Old 01-11-2017, 10:38 AM   #309
zVp
zVp's Avatar
Drives: 2012 Black GTI (DSG)
Did you increase your phone's volume settings?
Originally Posted by mostic View Post
Hi Man
I have a problem with the Telephone, everything is working perfect except that I hear the voice of callers low -but it is clear- even when I increase the volume to the maximum I still hear them a bit low.
Do you have any code or settings that can help.
Thx
Here are the details:
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 L HW: 1T0 035 680 C
Component: RNS-MID H41 5269
Revision: AB001001 Serial number: VWZ6Z7K5238074
Coding: 04050402040000900000
Shop #: WSC 01357 011 00200
VCID: 373EEB9A86A907FA4D-8062
Subsystem 1 - Part No: 7L6 919 859 G
Component: AUNZ V7 8035
No fault code found.
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 J HW: 7P6 035 730 J
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007662981511
Coding: 0210000000010110
Shop #: WSC 00015 115 12345
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 393AEDA2B8BD118ABB-806C
2012 DEEP BLACK PEARL GTI
zVp's Car Journal
Old 01-11-2017, 10:45 AM   #310
mostic
mostic's Avatar
Drives: VW
If you mean the phone volume from the phone itself then the answer is yes.
Old 01-12-2017, 12:41 PM   #311
zVp
zVp's Avatar
Sorry man, I'm not sure of any settings that can make the volume higher.
Is it just your phone? Does your media player on your phone work at higher volumes?
zVp's Car Journal
Old 01-12-2017, 12:55 PM   #312
mostic
mostic's Avatar
Drives: VW
Yeah, the media player volume is very high. I think it could be something related to sensitivity.
I tried several phones and it's the same!
Old 01-12-2017, 06:26 PM   #313
mostic
mostic's Avatar
Drives: VW
I found this options but I don't know how it could be useful!
I don't know if 0db is good or maybe I need to increase or decrease the value!
Thx
Old 01-31-2017, 07:40 PM   #314
50Fathom
Drives: 2013 Golf R
All Lights Shut Off When Turning Off Vehicle
Thanks to Tim S for these instructions
How-To
WARNING: I will not be held liable if anything occurs when attempting to change anything in the VCDS software. These instructions are created to the best of my knowledge and are as accurate as I can make them. Please be careful before you save your settings and always run Auto-Scan before any changes are attempted.
Load up VCDS, click on the Select button under Select Control Module
Click on the 09-Cent. Elect. button
Click on the Coding - 07 button
Click on the Long Code Helper button
Click on Byte 15 and check mark Bit 5 - Parking Lights OFF with Terminal S OFF and Light Switch at Low Beam
All lights should be off when the key is out of the ignition, even if you have your light switch to the far right (everything on). The default setting would leave parking lights (front and back) on after taking key out of the ignition.
I guess this would save your battery in case you forgot to turn the light switch to off, but I am not 100% sure about this.
Tried this on my '13 MK6 Golf R with KESSY, and it doesn't work. Lights stay on when the ignition is turned off.
Any other tweaks to make it work?
50Fathom is offline   Reply With Quote
Old 06-13-2017, 11:56 AM   #315
Renck
Renck's Avatar
Drives: 2013 GTI Autobahn + 2017 GTI SE
ZvP - thanks for this thread!
I just purchased a 2013 GTI and added LED tail lights. Do you know if there is a code to enable inner lights at the tail lights when brakes are applied? If yes, could you please share it?
I did search it already, but I wasn't able to find anything yet.
Renck is offline   Reply With Quote
Old 06-13-2017, 03:23 PM   #316
zVp
zVp's Avatar
I don't think so - there's some coding for MK7s, but I don't think there is any for MK6s that anyone has found.
Plus, it's done that way for safety reasons, I believe. If they all light up, someone can think that it's just your regular night-time lights, but if you see some sort of differentiation between the two, you'll know automatically it is the brake lights.
zVp's Car Journal
Old 06-13-2017, 03:30 PM   #317
Renck
Renck's Avatar
Gotcha! Thanks for replying back to my post.
Old 10-18-2017, 09:59 PM   #318
KFahey
KFahey's Avatar
Drives: 2011 MK6 GTI-MT
Just got an OBDeleven dongle for my car to do some coding....my shop attempted to code my DRLs off on my halogen headlight, but now they come on when the headlights are turned on and they are off when the lights are turned off. Can anyone help me with this please? I wanted them off always but still want my highbeams to work obviously. Thanks!
Sent from my SM-G935V using Tapatalk
APR K04 V3.1 | Unitronic CAI | CTS TBE | NewSouth Boost Gauge | R8 Coils | RSR Clutch Kit | OEM LED Tails | VWR Springs | KONI Yellow Front Struts | GFB DV+ | CTS Intercooler | 034 Street Mounts
KFahey is offline   Reply With Quote
zvp
