Old 03-07-2012, 03:03 PM   #1
Teddy Redskinz
Drives: 2012 UG GTI
Solved: Front Driver's Turn Signal Always ON
Background:
Bought a set of ED's Headlights (HID Projectors) due to great reviews. Picked up a H7 35W Morimoto d2h kit with canbus for the lighting. There was no splicing as everything is plug and play. No additional mods have been made to the car.
Problem:
The Front Driver's Side Turn Signal is stuck on. It will not turn off unless Driver's side harness is disconnected from the connector on the headlamp assembly.
The problem seems to be coming from the car's wiring harness to the connector.
Symptoms:
Tested the wiring harness and there is constant power from battery/Cecm for the driver's side. The passenger side headlight harness does not have constant power which makes sense as the front passenger turn signal is fine. All turn signals are operating correctly with the exception of the front driver's turn signal.
DRL's have not been turned off as I have not been able to find someone with a VagCom. DRL warning on the MFD and check front light bulb.
Plea for Help:
Trying to resolve this without having to take the car into the dealership since they will most likely deny the warranty claim due to the aftermarket headlights. Alternative is to put everything back to stock which is a PITA.
Solution
Replace the CECM.
If warranty will not cover it then you will have to come out of pocket to replace the unit. PN is 5k0937087 and has a MSRP of $260 but can be found for $200 from VW OEM Online Part Dealers.
A few people contacted me with the same problem and most at some point had put in aftermarket lights in their cars. Ed's Lights, Spyders, HID Fogs...it was all over the place so a general warning is in place about tinkering with the lights.
Teddy Redskinz is offline   Reply With Quote
Old 03-07-2012, 03:22 PM   #2
Heartagram131
Heartagram131's Avatar
Drives: Golf Sportline UG
When you plug in your stock housing the problem is still there yeah?
Paul | 2011 MK6 Golf Sportline United Grey | Air-Lift Performance w/ V2
Heartagram131 is offline   Reply With Quote
Old 03-07-2012, 03:26 PM   #3
xHeartcoreboyx
xHeartcoreboyx's Avatar
Drives: '10 CW 2DR GTI DSG
Did you check the fuse in the engine bay?
I had something very similar, it was the fuse.
SOLD -> MK7 R
Old 03-07-2012, 04:13 PM   #4
Teddy Redskinz
Drives: 2012 UG GTI
There is not enough clearance to plug in the stock housing without removing the bumper (harness is very short). I will proceed to this step if I cannot resolve it another way.
I will check on this tonight and see if works.
Ed got in contact with me and said it may be the bulb. I will put in the ones from my stock housing tonight and see if that resolves the matter.
Old 03-08-2012, 11:17 AM   #5
Teddy Redskinz
Drives: 2012 UG GTI
Swapped out the bulb and the fuse but it did not solve the problem. Front turn signal is still stuck on.
Old 03-08-2012, 07:10 PM   #6
nik
nik's Avatar
Drives: '12 CSG 6spd GTI 4DR
I don't really know the specs on the Ed lights, but when I swapped out the front indicators for the Ebay error free LED indicators (someone on the tex has them too), the left one stuck on for me too, but it was very dim light. The vendor indicated that its just the circuits discharging and it should be gone in a while. I removed the light because I didn't want a dead battery in the morning, and replaced it on the way to work the next day. It didn't light up the secnod time and was fine since.
2012 CSG GTI 6 spd - /// Dynaudio / Sunroof/ BBS RS861's/ neutered soundaktor/ custom mount bright a** LED trunk light/ Door warning lights/ USP Delrin shifter bushings/ S3 SS/ LED Tails
Need VAG-COM in the GTA? Shoot me a PM!
nik is offline   Reply With Quote
Old 03-08-2012, 10:30 PM   #7
phd-12v
phd-12v's Avatar
Drives: 2010 MK6 Gti
halogen bulb in turn signal, not LED
Jason---TECH SUPPORT GURU
2010 Gti w/DSG
2012 Jetta Se 2.5
phd-12v is offline   Reply With Quote
Old 03-08-2012, 10:33 PM   #8
steby
Drives: 2010 Mk6 GTI, 6spd
I have the same problem! Front driver side signal is stuck on. I just swapped both front signal bulbs out for new ones but that one is still lighted up.
2010 UG GTI, no vag coding done and euro switch w/o repair wire. My only mod so far is ed's headlight + euro switch.
No idea what to do next... So I took off that lighted bulb. Hopefully my side mirror signal is sufficient for now :/
APR Stage //+
I haz VAGCOM Cable
steby is offline   Reply With Quote
Old 03-09-2012, 01:07 AM   #9
phd-12v
phd-12v's Avatar
what euro switch do you have??? and Teddy do you have a Euro Switch?
2010 Gti w/DSG
2012 Jetta Se 2.5
Old 03-09-2012, 03:05 AM   #10
steby
The one Ed sells: chrome trim, 4 positions. Off, auto, parking, low beam? Not too sure what the symbols are.
APR Stage //+
I haz VAGCOM Cable
Old 03-09-2012, 10:30 AM   #11
Teddy Redskinz
Drives: 2012 UG GTI
No Euro switch.
Old 03-18-2012, 11:34 AM   #12
Teddy Redskinz
Drives: 2012 UG GTI
OP updated with solution.
Old 04-16-2012, 04:32 PM   #13
GTIJosh
GTIJosh's Avatar
Drives: MK6 GTI 6MT
I have this issue too. I am guessing the hid (aftermarket ) overdraws current and sticks a contact internally in the cecm. My only other thought is if they somehow changed byte 18 as some people have had similar symptoms when doing oem hid conversions.
APR stage 1, 20% tint all round, tinted tails, interior leds, whistler 695se, carbonio stage 1 +2, Neuspeed insert, OEM S3 short shifter, AWE boost gauge,...
GTIJosh is offline   Reply With Quote
Old 04-16-2013, 03:11 PM   #14
jamlee
Drives: 2013 cw gti, 2013 gsxr1000
Same thing just happened to me..any updates on this problem?
jamlee is offline   Reply With Quote
