Old 02-05-2015, 08:41 PM   #85
Velociraptor Thrust
Velociraptor Thrust's Avatar
Drives: MK6 & G35
Is the 18mm bolt a stretch bolt? I just changed my oil, and I'm now leaking a little bit.
Velociraptor Thrust is offline   Reply With Quote
Old 02-05-2015, 08:51 PM   #86
Desert MVIGTI
Drives: 2012 United Gray 4D 6M GTI
Did you use a new washer?
I should be able to roll coal all day long, this isn't fucking France.
Desert MVIGTI is offline   Reply With Quote
Old 02-05-2015, 08:59 PM   #87
Velociraptor Thrust
Drives: MK6 & G35
Alas, I did not. Didnt realize it was a crush washer. Head to Home Depot?
Old 02-05-2015, 09:00 PM   #88
Maybe autozone or advance.
Old 09-25-2017, 11:43 PM   #89
gavinfla
Hi all, i was trying find the size Torx bit today myself and couldn't an answere. thats how i found this forum. The torx bit size is T45 for my 2012 GTI, torque spec on oil plug is 30 Nm or 22 ft-lb don't forget the .84 cent washer. siphoning oil Is for boat engines 😊 Plus it makes for a dirty oil pan.
I thing someone was asking the torque spec on the wheel lugs, 120Nm or 88.5 ft-lb
gavinfla is offline   Reply With Quote
allen key, hex key, oil, oil drain plug, oil plug
