Old 09-03-2012, 08:43 PM   #43
GTIProject
GTIProject's Avatar
VW/Audi have actually issued a new updated drain plug (using a 10mm alum crush washer) to replace both the 18mm plugs and the 6mm hex plugs. Techs have been having issues with removing the 18mm plugs, and having the brand new 19mm plugs leaking after being torqued to spec. Newer pans designed for the 6mm hex were built with the 18mm bolt installed and the washer +paint sealed the oil. As soon as the bolt was unscrewed, the seal with lost and it would leak oil.
Basically if you crack the drain bolt loose and it leaks oil immediately, replace with the updated T45 torx bolt + crush washer. Most VW/Audi dealers stock it and know what it is. I'll try and post a picture and a PN tomorrow.
2011 GTI Tornado Red. Protection Package | Rota Torques | Goodyear Eagle F1 | Clear Bra | BSH TMI | APR Carbonio Stage 1 | APR Stage 2 | S3 SS | SPM DP/UR 3" CBE | R Tails | Tyrolsport Brake Bushings | Stoptech Pads | SB Stage 3 Drop-In | ECS Bleeder Block |
GTIProject is offline   Reply With Quote
Old 09-03-2012, 08:55 PM   #44
plac
Guest
Posts: n/a
good info.
Old 09-03-2012, 09:01 PM   #45
dbizzle22
Drives: GTI
Great info! Please try and get the part # at least so I can take it to the dealer parts desk. I don't want them selling me the wrong parts and wasting an extra trip.
How re-usable are these new bolt/crush washer combos? Replace each time or few times?
Old 09-03-2012, 09:03 PM   #46
plac
Guest
Posts: n/a
my drain plug has always dribbled the second i knocked it loose. but that was my normal 18mm one. only just installed my hex, so next oil change ill see if it dribbles. if it does, i'll have the torx one in my hand to replace it. or.. a fumoto and be done messing with it for good.
Old 09-03-2012, 09:04 PM   #47
dbizzle22
Drives: GTI
Plac - never went the ECS magnetic plug + copper washer route?
Old 09-03-2012, 09:10 PM   #48
plac
Guest
Posts: n/a
not that huge a deal for me. mine never really leaked. until like my 3rd oil change, then i got a new oil pan. i probably didnt need to now that all this info is out.. a proper plug that didn't dribble would have probably fixed it.
Old 09-04-2012, 07:25 AM   #49
rs999
rs999's Avatar
Have you guys tried supplementing the crush washer with a paper or rubber gasket?
Old 09-04-2012, 09:56 AM   #50
mk6cruzen
mk6cruzen's Avatar
Drives: 2012 CW 2-Door DSG Sunroof/Conv.
Good info. I checked my hex allen last night and it was dry. I will check it again tonight. Regardless, next oil change I will replace it. Let us know the PN on the new torx bolt if you can. Thanks again.
...Sent from my phone with typos...
* Llumar Ceramic tint/DG DSG Springs/APR Stg 2 (Oct.12th!)/Modshack/Soundakator delete/Passport & Blendmount/Mojo mats/SPM Street Downpipe/Drawtite hitch/red LED footwells/Tetrax Xway/Escort Live & micro usb hardwires/Seat Inserts/Thule roof rack/H&R 10mm & 15mm spacers/S2T paddles *
mk6cruzen is offline   Reply With Quote
Old 09-04-2012, 09:03 PM   #51
GTIProject
GTIProject's Avatar
Actually bought a torx bolt and washer today at work, have the invoice at work as well. Will take some pictures.
Old 09-05-2012, 05:42 PM   #52
GTIProject
GTIProject's Avatar
UPDATE: Torx plug is PN N91 167 901, crush washer is a standard VW/Audi aluminum round washer. Pictures comming, they are on my phone and need to upload them first.
Old 09-05-2012, 05:52 PM   #53
plac
Guest
Posts: n/a
only $1.71 at my online dealer. but shippings prob $10. maybe a local dealer has it..
Old 09-05-2012, 08:04 PM   #54
GTIProject
GTIProject's Avatar
Aforementioned pictures;
Old 09-05-2012, 08:13 PM   #55
plac
Guest
Posts: n/a
i dunno.. my hex plug seems fine. can't see how its much different from the torx one. i guess i'll find out next time i change the oil and check for dribble.
Old 09-06-2012, 11:05 AM   #56
Linnie8
Drives: W
Linnie8 is offline   Reply With Quote
allen key, hex key, oil, oil drain plug, oil plug
