opposed to the IHI VTR501. So a duty cycle that is ok for Stage 1 might surge the hell out of the K04 and cause damage. You cant boost wide open at lower RPMs, but this all depends on what the K04 can do physically relative to what the ECU is trying to MAKE it do.
Stage 1 and 2 tuning are optimized for the IHI. You can always slap a K04 on there with stock exhaust and intake and have that OEM feeling with almost as much (if not more) power than a stage 2, if that's what you're looking for.
UnNaturally Aspirated
APR Stage 1- ECS Dogbone
Old 06-01-2012, 10:53 AM   #58
GunKata
MILFn00dzHunter.com
GunKata's Avatar
Z - the APR kit doesnt include a new DV?
Everybody knows GunKata > *.*
No GunKata, no care.
Chicago Car Network
I can haz 350z racecar?
Old 06-01-2012, 10:55 AM   #59
grambles423
Limited Activity
Nope. I purchased it separately from ECS among other things. You can get it cheaper at Keffer
Old 06-01-2012, 11:11 AM   #60
plac
Guest
Posts: n/a
even if you go into stock program on stage1/stage2 tune, you still have to disconnect the MAF??
Old 06-01-2012, 11:21 AM   #61
grambles423
Limited Activity
I don't think so. I think you unplug it if youre having driveability issues in stock mode
Old 06-08-2012, 03:06 PM   #62
plac
Guest
Posts: n/a
as you are putting the new turbo back on the car. do you first place the intake manifold gasket, or do you set the intake into the V slots, then slide the gasket in?
Old 06-08-2012, 04:32 PM   #63
grambles423
Limited Activity
Place the gasket on the block studs THEN place the turbo into the V-Blocks. Much easier that way. The turbo wont really move once its in the blocks. Its really nice and just slides in like a virgin.
Old 06-09-2012, 08:35 AM   #64
Bender
Bender's Avatar
Drives: 2014 Focus ST
So you really need to kinda cram it in there and hit it with a rubber mallet a few times?
Old 06-09-2012, 08:39 AM   #65
andy_uranium
andy_uranium's Avatar
Drives: 2011 mk6 GTI CW, 2004 Acura TSX
Haha, terrible visual.
my moderate build thread - http://golfmk6.com/forums/showthread.php?t=16739&page=2
2011 CW GTI - DSG, Leather, LED R tails, OEM front lip, color matched side markers, red footwell leds, klii plaid vinyl accents, DG springs, Unibrace XB, UB and RB - OZ supertourismo LMs - Hankook V12 evo
andy_uranium is offline   Reply With Quote
Old 06-09-2012, 09:25 AM   #66
grambles423
Limited Activity
depends on how "slippery" the virigin is its a tight fit, but it goes in well!
Old 06-09-2012, 09:27 AM   #67
mark986
Drives: 2010 VW GTI
^ Amen!
APR Stage I & 2 Intake | APR K04 | APR Downpipe |APR FMIC | R Tail-Lights | Rev. D
mark986 is offline   Reply With Quote
Old 06-12-2012, 01:06 PM   #68
plac
Guest
Posts: n/a
another task im worried about, removing my stock rear intake pipe. so many people break that clip trying to get it off the tube. Maybe i should just do that part now, to know if its gonna break or not. then i can just have a new tube here by the install time if needed. and if it doesnt break, it will be loose and ready for the work.
and the other final question for the whole DIY. when tightening your 13mm nuts on the exhaust manifold. Do you have room for your torque wrench sitting upwards to top? Maybe a 1" or 3" extension on that thing?
Old 06-12-2012, 02:33 PM   #69
grambles423
Limited Activity
My tabs were already broken and I installed a new one during the install. Might not hurt to try...but that damn thing is so flexible, its bound to break.
I had a 3" extension with the torque wrench angled up. However, I also had the rain tray out and the sheet metal part that runs across that void out, gave me lots of room. Might consider that when you're installing.
Old 06-12-2012, 05:35 PM   #70
plac
Guest
Posts: n/a
jesus... one of those red plugged fittings is under the wastegate rod, under the manifold... looks like it will be a real beast to get to and work with.
anything i can do in prep days before?
swap that one coolant plug?
install the 4 downpipe studs?
and i have that ONE thick copper washer. i think it said it goes on the coolant fitting, between the turbo and banjo metal, then a normal thin one on the other side of that banjo fitting..
only got 1 tiny piece of paper instructions with it. wouldnt be even possible to do with just those instructions for me.
zach in a muscle shirt
