Old 09-06-2012, 11:57 AM   #57
dbizzle22
Drives: GTI
Originally Posted by Linnie8 View Post
only $1.71 at my online dealer.
... but how much is shipping? I'll probably run to the local dealer and just pick one up.
Any idea how reusable the torx plugs are? Plug lasts X oil changes and just replace the washer type deal?
Old 09-06-2012, 07:36 PM   #58
GTIProject
GTIProject's Avatar
Yeah, don't know why they changed the drive type, but techline tells us its a different type of metal than the older hex-head ones to prevent galling of the threads, and its not painted.
2011 GTI Tornado Red. Protection Package | Rota Torques | Goodyear Eagle F1 | Clear Bra | BSH TMI | APR Carbonio Stage 1 | APR Stage 2 | S3 SS | SPM DP/UR 3" CBE | R Tails | Tyrolsport Brake Bushings | Stoptech Pads | SB Stage 3 Drop-In | ECS Bleeder Block |
GTIProject is offline   Reply With Quote
Old 09-06-2012, 09:32 PM   #59
dbizzle22
Drives: GTI
Just got off the phone with my local dealer to check on stock of the torx plug. Got that in stock but the tech said that per the computer, the plug just installs on its own without any type of washer on a 2012 GTI.
Did your tech see something different on his computer that would show the need for the washer? If so, can you give me the part # for that too?
Thanks!
Old 09-08-2012, 03:12 PM   #60
GTIProject
GTIProject's Avatar
The plug seals with a washer. Don't know the part number off hand, but its a round crush washer, but the washer itself is round in circumference, rather than flat. Audi dealers have them for all 3.2/4.2/3.0T motors.
You need to use a washer with it.
Old 09-10-2012, 10:05 PM   #61
barische
barische's Avatar
Drives: GTI mk6
I changed the oil today, had to re-use the hex plug back on. I was thinking the washer on the original 19mm that i took from past oil change would come off but would not make it past the threads.
I put a copper washer on the hex plug and torqued it down. Filled it up with oil. Drove about 50 miles checked it three times no leaks yet. knock on wood.
I just ordered the 19mm original drain bolt and Magnetic plug from ECS which will install soon to be on the safe side. hex plug has about half threads of original 19mm. seems like i was able to get a good crush on the copper so its not leaking.
Old 09-11-2012, 07:59 AM   #62
plac
Guest
Posts: n/a
the hex plug is the proper size. the long 19mm bolt is way too long. its not supposed to go in half an inch past the threads..
Old 09-12-2012, 12:54 PM   #63
barische
barische's Avatar
Drives: GTI mk6
Cool thanks.. Will keep it in mind
Old 09-20-2012, 07:58 AM   #64
GTIwannagofast
GTIwannagofast's Avatar
Drives: 2010 VW GTI
VW/Audi have actually issued a new updated drain plug (using a 10mm alum crush washer) to replace both the 18mm plugs and the 6mm hex plugs. Techs have been having issues with removing the 18mm plugs, and having the brand new 19mm plugs leaking after being torqued to spec. Newer pans designed for the 6mm hex were built with the 18mm bolt installed and the washer +paint sealed the oil. As soon as the bolt was unscrewed, the seal with lost and it would leak oil.
Basically if you crack the drain bolt loose and it leaks oil immediately, replace with the updated T45 torx bolt + crush washer. Most VW/Audi dealers stock it and know what it is. I'll try and post a picture and a PN tomorrow.
i recently did an oil change... removed the original black 18mm hex head bolt, and replaced it with the 19mm hex head bolt from VW. when i removed the 18mm bolt, as soon as it was cracked loose, oil started coming out. now this 19mm hex head (with the washer attached) as a small dribble coming from it. has it been confirmed that this 6mm hex key plug or the T45 plug with the round washers are sealing this type of leak?? anyone else experience this, and have another suggestion for fixing it??
STAGE
GTIwannagofast is offline   Reply With Quote
Old 09-20-2012, 05:08 PM   #65
GTIProject
GTIProject's Avatar
Check out my posts on the matter. The original 18mm hex plugs will seal when brand new due to the thick e-coating from the supplier. Once cracked loose the new style pans require the hex/torx plug with the round aluminum crush washer to seal it. The 19mm hex will leak since the washer does not seal on the head of the bolt and oil gets past the threads.
Old 10-22-2012, 02:26 PM   #66
siliconcenturion
Drives: 1999 Miata, 2004 Miata
Sorry for the bump.
GTIProject, did you ever get the P/N for the crush washer?
Also, does the torque change? (I have it written down as 22 ft lb / 30 Nm)
Thanks
siliconcenturion is offline   Reply With Quote
Old 05-01-2013, 01:02 PM   #67
boostedmk6
boostedmk6's Avatar
Just a quick question:
I went to pick up a new crush washer for my original 18mm (standard socket) drain plug at the dealer and they only had the new 19mm (standard socket) plug with aluminum washer already installed (that doesn't come off).
Am I going to have any leaks?
GTI DSG | APR K04
GTA Detailing & Paint Correction
boostedmk6 is offline   Reply With Quote
Old 05-01-2013, 02:55 PM   #68
lon888
Drives: 2012 GTI Carbon Steel Gray 4-door
Went to the dealership a few days ago to get my 30,000 mile oil change and check-up. Apparently they sucked the oil out of my car because the parts list did not show a new drain plug or washer. I'm glad I'll do all of my oil changes after this - I don't like the idea of dirty oil being sucked out rather than draining out.
Valentine 1 / OEM Short Shifter / Euro Dash Cubbie / Euro Seat Cubbie / ECS Torque Arm Insert / Tyrol sport caliper kit / Euro light switch / Dummy button garage door opener / Auto dimming mirror / Stainless Brake Lines / BFI 25mm rear sway bar / euro front and rear cupholders / 42dd Shifter bushings
lon888 is offline   Reply With Quote
Old 06-11-2013, 01:37 PM   #69
Nitron
Nitron's Avatar
Drives: 2012 GTI DSG Autobahn
My 2012 came with the 6mm hex key plug. I tried swapping it out with ECS magnet plug/washer this weekend. Soon afterwards I noticed a dripping leak, even tightening to 22 ft lbs. I put the hex key plug back in without a washer and the leaking stopped. If the hex key plug continues to work, I'll just keep using that.
Nitron is offline   Reply With Quote
Old 06-12-2013, 11:44 AM   #70
climhazzard
Drives: MKVI GTI
Well, sure enough out of paranoia I look under my car this morning and my drain plug has a very slow drip. I have a '12 GTI that originally had the Hex Key plug and I replaced it with the standard 19mm during the first oil change. I've done a few oil changes since and never had a leak up until now (around 11k miles), so maybe it isn't always immediate. The other variable is that typically my friend changes the oil and we use a new bolt each time, but the last change was done during the 10k mile service by the dealership. There was no drain plug listed on my invoice, so I'm guessing they just reused the one that was already on there. Luckily it was a very slow drip and didn't have any sort of noticeable effect on oil level (I typically check once a week).
I brought the car into the dealership this morning as I didn't want to keep driving around with it leaking, just in case it somehow worsened. Unfortunately the dealership didn't have the new Torx plug in stock that GTIProject mentioned, so they cut the old steel washer off the existing plug and used a round aluminum type (N-013-815-7), which seems to have sealed properly. After a quick Google, this part # looks like the aluminum washer GTIProject said should be used with the Torx plug.
GTIProject, would you be able to confirm this is the correct part number? Some of the other members in the thread had asked for it so I hope this helps.
climhazzard is offline   Reply With Quote
allen key, hex key, oil, oil drain plug, oil plug
