Old 02-11-2012, 06:35 PM   #15
zVp
zVp's Avatar
Drives: 2012 Black GTI (DSG)
Originally Posted by danielj View Post
Your car is optioned exactly how I wanted mine (colour too and we had ala cart options back in 2010)
Very nice and glad to see your making it your own.
Thanks! What made you get Shadow Blue? (Not knocking on Shadow Blue, I do love that colour, but we Canadians don't get that colour, eh?)
2012 DEEP BLACK PEARL GTI
zVp's Car Journal
Old 02-11-2012, 06:39 PM   #16
danielj
danielj's Avatar
Drives: 2013 BMW x135
I bought in late MY2010 so pickings were slim. SB was a late in the MY option so at the time, a rare colour. It had the autobahn package and looked so darn good I went for it. I still wish it were black today and will for sure get black the next time.
Old 02-11-2012, 06:49 PM   #17
zVp
zVp's Avatar
Staging
How-To
WARNING: I will not be held liable if anything occurs when attempting to change anything in the VCDS software. These instructions are created to the best of my knowledge and are as accurate as I can make them. Please be careful before you save your settings and always run Auto-Scan before any changes are attempted.
NOTE: This will not work for all clusters; newer model year cars will not guarantee this working as well as some members attempting this failed to get this working (even in MY2012 GTIs).
Load up VCDS, click on the Select button under Select Control Module
Click on the 17-Instruments button
Click on the Adaptation - 10 button
This window will pop up -expand the drop-down menu.
Click on the drop-down menu and select Staging
Select Active on the drop-down menu under New Value. Press Do It and the settings should save. Close the program, remove cable and remove key from the car. Get out of the car and lock. Unlock and get back into the car and start up the car to see if the staging works.
NOTE: When opening the Staging menu, if active is not shown in the Stored Value box, chances are this will not work with your cluster. If I remember correctly, it will say something like Channel: Not valid or Not Active or something along the lines.
zVp's Car Journal
Old 02-11-2012, 06:52 PM   #18
zVp
zVp's Avatar
Does it rain a lot in Seattle? if so, black isn't a great colour to get :P My car turns to Dusty/Dirty Carbon Steel Grey after a few days after washing
But it does look great when its nice and clean
zVp's Car Journal
Old 02-11-2012, 07:35 PM   #19
zVp
zVp's Avatar
Boo! Imgur messed up all my pictures!
zVp's Car Journal
Old 02-11-2012, 07:44 PM   #20
danielj
danielj's Avatar
It rains often in Seattle but i had managed well for the past 13 years with having a black car. SB might as well be black given it shows the dirt just as easily.
But enough about me and my wants lol.
Old 02-11-2012, 08:14 PM   #21
zVp
zVp's Avatar
Emergency Brake Flashing via Brake Lights/Turn Signals Active
How-To
Click on the 09-Cent. Elect. button
Click on the Coding - 07 button
Click on the Long Code Helper button
Go to Byte 16 and check mark Bit 1 - Emergency Brake Flashing via Brake Lights Active
Also, check mark Bit 2 - Emergency Brake Flashing via Turn Signals Active if preferred as well
zVp's Car Journal
Old 02-11-2012, 08:17 PM   #22
zVp
zVp's Avatar
Automatic Rear Window Wiping with Reverse Gear Disabled
How-To
Go to Byte 21 and uncheck mark Bit 6 - Automatic Rear Window Wiping with Reverse Gear Active to deactivate this option
zVp's Car Journal
Old 02-11-2012, 08:23 PM   #23
zVp
zVp's Avatar
DRL MFA Menu
How-To
WARNING: Please follow your state's, province's and/or country's regulations on DRLs. I do not condone disabling DRLs if the law states you must have them at all times on your vehicle.
Go to Byte 15 and check Bit 7 - Daytime Running Lights (DRLs) Adaptation active (MFA+)
You can now turn on/off your DRLs on the fly with the menu in the MFA. It should be under Lights/Vision sub-menu. Checkmarked means your DRLs are active; unmarked means your DRLs are inactive.
Please note, you cannot change this while the car is moving - please do not attempt to turn on/off DRLs while operating a moving vehicle.
zVp's Car Journal
Old 02-11-2012, 08:33 PM   #24
zVp
zVp's Avatar
Horn Confirmation when Locking MFA Menu
Thanks to veedoubleme at http://www.golfmk6.com/forums/showpo...16&postcount=9
How-To
Go to Byte 5 and uncheck Bit 2 - Horn Confirmation Adaptation Blocked (Adaptation Channel 010/011 & MFA+/FIS)
You can now turn on/off your horn confirmation when locking on the fly with the menu in the MFA. It should be under the Convenience sub-menu.
Checkmarked means your horn will beep when locking the doors; unmarked means your horn will not beep when locking the doors.
zVp's Car Journal
Old 02-11-2012, 08:37 PM   #25
zVp
zVp's Avatar
Fog Lights active with High Beams active
How-To
WARNING: Please follow your state's, province's and/or country's regulations on the maximum number of lights can be active at one time.
Go to Byte 14 and uncheck Bit 2 - Fog Lights inactive with High Beams active
Now you can use your high beams and fogs at the same time.
zVp's Car Journal
Old 02-11-2012, 08:45 PM   #26
zVp
zVp's Avatar
Comfort Closing/Opening via Remote Control
How-To
Go to Byte 3 and check Bit 5 - Comfort Operation via Remote Control Active
Checking Bit 0 - Comfort Opening for Sliding Roof Active will also open the moonroof while opening the windows via the remote fob. I did not activate this setting.
NOTE: This may not work. Apparently some update from the dealer that deals with the fan running after the car is shut off affects this coding. See http://forums.vwvortex.com/showthrea...control-on-Mk6 for more information.
Press and HOLD the lock button on your fob to close all the windows. HOLD until all windows are closed or until preferred height.
Press and HOLD the unlock button on your fob to open all the windows. HOLD until all windows are open or until preferred height.
zVp's Car Journal
Old 02-11-2012, 08:52 PM   #27
zVp
zVp's Avatar
Comfort Turning Signal
How-To
On the drop-down menu, select Comfort Turn Signals (Cycles)
Change to your preferred number of cycles/blinks (3 is default) using the Up and Dn buttons
Save your changes.
Depending on the model and/or year of your car, this will not work right away.
Go to your MFA menus, enter the LIGHTS/VISION menu and restore settings to factory. Attempt to use the comfort turn signal.
zVp's Car Journal
Old 02-11-2012, 09:03 PM   #28
zVp
zVp's Avatar
Steering Wheel Push-To-Talk Button
If you have a newer steering wheel with a Push-To-Talk (PTT) button on the bottom left of your steering wheel, you can change it to act as a mute button.
How-To
Click on the 19-Steering Wheel button
Click on the Long Coding Helper button
Go to Byte 1 and uncheck Bit 3 - Multi-Function-Steering-Wheel (MFSW) with Push-To-Talk (PPT) Button installed
The Push-To-Talk (PPT) button will now act as a mute button.
zVp's Car Journal
zvp
