Old 04-08-2012, 07:17 PM   #1
mike12
Drives: 2010 VW GTI
downpipe question
i tried to search a bit but i found nothing i really was looking for.
i dont have the money to go stage 2 right now but i figure stage 1 and 2 cost about the same so when i go apr i wanna just jump straight to stage 2 my question is can i run a DP w/o the tune. i have a magnaflow CBE already and K&N intake. i know it will throw a code w.o the tune but can i run a defouler and be safe or no?
mike12 is offline   Reply With Quote
Old 04-08-2012, 07:26 PM   #2
allset
allset's Avatar
if u mean run a 3" DP and high flow cat with stock tune, yes u can.
Old 04-08-2012, 07:40 PM   #3
AXO
AXO's Avatar
Yes, You need an o2 Sensor Spacer. RAI and 42 Design Draft sell them. Try doing a search for "o2 Sensor Spacer". There is a lot of good threads on this subject.
Life's a Garden, Dig It!
HOOKERS
Old 04-08-2012, 07:41 PM   #4
Mindfields
Mindfields's Avatar
Drives: 2012 .:R
APR dealer told me that the upgrade for the progam from stage1 to 2 is free ... so do what i'm planning, get stage 1 then when u have $ buy DP & upgrade !
Mindfields is offline   Reply With Quote
Old 04-08-2012, 08:02 PM   #5
allset
allset's Avatar
i have the UR DP with 200 cell metal cat ; it has a built in o2 spacer on all DP the sell for the mk6.
I was stage 2 for a year but recently needed a new ECU. So right now im OEM tune with the UR DP, after the ECU went in it took about 400 miles of driving but all readyness inducators passed and i passed NYS emissions. No CEL, I check it today still all readyness are passed. Kinda surprised, i expected at least 1 fail for the cat.
Old 04-08-2012, 08:03 PM   #6
Modshack
Modshack's Avatar
Ultimate Racing DP with 400 cell CAT: No spacers, No cel's, No tune.
Mine's been flawless..
Old 04-08-2012, 08:15 PM   #7
allset
allset's Avatar
i know right? UR is great. they dont even advertise the built in spacer/no CEL thing. i was completely shocked to have full readyness with a stock tune and 200 cell cat.
Old 04-08-2012, 08:25 PM   #8
mike12
Drives: 2010 VW GTI
but running a DP with a cat would make it so you dont need a defouler or spacer thats common sense i was saying if i ran a catless DP can i use the spacer/defouler until i go stage 2. Also i think my local APR dealer said the upgrade to stage 2 is like 150 for some reason...labor? idk
Old 04-08-2012, 08:44 PM   #9
allset
allset's Avatar
no , most DPs without spacers will thow CEL with cats of 200 cell even 400 cell sometimes. Alot still throw with spacers and usually the CEL comes and goes, i havent seen it yet. These are high flow cats with less platinum, palladium and iridium (the catylst that alters the chemistry of the exhaust, the ecu is expecting cleaner exhaust from the more dense oem cat , hence the CEL
Old 04-08-2012, 08:47 PM   #10
mike12
Drives: 2010 VW GTI
i was reading the other thread saying most people have use the middle sized jet on the RAI spacer and have had no problems so i may try that. im just asking cause i have no emissions in my part of VA but they will question a check light and i wanna run a catless DP cause theyre a little cheaper but i will seee
Old 04-08-2012, 08:51 PM   #11
allset
allset's Avatar
im not sure using a spacer in a dp with no cat will prevent a CEL, it may not be alble to compensate enough to fall in the parameters of the ecu but do some reseach, maybe it will
Old 04-08-2012, 08:52 PM   #12
Modshack
Modshack's Avatar
In that case, i's a crapshoot.
Old 04-08-2012, 08:58 PM   #13
mike12
Drives: 2010 VW GTI
^ your Ultimate-Racing DP with the 400 cell hasnt had any problems tho?
Old 04-08-2012, 09:29 PM   #14
mike12
Drives: 2010 VW GTI
what is the difference in the CBFA and CCTA downpipes. i was thinking of getting the Godspeed catless DP and then having a shop weld in a 400 cell ceramic 3" high flow cat and thats only 200+ in parts for a catted DP compared to buying the UR one...i know it sounds dumb but ive done this method on my old SRT-4 and it worked fine. only problem here is i can only find godspeed DP's in CCTA and i believe i have a CBFA
