Old 05-31-2011, 01:37 PM   #15
GTI_likeurmom
GolfMK6 Elite
GTI_likeurmom's Avatar
Drives: Veyron 16.4
Originally Posted by ricnet.se View Post
hatch pop?
the springs and so on?
here is a link on ecstuning on how to do the hatch pop mod.
http://www.ecstuning.com/Volkswagen-...Pop/ES2083320/
for spring install just follow the coilover diy but for the rears just change the spring out. if you have xenons there is a leveler arm connected to the rear suspension arm that needs to be disconnected when changing the springs.
edit: you also can search vwvortex and golfmk5 for more how to's.
Old 06-02-2011, 04:03 AM   #16
mmike1980
Drives: audi a6
for general diagnose you can get the vag com vcds interface, my current cable is 10.6.3, this is where i got:
http://yellyeahmy.com/6-vcds-vag-106...obd-cable.html
so far so good...
mmike1980 is offline   Reply With Quote
Old 06-02-2011, 04:13 AM   #17
tymont12
Drives: 2011 2.5L Golf
so far so good...
so you're telling me this $40 cable will allow me to alter my golf's coding? Or just read it?
tymont12 is offline   Reply With Quote
Old 07-06-2011, 09:46 AM   #18
bubuski
El Moderador
bubuski's Avatar
Drives: MK6 GTI 5-door TR
New link added.
Old 10-08-2011, 05:17 AM   #19
maskari_gti
maskari_gti's Avatar
Drives: MK4 & MK6 GTIs
Awesome thread
Saved
maskari_gti is offline   Reply With Quote
Old 01-13-2012, 10:48 AM   #20
grambles423
Limited Activity
grambles423's Avatar
Drives: 2008.5 BMP GTI
Want to add these links for suspension install?
http://forums.vwvortex.com/showthrea...s-(fronts-only)
http://forums.vwvortex.com/showthread.php?2213232
http://forums.vwvortex.com/showthread.php?3043490
This was also a good reference:
http://deviantspeed.com/suspension-i...i-gti-2-0t-fsi
UnNaturally Aspirated
APR Stage 1- ECS Dogbone
Old 01-13-2012, 11:45 AM   #21
bubuski
El Moderador
bubuski's Avatar
Old 03-05-2012, 04:45 PM   #22
ErsteGTI
Drives: White 2011 GTI 4dr DSG
subscribed....great thread
ErsteGTI is offline   Reply With Quote
Old 03-20-2012, 09:17 AM   #23
bubuski
El Moderador
bubuski's Avatar
Links updated
Old 03-25-2012, 07:57 PM   #24
Mindfields
Mindfields's Avatar
Drives: 2012 .:R
Great tread !
Mindfields is offline   Reply With Quote
Old 03-26-2012, 10:27 AM   #25
Praxus
Praxus's Avatar
Drives: 2011 4 Door GTI Shadow Blue
Great Thread! A must have, (Subscribed)
2011 VW GTI MKVI | DSG Auto | [Shadow Blue | Interlagos Plaid Interior | Sun & Nav | 20% Tint | Shaved Hood and Badgeless Front Grille| EUROJET 3" Turbo-back Exhaust | FORGE Twintake Induction System & Diverter Valve | [COLOR="Red”]AVE[/color] Turbo Outlet Pipe | NEUSPEED HI-FLO Air Charge Pipe (i.e.Throttle Body Pipe) | Revo Stage II | Rieger Front Lip Spoiler w/ Cutouts & Side Skirts |
Praxus is offline   Reply With Quote
Old 04-25-2012, 04:45 PM   #26
grambles423
Limited Activity
DSG 40K Service: Oil and Filter Change
http://www.scribd.com/doc/5493363/DI...enance-service
http://www.myturbodiesel.com/1000q/m...ge-service.htm
Old 04-30-2012, 10:17 AM   #27
WAP
WAP's Avatar
Should Modshack's Soundaktor disabling video be included here? Just a thought...
Old 05-12-2012, 03:27 PM   #28
tetrovski
Drives: 2012 MKVI Highline 2.5L
this should be stickied
tetrovski is offline   Reply With Quote
