Old 04-16-2015, 11:13 AM   #169
phem0r
Noise pipe delete link for 2011+ is broken
Noise Pipe and Soundaktor Delete: Eliminates the sound makers on your vehicle to enjoy a REAL engine sound
2008.5 - 2010: http://www.golfmk6.com/forums/showthread.php?t=6889 and
2011+: http://www.golfmk6.com/forums/showthread.php?t=33595
"Invalid Thread specified. If you followed a valid link, please notify the administrator"
phem0r is offline   Reply With Quote
Old 05-27-2015, 01:33 AM   #170
skotcoop
skotcoop's Avatar
Drives: 4DR CW 2012 GTI 6SPD
Check. Looking for links for LED tail lights. Wasn't in the list and the search had too many results.
skotcoop is offline   Reply With Quote
Old 05-27-2015, 08:46 AM   #171
lilonespaz
lilonespaz's Avatar
Google works wonders.
Reps Zizza
http://www.ecstuning.com/Volkswagen-...hts/ES2730504/
OEM
http://www.ecstuning.com/Volkswagen-...hts/ES2221157/
Reps Depo
http://opdparts.com/index.php/volksw...rk-cherry.html
EDs Tail lights (reps)
http://forums.vwvortex.com/showthrea...-fog-Group-Buy!
Old 05-28-2015, 09:59 PM   #172
skotcoop
skotcoop's Avatar
Yes it does. I meant thread links sorry. I should have been more specific with my statement and I dont know what "reps" means. I'm curious if anyone has tried these http://www.ecstuning.com/Volkswagen-...hts/ES2718561/
Old 05-29-2015, 08:29 AM   #173
lilonespaz
lilonespaz's Avatar
Reps = Replicas as in not OEM
Which just means that someone else made them it doesnt mean they wont look or function the same its just not Genuine VW.
Here are some threads on LED tails.
Google works for this too.(Just saying not being a dick) Type GolfMK6GTI at the begging or end of whatever you are looking for on google and the first few should be threads on here.
Review - Depo LED Tails
http://www.golfmk6.com/forums/showthread.php?t=55296
LED tails fog vs no fog - Reverse
http://www.golfmk6.com/forums/showthread.php?t=54133
LED tails - my install video
http://www.golfmk6.com/forums/showthread.php?t=7420
Old 06-02-2015, 11:10 PM   #174
skotcoop
skotcoop's Avatar
Perfect. Thanks a bunch. I asked about the helix ones because they were the only ones (that I noticed) that were plug and play with no coding required. Is this wrong?
Old 06-03-2015, 08:22 AM   #175
lilonespaz
lilonespaz's Avatar
If youre not doing a rear fog Depos are also plug and play. They have a resistor box that should make you not throw a bulb out warning.
If you buy one with rear fogs without coding you will just have 1 white and 1 red reverse light. You only need coding on the tailights if you are using the fog function or if you get a bulb out warning.(To my knowledge)
Old 07-10-2015, 07:56 PM   #176
skotcoop
skotcoop's Avatar
I still think these look best http://www.ecstuning.com/Volkswagen-...hts/ES2718561/
Old 09-14-2015, 12:50 PM   #177
Verd Machta
Drives: 2012 VW GOLF
Super helpful indeed.
Verd Machta is offline   Reply With Quote
Old 12-31-2016, 02:15 AM   #178
jakedeloera361
https://www.ecstuning.com/b-alzor-pa...four/030-10kt/
What would I need to do to run these wheels without rubbing? Would 10mm spacers be fine?
jakedeloera361 is offline   Reply With Quote
Old 12-31-2016, 02:56 AM   #179
jakedeloera361
Im gonna do between a 1-2" drop depending on what I can get away with but I saw that these have a 35 mm offset and stock is 45mm so that's why I say 10mm spacers.
Old 12-31-2016, 02:58 AM   #180
snobrdrdan
Formula 2 Champion
snobrdrdan's Avatar
Drives: a VW
Your source is wrong
Stock wheels are 18x7.5, ET51.
18x8, ET35 will poke out 22mm over stock (most spacer "flush" kits, with the OEM wheels, are 10mm front & 15mm rear)
Helpful tool:
http://www.1010tires.com/Tools/Wheel-Offset-Calculator
2017 Passat VR6
2017 Passat R-line
snobrdrdan is online now   Reply With Quote
Old 12-31-2016, 09:23 AM   #181
drval85
If you added 10mm spacers to an et35, your final offset would be et25.
Et35 with a 2" drop will probably need rolled front fenders. At least with a 225/40 tire. Maybe not with a 215/40.
Old 01-03-2017, 01:04 AM   #182
Random
Drives: 2010 VW GTI
Helpful
Very helpful
Random is offline   Reply With Quote
