Go Back   VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - > Technical Topics > DIY Guides and Discussions
Old 06-30-2016, 04:19 PM   #57
Drives: Everything
Confirmed the Correct procedure here
Another great tip in this video (the later part)
JT64 is offline   Reply With Quote
Old 06-11-2017, 04:37 PM   #58
Drives: MK6 GTI | 01 Ducati M750
Side note to everyone: handheld vacuum bleaders don't work. At least, mine didn't work.
I typically use a handheld vacuum bleeder, which works great on... everything else I've worked on (Honda/Toyota), but it does not work on these. You'll pull the fluid out but get a lot of air. VW's must be valved differently. In a Honda, if you pump the brakes with the reservoir cap off, you'll spout fluid everywhere. In these, I pumped the brakes safely with the cap off.
When I had someone pump the brakes using the ol' "helper method", everything went per normal. Just thought I'd note this, in the event someone reads through to page 5. Thankfully I saved the clean fluid to re-use, as I may have went through the liter thinking it was normal to flush through a lot of air.
rtnlsltn is offline   Reply With Quote
Old 06-22-2017, 07:21 AM   #59
Drives: Golf 5 R32, golf 6 GTD
Pictures are broken
MikeB is offline   Reply With Quote
Old 08-15-2017, 09:04 AM   #60
Pics are broken
Sent from my Life One X2 using Tapatalk
Joveen is offline   Reply With Quote
Old 01-17-2018, 12:02 PM   #61
Drives: 2011 mk6 GTI 2.0T
Originally Posted by PandaGTI View Post
Also add... To that... Don't over tighten the bleeder nipples... I repeat DON'T OVER TIGHTEN THE BLEEDER NIPPLES.
Every DIY I've read about bleeding brakes never really mentions this and I'm learning the hard$$$ way.
Bled the brakes on my BBK which all went smoothly, but I guess I over tightened the bleeder nipples with my gorilla hands. Found this out on the track when the combination of hot brakes and overly tightened bleeder nipples led to fluid gushing out of the BBK calipers baking and corroding onto the paint of the calipers. Also sucking air back into the system leading to loss of brakes on the track.
So now I have to buy new bleeder nipples and hope that the caliper threads aren't stripped, if it is stripped then the caliper threads are gonna have to be re threaded. On top of that after I get it sorted out... I'm gonna have to get the calipers repainted.
Also if you do have a BBK.. the nipples will weep a little so maybe it's best to use the inner bleeder nipples so if it does weep it'll be on the inner side that you can't see.
Lastly on my BBK the nipples should be torqued to 10 lb/ft and on an OEM brake I believe it is 7lb ft... In other words tight enough so the fluid stops coming out then 1/8 of a turn tug.
This is from a while ago hope your still active, Where did you find Stainless Steel brake lines for your BBK that would fit?
demon342 is offline   Reply With Quote
