Old 04-16-2013, 04:24 PM   #15
phd-12v
phd-12v's Avatar
Drives: 2010 MK6 Gti
needs a new CECM............ mine ends in 087g......even with the harness unplugged, you will still have a battery drain happening. you should get the cecm swapped for a newer one.
Jason---TECH SUPPORT GURU
2010 Gti w/DSG
2012 Jetta Se 2.5
phd-12v is offline   Reply With Quote
Old 04-17-2013, 10:02 AM   #16
jamlee
Drives: 2013 cw gti, 2013 gsxr1000
After replaceing the cecm did anyone run into the issue again?
jamlee is offline   Reply With Quote
Old 04-17-2013, 10:40 AM   #17
Teddy Redskinz
Drives: 2012 UG GTI
No issues since I had it replace over a year ago.
Teddy Redskinz is offline   Reply With Quote
Old 04-20-2013, 05:27 PM   #18
phd-12v
phd-12v's Avatar
nope....................... mine has been flawless
2010 Gti w/DSG
2012 Jetta Se 2.5
Old 12-22-2013, 11:44 AM   #19
timneedscoffee10
timneedscoffee10's Avatar
Drives: 2011 VW GTI w Sunroof
Balls... this is happening to me too. I have HID retrofits (not ed's, x-forum member sukanis') and a euro switch. I swapped in my stock halogens this morning, but it's still getting power all the time to that signal bulb.
Old 05-04-2016, 02:28 PM   #20
Furioustylez75
Drives: 2014 GTI 2.0L TSI
this just happened to me. Went to arm alarm, right front turn signal stuck on. bought used BCM, will update later.
Furioustylez75 is offline   Reply With Quote
Old 03-01-2017, 10:47 PM   #21
titogtimkv1
titogtimkv1's Avatar
I've had this problem for months got a hid kit from uspmotors and it was great than started to flicker and than one day I went to turn my car it wouldn't start went to jump start it turned on right away than noticed the left turn signal stayed on tested the right one no power tested the left continuous power going back to the stock to take it in for the warranty was gonna go with some spyder headlights I got wonder if I will have same issue this is so annoying should have gotten the premium model FML
titogtimkv1 is offline   Reply With Quote
Old 01-30-2018, 06:47 PM   #22
b1ker4e
Drives: VW Golf MK6 118 TSI 2009
Exclamation BCM failure second time
It's my second time having this problem on my 2009 118tsi Mk6 Golf Comfortline. Yes I have aftermarket hid(low beam and fog lights) both 35w. The first time when it happened was just after a couple of months since I installed the HID's, and yesterday whan I was changing lanes on the freeway it happened again. Constant 12V on on driver side turn signal connector even if the car is locked. The part number of my BCM is 1K0937086C. There is no way fixing the problem other than replacing the whole BCM. I'll get red of my HID's and install new headlights with projector lens and will use LED bulbs this time. I will also change my fogs to LED before I buy a new BCM, hopefully everything will be alright this time.
Should I replace my BCM with the one with same part number as my existing BCM, or use a BCM from a highline model? I've heard that the highline BCM can handle HID's? Will it be compatible with my car? I've got a VAG-COM so I can do all the coding.
b1ker4e is offline   Reply With Quote
