Old 01-12-2012, 10:02 AM   #1
D Darko
D Darko's Avatar
Drives: '10 GTI: Black/4dr/6spd/Dynaudio
Mounts to compliment K04?
Calling all K04 owners...what engine and trans mounts are you using? Looking for actual experiences, not what you think you might be getting, please. Particular info/questions are:
Now that you have the K04 and mounts, in hindsight was it necessary or recommended?
What are the pros/cons of living with your particular mounts as a DD?
Would you purchase them again?
Any other info/advice you would give on mounts based on your experiences?
Thanks for your time!
APR Stage II v1.2, APR Downpipe, Carbonio (w/Modshack support), Southbend DXD Stage 2 Endurance (Revised and Cryo'd), Peloquin LSD, Tyrolsport Deadset Kit, BSH Insert & Pendulum, Dieselgeek Short Shift Kit, APR/Hotchkis Sways F/R, Unibrace UB, p3cars Digital Boost Gauge, OEM Rev 'D' Diverter, OEM 9w7 Bluetooth, OEM LED R Tails, Smoked Sidemarkers, Tint (35/50)
"Why are you wearing that stupid man suit?"
D Darko is offline   Reply With Quote
Old 01-12-2012, 10:05 AM   #2
D Darko
D Darko's Avatar
Stage 3 owners feel free to contribute as well. Didn't mean to exclude you guys...
Old 01-12-2012, 10:13 AM   #3
grambles423
Limited Activity
grambles423's Avatar
Drives: 2008.5 BMP GTI
Answer in Bold
Originally Posted by D Darko View Post
Calling all K04 owners...what engine and trans mounts are you using? BFI Stage 1 Engine and Trannsmission Mount + ECS Dogbone
I say neccessary, but that question yields too much subjectivity. I will say this, inserts are not the way to go. If you're doing to do it, get ALL the mounts together so they compliment each other.
If you were to stiffen one, the energy is transferred to the other 2 mounts causing more vibration and deflection of the rubber. That causeds more damage.
If you were to stiffen two, the energy is then transferred to one mount and adds twice the deflection causing even more damage.
Adding all three, transmits all the "lost" power through the driveline
Pros: Solid Shifting, Great Response, WOT Growl reverbs through the cabin better and sounds AWESOME, yet quiet in normal driving situations.
Cons:
I get a tiny vibration in reverse, nothing to cry home about and I will probably burn my tires quicker.
Yes, with no hesitation at checkout.
Make sure you retorque after the given mileage in the instructions. These mounts are PERFECT for DD because they are not a very hard rubber but are still harder in durometer than the stock mount. Most mounts stretch their limits and offer harder durometers to market better. Its easier to tell people you have a higher duromter, so that should translate to a better product. Thats false. While harder is better, yes, driving experience outweighs that.
Looks great in the engine bay as well.
UnNaturally Aspirated
APR Stage 1- ECS Dogbone
Old 01-12-2012, 10:39 AM   #4
MasterKevin
MasterKevin's Avatar
Drives: MK6 Golf GTI
Running all bsh mounts with my awe k04
Well worth it. Except increase in vibration.
But bare able. You can def notice it though.
Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.
MasterKevin is offline   Reply With Quote
Old 01-14-2012, 11:08 AM   #5
bvlgari
Drives: Golf Gti MK6
What kind of vibration? I'm seeing threads that saying all this mounts will cause vibration. What does it mean?
bvlgari is offline   Reply With Quote
Old 01-14-2012, 11:49 AM   #6
grambles423
Limited Activity
Increase cabin vibration that you can feel.
Old 01-14-2012, 11:58 AM   #7
gregprep29
I spoke with the guys at USP about the other mounts. I agree with what grambles said, just the torque arm insert. They said for DD, all of the other motor mounts is not recommended because the amount of vibration isn't worth the performance gains. They said the best way to reduce loss of traction is the torque arm insert, lowering your car, better tires. If you want to spend $ on an lsd, that'd be another addition. I have the bfi torque arm insert and I think it's the best mod you can get for the gti whether stock or k04. I will soon lower my car, and then use the stock tires until I wear them out. After driving the k04, I will not invest in an lsd. The car is very manageable with the k04, and while it does spin tires in first and second, it's not killer. I would say get the torque arm insert, lower it, and get better tires when you need them. That's my plan. I'm also looking into that vag-com of the xds system. Apparently you can change it to the stock setting of the Scirroco.
APR K04---APR Carbonio Stg 1 & Stg 2---APR Intercooler---AWE Turbo Outlet Pipe---OEM S3 Short Shifter---UR Catted-Resonated Downpipe---BFI Torque Arm Insert---H&R Sports Springs---Whiteline Anti-Lift Kit---Whiteline rear bushing kit---SB Stage 3 Disc Only---USP SS Brake Lines---Hawk HPS pads
gregprep29 is offline   Reply With Quote
Old 01-14-2012, 12:01 PM   #8
gregprep29
grambles, aren't the torque arm insert and dogbone insert the same thing? "BFI Stage 1 Engine and Trannsmission Mount + ECS Dogbone" I thought it was the same thing, just named differently????
Old 01-14-2012, 12:09 PM   #9
DRedman45
DRedman45's Avatar
Drives: UG '10 4dr gti(sold)-E86 //M coupe
Send a message via AIM to DRedman45
torque arm=dog bone
but he actually suggested getting all the mounts and not just the dog bone. BFI makes poly replacements for the oem rubber in the engine and trans mount...stage 1 is good for a daily
I will miss my K04 gti
DRedman45 is offline   Reply With Quote
Old 01-14-2012, 12:41 PM   #10
mg_90
mg_90's Avatar
Drives: ┤11 GTI
Just a question for a owner of a BFI engine mount. Does this mount have the support for the bracket that holds the wiper fluid reservoir in place? This bracket is also bolted to the chassis on the left in the engine compartment. For example the BSH mount has this support.
Thanks in advance.
Instagram: @mk6gtimike
mg_90 is offline   Reply With Quote
Old 01-14-2012, 12:43 PM   #11
DRedman45
DRedman45's Avatar
the bfi mount is an insert that goes inside the stock aluminium mount...it replaces the rubber
Old 01-14-2012, 12:46 PM   #12
Smoooth
Drives: 2011 GTI 4 door
I have Dogbone on tranny only. Vibration at 1800 rpm rattles ceiling center console-glasses holder. Annoying but trying to live with it for now. May put stock back…
http://www.golfmk6.com/forums/showth...pr+k04+project
Smoooth is offline   Reply With Quote
Old 01-14-2012, 12:48 PM   #13
DRedman45
DRedman45's Avatar
^thats weird...i don't have issues at all with mine
Old 01-14-2012, 01:02 PM   #14
Smoooth
Wish there was no vibrationů Looked under the vehicle for any other source. No rubbing parts, exhaust is oků Puzzling and annoying.
