Old 06-01-2012, 11:42 PM   #29
VR6Growl
VR6Growl's Avatar
Drives: '12 Jetta 2.5 SEL; '14 328D xDrive
Hey guys, this is a great write up so far! Quick question, has anyone found any issues with staging on a "C" model cluster? Mine says the function is not active so I can't do anything, but I thought C was one that it worked on?
1 other question, how do I change the alt. speed display to mph instead of kph?
Thanks!
-Jason G. --
2012 Jetta 2.5 SEL
2014 BMW 328D xDrive
VR6Growl is offline   Reply With Quote
Old 06-03-2012, 11:32 AM   #30
Fast4life
Fast4life's Avatar
Drives: Old:2012 GTI CSG/DSG New: MKVII GTI
Question, is there a way to make the headlights turn on when I unlock the car? Id assume this is the coming home feature but I'm not sure. I have ed's lights and i think it would be cool to have the LED's illuminate when I unlock the car
APR TUNED STAGE 2, S3 IC, 42DD Street DP, Red Interior LED, 15% tint all around, StopTech Brake Pads, Rev "D" DV
Fast4life is offline   Reply With Quote
Old 06-06-2012, 10:16 PM   #31
CrzyP
CrzyP's Avatar
Drives: '03 GTI 20th, '12 GTI Autobahn
For those with the 2012 LED DRL's. If you want them to dim instead of turn completely off when you use your turn signals, you first need to do the coding mentioned on the first post to disable DRL's with turn signals. Then you need to change the coding of your cluster to another country other than USA. After that you should have dimming DRL's with turn signals.
Question though. When you open the door to a Golf R, the cluster needles light up along the the cabin lighting. How do I get my GTI to do the same?
CrzyP is offline   Reply With Quote
Old 06-07-2012, 03:20 PM   #32
chucka
Drives: CW GTI 4 Door
Windows: Roll Up/Down with Key
Description: Roll down down your windows with your key remote when you unlock the doors
Check bit 5 of byte 3 in Central Electronics Long Coding Helper
Option: If you want to be able to do this when the car is turned on, check bit 7 of byte 3
Option: Enable your lock switch on the door to roll all windows up/down without a key present, check bits 3, 4, and 7 of byte 3
Pic tutorial: Comfort Closing/Opening via Remote Control
I did this today cause I was itching do another vagcom tweak.
It worked but for some reason the rear right window doesn't go down or up with it. It does with the key fob. No biggie to me just thought I mention it.
dfweuros.com
chucka is offline   Reply With Quote
Old 06-07-2012, 03:27 PM   #33
grambles423
Limited Activity
grambles423's Avatar
Drives: 2008.5 BMP GTI
Definitely used this twice already for Local VAGCOM dealings
UnNaturally Aspirated
APR Stage 1- ECS Dogbone
Old 06-07-2012, 06:31 PM   #34
veedoubleme
veedoubleme's Avatar
Drives: 2014 MB C300
I just tested to make sure I wasn't wrong first, and this works correctly on my windows. I wonder if you need to reset something?
Great!
Old 06-09-2012, 04:28 PM   #35
zVp
zVp's Avatar
Drives: 2012 Black GTI (DSG)
http://golfmk6.com/forums/showpost.p...&postcount=196
Disable/Enable Hill Hold
2012 DEEP BLACK PEARL GTI
zVp's Car Journal
Old 06-09-2012, 05:31 PM   #36
Mustache rash
Mustache rash's Avatar
Drives: 2011 K04 GTI 6mt
Thanks for this.
2011 CSG GTI 6MT
APR K04 3.1
Build Thread
IG@mustache_rash
Old 06-11-2012, 06:09 PM   #37
ohsnapzombies
Drives: 2016 MK7 GTI
just did about 7 items. awesome thread is awesome.
ohsnapzombies is offline   Reply With Quote
Old 06-13-2012, 08:09 AM   #38
GTIIIIIIIII!!!!
GTIIIIIIIII!!!!'s Avatar
Drives: 2011 CSG 4DR 6SP
LED tails with rear fog
Anyone have problems getting the rear fog to light up? I just checked the wiring and all is good there. I think we tried both code 15 and 22. Verifying that right now.
Mods: 194 Red Footwell lights / Smoked Side Markers / OEM LED Tails / Euro Switch / Textured Black Mirror Caps / 20% Tint / APR Stage I / Carbonio Stage I + II / PIAA Extreme White H8, H7, 168 /ECS Tuning Short Throw Shifter, Pop Hatch, LED License Plate & Trunk Lights, Split Tinted Mirrors / VMR 708's w/Continental DWS / DG Springs / Unibrace UB & RB / AWE Boost Gauge. NJ DIRTY EUROS on FB
GTIIIIIIIII!!!! is offline   Reply With Quote
Old 06-13-2012, 01:35 PM   #39
veedoubleme
Originally Posted by zVp View Post
Cool! Thanks! I updated the main post with this.
I'm trying to decide if I like it or not paired with DSG. I think I like it fine, so I'll probably just leave it alone, but it's good that it can be turned off.
Old 06-13-2012, 01:56 PM   #40
zVp
zVp's Avatar
No problem!
I've been driving around with it off for a while now and honestly I'm not even sure if its different from putting the HHC to low. Although, there's not many hilly areas in the Toronto area that I drive in. I'll keep testing!
zVp's Car Journal
Old 06-18-2012, 07:27 PM   #41
nik
nik's Avatar
Drives: '12 CSG 6spd GTI 4DR
Tear Drop for front wipers
Courtesy of the tex
LINK
2012 CSG GTI 6 spd - /// Dynaudio / Sunroof/ BBS RS861's/ neutered soundaktor/ custom mount bright a** LED trunk light/ Door warning lights/ USP Delrin shifter bushings/ S3 SS/ LED Tails
Need VAG-COM in the GTA? Shoot me a PM!
nik is offline   Reply With Quote
Old 06-18-2012, 08:03 PM   #42
veedoubleme
Originally Posted by nik View Post
Courtesy of the tex
LINK
Great find for those that appreciate tear drop wipers!
I updated the first post as usual.
