grambles423
Automotive Engineer
Hey guys,
Back at it again with some discussion. As some of you are aware of from my build thread, ever since I installed the K04 I've had a CEL pop up on random mornings. It seems to happen so random that I cant pinpoint an accurate trend. It seemed to happen every morning when it was REALLY cold, but then this morning it didnt do it. So I'm at a total loss and would like some other brains thinking on this. Here is the original Scan:
I contacted Arin yesterday and got a explanation back about what the code is and what its looking for. I'm a little foggy about how to interpret the secondary parameters and what engages the air flow testing from the secondary pump. Heres what I got:
DTC: P0491
Error Message: Seconday Air System - Insufficient Flow
Diagnostic Procedure: Check the Secondary Air Combination Valve
Malfunction Criteria and Threshold Value: SAI Pressure sensor vs. Modeled pressure < 0.62%
Secondary Parameters:
Frequency of Checks, MIL Illum: 2 DYC
I obtained VAGCOM last Friday and have been playing with it since then. Upon some intense googling, I found I could ACTUALLY log the startup process of the SAI pump and if the test went well or not. (Reference: Group 77 - Air Mass from Sec. Air. Inj. bank 1 %)
I have no clue what is causing it to do a system check or why there is a delay from the start, but the fact that the SAI Pump is not pulling air during that entire system check looks to me like a shit valve. I'll double check the relay and make sure its not fried before I do a vacuum test of the system. But the valve seems to be moving. Seeing that the air mass is -100% before startup, 0 during testing, and -53.9% after it failed lets me know the combination valve is opening and closing, but why is it closed during the testing phase? Is there something in the software from preventing it? I dont want to swap out the valve and not have it work.
I want APR's POV on this as well, maybe Arin can talk to Chris about this, but aside from vacuum testing the system, I'm at a loss. Anyone have a part diagram of the SAI? I'll also check the breather filter attached for any clogs.
I have 3 other logs where the CEL did not come on...these will be posted shortly. EDIT: Seems there is a passive routine for allowing a certain number of checks before a CEL/MIL
1 Fault Found:
001169 - Secondary Air Injection System: Bank 1
P0491 - 000 - Insufficient Flow
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 65873 km
Time Indication: 0
Date: 2000.00.00
Time: 12:37:14
Freeze Frame:
RPM: 1758 /min
Load: 14.1 %
Speed: 0.0 km/h
Temperature: 18.0°C
Temperature: 17.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.970 V
Readiness: 0010 1001
DTC: P0491
- MAF = 7-150 kg/h
- Delta Engine Load = -10% - 10%
- ECT = 5*C - 60*C
- IAT = 5*C - 40*C
- Altitude < 2700
- SAI Pressure Sensor, Ready = No Fault
