mattyICED
Got this set from PYSpeed. :thumbsup:
Heres what the box looks like
Everything out of the box
So lets get started..
Push in the clip on the side to release the light housing from the bumper.
It should look like this. Pull it out some to be able to see the connector
Now on the connector push the tab in the opposite direction of the housing
Now grab a ballast and connector harness for the new LEDs. They connect like this..
Once you get that squared away connect the new harness to the connector on the vehicle.
Ziptie your wires however you see fit
Gently slide connector and ballast through the opening and clip in the new housing.
And simply repeat for the other side!
Here is the difference..
