Old 05-14-2012, 01:00 PM   #29
bubuski
El Moderador
bubuski's Avatar
Drives: MK6 GTI 5-door TR
Originally Posted by WAP View Post
Should Modshack's Soundaktor disabling video be included here? Just a thought...
Link?
Old 05-14-2012, 05:27 PM   #30
WAP
WAP's Avatar
Originally Posted by bubuski View Post
Link?
Here's the link to the original thread. Modshack's video is on page 20, post# 397.
http://golfmk6.com/forums/showthread...daktor&page=20
Cheers
Old 05-30-2012, 12:32 PM   #31
bubuski
El Moderador
bubuski's Avatar
Cheers
Took a while but I got it done. Thanks
Old 06-01-2012, 11:22 AM   #32
WAP
WAP's Avatar
Old 06-26-2012, 10:04 AM   #33
Hornblower
Hornblower's Avatar
Drives: 2012 GTI DSG UGM
Question...is the DSG service as shown in these videos virtually the same for both TDI and gas engines? Specifically, is the fluid amount the same for both TDI and gas engine cars?
Hornblower is offline   Reply With Quote
Old 10-13-2012, 10:48 PM   #34
Kritter
Drives: '12 GTI 4dr navi/sunroof
Saved for next day off. Thanks
Ko4 Member #91
APR Ko4 | Carbonio stage 1&2 | UR DP | 35% tint all around | OEM Euro short shifter | Euro blind spot mirrors | LED reverse and interior | red LED footwells | Custom über stealth V1 | P3 Gauge
Kritter is offline   Reply With Quote
Old 11-11-2012, 09:48 PM   #35
Mcflurvin
Mcflurvin's Avatar
Drives: MK6
Someone needs to update this
Mcflurvin is offline   Reply With Quote
Old 06-27-2013, 10:26 AM   #36
James9449
James9449's Avatar
Drives: 2011 GTI, DSG, United Gray
Wheel Changing
What is the name of the guide tool used to hang a wheel? I'm referring to the pin-like lug insert that supports the wheel being mounted or dismounted. If anyone can point me to a resource where I can find this specifically for my VW, I'd appreciate it.
Also, what are the specs for the wheel lugs on late model GTIs? That is, what are the diameter and thread specs?
2011 UG GTI 2-door; DSG; Autobahn; Bi-Xenons; Lamin-X front end; Geo-Shield tint (50%); Borla cat-back; full APR Carbonio intake; APR Stage 1 ECU; LED interior lighting; Neuspeed 25mm RSB; BSH motor / transmission / pendulum mounts; BSH catch can with 42dd drain kit; P3 vent-mount digital boost gauge; EuroSwitch; LED city lights; R1 Concepts Premium slotted / drilled rotors; PosiQuiet ceramic pads; VW DG linear springs; misc. cosmetic stuff.
James9449 is offline   Reply With Quote
Old 06-27-2013, 10:32 AM   #37
bubuski
El Moderador
bubuski's Avatar
Its a 'Wheel Mounting Assist Tool', comes in plastic or metal sells for about $5-12. I dont think it has a fancy name. M14x1.5 is the thread for the tool and lug bolts.
Old 06-27-2013, 03:18 PM   #38
James9449
James9449's Avatar
Thanks much, oh most wise and beneficent moderateur.
Old 07-15-2013, 10:47 AM   #39
Oatmeal_Batter
Saved
Oatmeal_Batter is offline   Reply With Quote
Old 08-14-2014, 11:11 AM   #40
raimo_81
Drives: 2010 Golf
I am looking to install just shocks (Koni STR.T) on a mk6 golf - 2010, would anyone know if any of these diy's apply???
raimo_81 is offline   Reply With Quote
Old 08-14-2014, 02:33 PM   #41
Shutaro
Drives: '16 6MT Mazda 3S GT HB
Shock installation will be the same as coilover installation. Dan's spring DIY will help too, but it doesn't cover the rear strut.
'12 DBP MT TDI : APR Stage 1 : DG springs : Bilstein B8s : Depo Black Cherry tails : H&R spacers 10/15mm : Ed's reps w/Morimoto 3Fives @ 4300k : 35/20% tint : VCDS [Garaged until the VW buyback ]
Shutaro is offline   Reply With Quote
Old 11-16-2014, 09:40 AM   #42
ryanbmk6
ryanbmk6's Avatar
Drives: 2011 GTI REVO stg1
Saved
ryanbmk6 is offline   Reply With Quote
