Hi all, I have a question.
Would a Brembo 6pot 355mm fit a 18x8 O.Z wheels with offset 48?
What kind of spacers would be needed? Thxx all
Do you already own the wheels? If so I would go to the Brembo website print out the Brake template and with the wheel off place it inside the wheel and see if contact occurs. That is the most reliable way.
What OZ wheel? The are all shaped differently and some may work and some may not.
I do not own the wheels yet, I am looking at the new Formula wheels 18x8.
Very Nice Wheel/Brake combo Rotary Knight.
stoptech should have a cutout that you can use to check the clearance with the caliper. i bet thats what they will probably send you. Should be available on the site though.
Guess Im going to need spacers!The overall dimensions between our Trophy and painted calipers have no significant difference and will use the same templates. If the templates indicate a very tight amount of space between the caliper and wheel spokes, it should be expected that wheel spacers will be required to make adequate room.
Let us know if you have any questions.
Erik
