Jason3D
So this isn't the typical cup kit versus coilover question. Well sort of...
Here's my situation: I have a set of H&R Supersport springs that I ran with stock shocks for a while, but found that the ride was bumpier than I liked, and that it seemed to run out of shock travel over larger bumps and dips at higher speeds. I'm not sure if the shop that installed them trimmed down the bump stops so that may have been a contributing factor as well. Anyway, I thought the ride height was perfect, but decided the ride comfort wasn't what I wanted, so I switched back to my original setup of DG springs and stock shocks (which ride great).
Here's my question: I am wondering if I paired the H&R Supersports springs with a set of adjustable Koni shocks, would I be able to get a much more comfortable ride than when they were paired with the stock shocks?
Aside from the obvious advantage of height adjustability, would there be any additional benefit of just selling off the H&R Supersports and buying a set of Koni coils? If I went with the coils, I would most likely set them to a height very close to what the Supersports were at anyway, so I am really just wondering if the Koni coils would have a similar ride comfort as the Supersports paired with Koni shocks, if they're both at a similar ride height.
I saw that WRDUSA has a sale on Koni coilovers right now for about $1k, versus a set of Koni Yellow shocks would be about $600 and I could just re-install the Supersport springs with them.
Any insight or experience with similar setups is appreciated. Thanks!
