Old 02-12-2012, 01:29 AM   #29
boostedmk6
boostedmk6's Avatar
Originally Posted by zVp View Post
Lol, thanks!
Hmm. I was looking at some t8 fixtures, but I'm a novice at electrical work. Might see if I can get some DIYs and try it out, but maybe I'll start with halogen lights first. I'm just afraid of the heat generated by them
And LOLs at the LED tails comment. You should grab the reps for your car. Like I said before, I'll come over some day (when it's nicer outside) and we can swap the tails into your car to see if you like 'em!
You can get plug in units as well.
Sounds good though... Cant wait for spring!
GTI DSG | APR K04
GTA Detailing & Paint Correction
boostedmk6 is offline   Reply With Quote
Old 02-14-2012, 12:01 PM   #30
Super Steve
Super Steve's Avatar
Drives: 5dr MKVI GTI
wow thank you work you put into making the helpful vagcom walkthroughs
Super Steve is offline   Reply With Quote
Old 02-14-2012, 11:52 PM   #31
zVp
zVp's Avatar
Drives: 2012 Black GTI (DSG)
Thank you, I just hope it helps people
2012 DEEP BLACK PEARL GTI
zVp's Car Journal
Old 02-15-2012, 12:11 AM   #32
MBorVW
MBorVW's Avatar
Drives: 2015 VW GTI 4dr SE DSG
Awesome thread! All things vagcom in one place with easy instructions! This helps me a ton.
Also: 2012 Tiguan LE 2wd
MBorVW is offline   Reply With Quote
Old 02-16-2012, 10:59 AM   #33
zVp
zVp's Avatar
Warning Triangle & First Aid Kit
Thanks to Tim_S at http://forums.vwvortex.com/showthrea...rning-Triangle
Parts Required
N 105 412 01 - White Plug
N 906 513 04 - Black Screw
1K6 860 266 D 9B9 - Strap/Bracket
000 093 057 - CORRECT Warning Triangle (Do not use 1Y0 093 055 as it is too narrow to fit); You can also use 8D9 860 251B (EOS Warning Triangle) as a replacement. They are both the same size, I believe.
Now, its up to you which first aid kit you want to use.
000 093 114 - Blue First Aid Kit (Correct one for Gofl/GTI)
3C0 093 108 - Red First Aid Kit (Passat kit for rear seat armrest)
They will both fit; I got the red one myself since I prefer the colour.
Instructions
Open your trunk and look on the left side. There will be a black plug; you will have to get this out.
IMPORTANT: Pull back your carpet and insert the white plug into the hole in the side of the trunk. Put back the carpet. If you put the white plug over the carpet, it will move around and not be sturdy. Putting it behind the carpet solves the problem.
Screw the bracket into the white plug in the correct orientation.
Put your warning triangle in and then strap in the first aid kit.
WILL POST PICTURES LATER
zVp's Car Journal
Old 02-16-2012, 10:32 PM   #34
zVp
zVp's Avatar
Driver Seat Heating Memory Retention
How-To
WARNING: I will not be held liable if anything occurs when attempting to change anything in the VCDS software. These instructions are created to the best of my knowledge and are as accurate as I can make them. Please be careful before you save your settings and always run Auto-Scan before any changes are attempted.
Load up VCDS, click on the Select button under Select Control Module
Click on the 08-Auto HVAC button
Click on the Adaptation - 10 button
This window will pop up - expand the drop-down menu.
In the drop-down menu, select Retention of driver's seat heater level
Select On and save your settings.
When turning back your car after leaving your heated seat on, it will retain that setting.
zVp's Car Journal
Old 02-19-2012, 11:54 AM   #35
zVp
zVp's Avatar
Just messing with my dad's video function of his Sony NEX-5. Nice little mirrorless DSLR. So much easier to lug that thing around than a small Canon 400D.
zVp's Car Journal
Old 02-19-2012, 06:13 PM   #36
zVp
zVp's Avatar
Finally finished installing the Aspherical Mirrors from the group buy http://www.golfmk6.com/forums/showthread.php?t=28838. Thanks quickit!
Used a butter knife wrapped in a microfibre cloth and pryed open the mirror. Unfortunately, the passenger side mirror cracked when I tried to get that open, but the driver side was a lot more forgiving.
Used a flat-head screwdriver to slowly remove the leads for the heated mirrors and just popped back the mirrors into the housing.
Pretty easy, except for the cracking mirror
I didn't really pay attention before but, is it just me or is the passenger side mirror more recessed into the housing than the driver side?
zVp's Car Journal
Old 02-20-2012, 12:48 PM   #37
zVp
zVp's Avatar
Mirror Adjust Menu in MFA
For 2011s and up. Apparently 2010s will have this menu.
How-To
Click on the 09-Cent. Elect. button
Click on the Coding - 07 button
Click on the Long Code Helper button
Go to Byte 8 and check Bit 6 - Synchronized Mirror Adjustment
You will now have Mirror Adjust in your Convenience sub-menu. If you continue deeper into the menus, you will see Both and Individual, referring to adjusting your side mirrors simultaneously or one at a time depending on which side mirror you select.
zVp's Car Journal
Old 02-20-2012, 01:03 PM   #38
zVp
zVp's Avatar
Coming/Leaving Home Menu in MFA
How-To
Go to Byte 12 and check Bit 2 - Coming-Home Mode (0 = Automatic / 1 = Manual)
Go to Byte 17 and check Bit 5 - Coming-Home (CH) Active and Bit 6 - Leaving-Home (CH) Active
You will have the Coming Home and Leaving Home menu in your MFA. If you go deeper into the menus, you can set the interval in +/- 10 sec to your preference.
zVp's Car Journal
Old 02-21-2012, 11:27 PM   #39
zVp
zVp's Avatar
Not really pictures of the GTI or anything, but I did do some car related things today. Went to the Canadian International Autoshow!
Saw a bunch of cool cars, but it was really busy today. Not really a good day to take good pictures I got fed up of people walking in front of cars as I'm trying to get pictures of. So instead of trying to get a full shot of a car, tried to do something more "artistic" of some sort. Of course, they did pay for entrance as well so they have all the right to do what they please when they come here, but c'mon. You see a guy trying to take a photo of a car, don't just walk in front of them!
Also got picked to test drive some Mercedes Benz vehicles around a little course at Ontario Place. It was a really small course, but it was a nice little experience. Unfortunately, not AMG vehicles though!
E-Class - Sweet car, nice power, but ABSOLUTELY HATE the shifter. It's like a Mini-Van shifter.
Smart ForTwo - Funny little car to drive around. The brakes were shot on that car though.
GLK - Great little SUV. I actually really liked it. Unfortunately, I got stuck behind the shuttlebus taking some people around for a little "test" drive around the course so I couldn't really push it too hard.
C-Class - What a disappointment. Slow and just... well, slow. Did not like at all.
Lexus LFA
Mazda Shinari Concept (SHARP LOOKING CAR)
BMW Vision Connected Concept
Acura NSX Concept
zVp's Car Journal
Old 03-11-2012, 08:26 PM   #40
zVp
zVp's Avatar
Hill Hold Control (HHC)
How-To
Click on the 03-ABS Brakes button
Click on the drop-down menu and select Hill Hold Control (HHC)
Change Hill Hold Control (HHC) to your preference.
NOTE: If you have disabled Hill Hold Control (HHC), you will not be able to enter these menus.
zVp's Car Journal
Old 03-16-2012, 07:33 PM   #41
zVp
zVp's Avatar
Can't wait to put these on!
zVp's Car Journal
Old 03-16-2012, 07:50 PM   #42
Lodi
Lodi's Avatar
Drives: 2012 2dr CSG Gti w/DSG
I'm starting to get bored with my stock Denvers too. Nice pick-up
*APR stg2+ /// R8 coils /// NGK irid's /// K&N Typhoon Intake /// Ultimate Racing DP /// Borla CB /// A-Spec TOP & TBP /// Eibach Sportlines /// UniBrace XB - UB - RB /// 17" R133's w/Nitto Invo's /// oem R LED tails /// + various cosmetic & audio*
Lodi is offline   Reply With Quote
zvp
