Old 02-09-2012, 05:34 PM   #29
Muskie
Formula 2 Champion
Drives: 2011 GMC Terrain
Originally Posted by justin@usrt View Post
Having your nozzle pre throttle body will cause failure to your throttle body as it is made up of electrical components. Placing the nozzle post throttle body using our plate will eliminate any possible chance of failure.
for placement of a second nozzle after the intercooler for more cooling you want to give the spray ample "pipe travel" time for full evaporation before reaching the throttle body.
Can you give any details on nozzle size and controller setup? I'm interested in a dual nozzle setup for both cooling and power. Are there TOP pipes that are pre drilled for nozzles?
2011 GMC Terrain | New Windshield Wipers Mod | Bluetooth Streaming Audio Mod | Weather Tech Floor Liners Mod | 55w 4500k HID lowbeam mod | Road Stripe Paint Mod
Muskie is offline   Reply With Quote
Old 02-10-2012, 12:32 AM   #30
steelcurtain
Drives: '12 Audi TT-RS
You don't want to do that. That will lead to meth pooling in your fmic causing issues over time. The air flow efficiency of your fmic will decrease.
'09 GTI TSI - 11.53@121.18
steelcurtain is offline   Reply With Quote
Old 02-10-2012, 12:38 AM   #31
steelcurtain
http://www.golfmkv.com/forums/showthread.php?t=148047
Old 02-10-2012, 04:09 PM   #32
justin@usrt
Drives: jetta
Send a message via AIM to justin@usrt
For a dual nozzle setup it would consist of a larger nozzle after the intercooler, and a smaller nozzle at the throttle body. Going into the exact sizing is the next step for when you are ready to purchase. Once I have your turbo size, estimated hp, what psi you are running, and fueling I can properly figure you out nozzle sizing with our calculator.
For the controller. If you are on a stock turbo or similar size I would recommend MAF controlled. If you are on a big turbo I would recommend MAP controlled.
For the predrilled nozzle holes on the TOP pipes you need to be careful that you are giving ample time for the spray to evaporate.
www.usrallyteam.com
Justin@usrallyteam.com
follow us on facebook
Unitronic Chipped Authorized Dealer
justin@usrt is offline   Reply With Quote
Old 02-10-2012, 04:11 PM   #33
justin@usrt
Drives: jetta
Originally Posted by ISSAM ABED View Post
How are those wood screws working out for you?
The wood screws are working out just fine. They hold a perfect seal, no leaks, and they are the correct thread pitch. We also have the machined screws as well to ensure fitment on all applications.
Let me know if you have any more questions, or are interested in ordering one.
They are in stock and ready to ship.
www.usrallyteam.com
Old 02-10-2012, 11:33 PM   #34
Trogdor
Trogdor's Avatar
Clint when are you planning on releasing the mount kit? And yes a holder for the reservoir would be awesome as well. I have a snow kit sitting on the table right now, and I have been trying to figure out the best way to mount it.
APR,SouthBend,Eurojet,
AWE,BSH+RANDOM
Burninating the People
Trogdor is offline   Reply With Quote
Old 02-10-2012, 11:36 PM   #35
steelcurtain
Lulz. True professional. Nicely done.
Old 02-12-2012, 12:00 PM   #36
watson
watson's Avatar
Drives: '11 GTI, '11 X3
On your site, you have a kit that looks to be made specifically for the GTI (TSI). How does the stage three kit compare with the one made for the TSI?
the GTI
the X3
the Birds
The Dogs
watson is offline   Reply With Quote
Old 02-14-2012, 01:55 PM   #37
justin@usrt
Drives: jetta
the stage 2 for all kits is one dimensional in control. (MAP or MAF based) The mass air flow is frequency based and not voltage based. Which is why there is a specific FSI/TSI kit.
The stage 3 kit is two dimensional (MAP and injector duty cycle) Boost pressure plus injector duty cycle is how it calculates engine load. It takes the boost pressure and trims the pre programed curve using the injector duty cycle. Always more accurate, and will deliver the correct dosage.
The reputation is built on stage 2. Stage 2 is good enough for 90% of users today. The other 10% want the Stage 3 kit. We recommend the stage 3 kits more for the 6cylinder turbo cars.
www.usrallyteam.com
Old 02-14-2012, 02:18 PM   #38
JoeVDUB
JoeVDUB's Avatar
Drives: Mach 1
I have a devils own kit and just ordered your throttle body spacer, I plan on doing just 1 nozzle at the moment, until I get use to things and know how everything works to a higher extent. What size nozzle should I run? Oh and I'm stage 2, full bolt ons, if that makes any difference.
JoeVDUB is offline   Reply With Quote
Old 02-14-2012, 03:09 PM   #39
justin@usrt
Drives: jetta
Our throttle body spacer plates are not made for Devils own nozzles. They are made to fit Snow Performance nozzles. A simple solution is to plug the hole in our existing plate, and redrill to your correct thread pitch. Any machine shop can handle this for you.
Just based off what your telling me I would recommend a 60cc nozzle. (1-Snow Sizing) I cannot guarantee this is accurate information because I do not deal with Devils Own.
www.usrallyteam.com
Old 02-16-2012, 02:35 PM   #40
zhijjawi10
zhijjawi10's Avatar
Just got the new Eurodyne Boost Manager Plus installed. Not finished tuning, but it's a cool mount location!
Thanks to Ray at R.A.I. Motorsport and Chris at Eurodyne, can't wait for them to really show me what this thing can do. It's a very impressive system with all of it's features.
zhijjawi10 is offline   Reply With Quote
Old 02-16-2012, 03:00 PM   #41
JohnnyDrama
Drives: MK5
JohnnyDrama is offline   Reply With Quote
Old 02-22-2012, 09:44 AM   #42
JoeVDUB
JoeVDUB's Avatar
Drives: Mach 1
Just an update: I received the throttle body spacer, looks like a real quality piece. It also works with the Devils Own nozzles so if anyone has a DO kit, you can still use this product. Can't wait to install it now.
dubpl8 w/m his anus
