Old 04-19-2012, 11:43 AM   #1
dasVW.com
dasVW.com's Avatar
Drives: 2011 VW GTI
Question 18711/P2279/008825 - Leak in Air Intake System
I am getting this error code, P2279 - Leak in Air Intake System.
I've checked & reassembled my air intake 4 times now and I still cannot get this error code to go away.
Any recommendations?
Here is what Ross-Tech says about it:
Possible Symptoms
-Malfunction Indicator Lamp (MIL) active
Possible Causes
-Vacuum Leak
-Intake Manifold Runner Position out of Specification
-Faulty Positive Crankcase Ventilation (PCV) System or Heating Element (N79)
Possible Solutions
-Check Intake System for Leaks
-Check Intake Manifold Runner
-Check (PCV) System and / or Heating Element if applicable
Special Notes
-When found in the NAR 2.0T (BPY) check RVUTB: 01-09-03 or 2018919 for updated Crankcase Breather Valve
-If the breather valve is faulty, full engine vacuum is typically found when removing the oil cap at idle.
http://wiki.ross-tech.com/wiki/index...1/P2279/008825
2011 VW GTI 2.0T ///My Build Thread
Volkswagen MK6 GTI Comparisons: ECU UpgradesIntercoolersDownpipesCat-back ExhaustAir Intakes
dasVW.com is offline   Reply With Quote
Old 04-19-2012, 12:12 PM   #2
steemax
steemax's Avatar
Drives: 2016 Subaru WRX Stage 2 ProTune
Possible Symptoms
Possible Causes
-Vacuum Leak
Possible Solutions
Special Notes
Have you checked the PCV pipe that connects to the end of the intake by the rear of the engine?
Previous: 2011 VW FrankenTurbo GTi
Present: 2016 Subaru WRX Stage 2
YouTube: Click Here
Instagram: Steamax
steemax is offline   Reply With Quote
Old 04-19-2012, 12:16 PM   #3
dasVW.com
dasVW.com's Avatar
Drives: 2011 VW GTI
I have. As far as I can tell, it is on there tight.
Old 04-19-2012, 12:32 PM   #4
JhnR
Drives: Lemon mk6 GTI
did you try to reinstall stock see if the problem still persists?
JhnR is offline   Reply With Quote
Old 04-19-2012, 12:47 PM   #5
McQueen77
why wouldnt you just go to the dealer? the car is brand new.
Old 04-19-2012, 12:56 PM   #6
dasVW.com
dasVW.com's Avatar
Drives: 2011 VW GTI
I have not. I was hoping I wouldn't have to resort to doing this.
Quite frankly I am tired of *not* having my car. It was in the body shop for over a month. I am sick and tired of loaner cars, or finding a ride with someone, or car pooling. Hopefully I can fix it and be done with it.
If I do take it to the dealer, I'll put the stock intake back on so they won't b*tch at me for my intake.
Old 04-19-2012, 01:19 PM   #7
JhnR
why not its a 20 min job tops..just sayin
Old 04-19-2012, 01:20 PM   #8
dasVW.com
dasVW.com's Avatar
Drives: 2011 VW GTI
I'll give it a go tonight. Thanks for your input.
Old 04-19-2012, 02:46 PM   #9
JhnR
then if you have no problems after its your intake
Old 04-26-2012, 12:09 PM   #10
dasVW.com
dasVW.com's Avatar
Drives: 2011 VW GTI
For the record, I believe it was the silicone reducer coupling. I replaced my entire setup with a new silicone piece and two new stainless steel T-bolt clamps. Now it is air tight (for atleast 48 hours).
-Vibrant Performance Silicone 4 Ply Reducer Coupling [link]
-Vibrant Performance Stainless Steel T-bolt Clamps [link]
Old 04-26-2012, 12:28 PM   #11
Modshack
Modshack's Avatar
Most issues like this are Installer errors..
Old 04-26-2012, 12:29 PM   #12
grambles423
Limited Activity
grambles423's Avatar
Drives: 2008.5 BMP GTI
THIS x1000000000000000000000000000000000000000000000000 00000
Its too bad there arent poke yokes designed for these instances. Plus, there is a reason the service department goes through rigorous training when a new model comes in
UnNaturally Aspirated
APR Stage 1- ECS Dogbone
Old 04-26-2012, 12:57 PM   #13
JhnR
Old 04-26-2012, 01:56 PM   #14
dasVW.com
dasVW.com's Avatar
Drives: 2011 VW GTI
I figured as much. Hence why I tried 3 different sets of hose clamps and reinstalled it 3 times to try ditch the leak. -but- the hose clamps were shot and I had to order new hardware.
That's a lot of zeros...
