Old 05-27-2013, 11:06 AM   #29
timneedscoffee10
timneedscoffee10's Avatar
Drives: 2011 VW GTI w Sunroof
DIY: SS Brake Lines and Fluid Flush
Originally Posted by FoxGTI View Post
I have a question,
If I wanted to replace my brake fluid with Motul 600 synthetic, how would I be able to distinguish the new fluid from the old?
My car had 40K and I am trying to get everything together to chance brake pads on the rear and upgrade the front Brake lines, as well as replacing my brake fluid.
The used fluid will still be off in color compared to the new fluid. You'll be able to tell, it's just more subtle. Using blue ate makes it very obvious.
Open your bleed valve and capture some dirty brake fluid and just compare it side-by-side with the new stuff so you can see what you're looking for.
Old 05-27-2013, 05:42 PM   #30
FoxGTI
Drives: MK6 GTI Candy White
I see, thank you !
FoxGTI is offline   Reply With Quote
Old 11-28-2013, 01:08 AM   #31
FeX141
Drives: Mk6 GTI (2010), 6MT, 2-door
Great info and writeup!!
Is it normal to have to top up your brake fluid after 2 years? Does this mean I will have to replace the pads soon? if so how soon? Thank you.
FeX141 is offline   Reply With Quote
Old 11-28-2013, 05:44 PM   #32
Jordanka
Drives: Passat 6MT
Your brake pads have worn down hence the brake fluid level dropping. If you can, have a look at the brake pad when you do a tire rotation or have the wheel(s) off. Alternatively you can ask your mechanic to check.
It's not a bad idea to do a brake fluid flush every 40K, just remind the dealer to do the clutch line too as they have a tendency to forget.
Jordanka is offline   Reply With Quote
Old 11-28-2013, 06:35 PM   #33
FeX141
Thanks for the info and tips Jordanka! It's hard to see the inside pads, but from what I can see (and the outside ones) there is still a decent amount left.
Old 11-29-2013, 04:30 PM   #34
Jordanka
Drives: Passat 6MT
NP my man, my car's 6MT and I'm at 57K Km - about 30-40% on the fronts and rears. Your pads should wear evenly unless there are other issues so what you see on the pad facing the front of the rotor should be the same for the pad on the rear face of the rotor.
Old 11-29-2013, 05:13 PM   #35
MaliciousMK6
MaliciousMK6's Avatar
Good write up! This is definitely on my to do list
Old 11-29-2013, 05:27 PM   #36
FeX141
Thanks! I can see about 1.5-1.75cm on the outside pads on the front and about 1cm on the rear (what is left). I have 87K km. Only cosmetic changes with my vcds and yellow fogs. . So if you ever see a carbon coloured GTI with yellow fogs as the daytime running in the GTA, that's probably me!
I ordered some brake fluid, so I can top it up, although it may not even be necessary.
Old 11-30-2013, 01:54 AM   #37
Jordanka
Drives: Passat 6MT
Wow bud, 87K Km on the original brake pads is pretty damn good. Based on the numbers you wrote I would suggest replacing the brake pads only and doing a fluid flush as preventative maintenance. You should be able to take the OEM rotors past 100K with no problems.
When the car's cool, run your fingers along the rotor and check how smooth they feel. If the brake pads get completely worn they'll damage the rotor, so replace the pads before this happens.
Old 11-30-2013, 02:46 AM   #38
FeX141
Will do! I do most of my driving when there is no or little traffic. 70% highway. And I am easy on the brakes. (can't say the same for the throttle though )
I'll be sure to check the surface roughness of the rotors and replace the pads before they are totally done. I wonder how much leeway the pad sensor gives, or if you have to replace them right away once it goes off.
Overall, I am very impressed with the longevity of the brake pads.
Thanks again!
Old 12-02-2013, 12:11 PM   #39
Jordanka
Drives: Passat 6MT
Thanks again!
You're certainly welcome. I would replace the pads right away once the sensor goes off. If you're at almost 90K I'd start shopping around for brake pads in the interim.
Old 12-02-2013, 05:48 PM   #40
FeX141
I think the rears will go first. They seem to have much less pad left than the fronts. And I think the sensor is on the front driver side only. So I will just have to monitor the last 0.5cm of pad.
I have been looking for pads. Seems there are some good pads for a good price on TireRack. Can get some HPS for a decent price. https://www.tirerack.com/brakes/brak...ModClar=2-Door
Thanks!
Old 01-22-2014, 03:28 PM   #41
Stero1Dcc
Drives: 2011 ko4 CC
I got a set of these... need to get it done! great write up
Stero1Dcc is offline   Reply With Quote
Old 01-22-2014, 03:35 PM   #42
FeX141
Update:
I was wrong about the amount of pad left. Fronts come with 12mm I'm at 8mm.
Rears are at 1-1.5mm.
I changed the rears only. Pads and rotors. And did a fluid flush.
I'm amazed at how much pad is left on the fronts! I have now about 90K km
Cheers,
