Surging/hesitation/pulsing under hard acceleration
intoflatlines
Mods: APR stage 2 tune, Carbonio stage 1 intake, GHL catted DP, Magnaflow CB, BFI stage 1 torque mount insert
This issue happens seemingly randomly, and lasts for maybe a week or so and then goes away for awhile. When I go WOT (or hard acceleration) in 3rd gear or higher (I don't really go WOT in 1st or 2nd for obvious reasons) there is some weird surging feeling and you can hear it. It's almost as if I was slightly letting off the gas and then getting back on. It is not a rhythmic surging (it is irregular in beat). It kind of reminds me of when you watch a video of a car going around the Nurburgring, and then under WOT the exhaust note/RPMs kind of fluctuate when going over the undulations on the track.
I know that my clutch is slipping. In 4th and up it will slip at low/moderate RPMs and WOT. But this feels different because when the clutch slips the RPMs will rise steadily for a little, then hold constant until the rest of the transmissision speed catches up.
I've heard that it could be a fuel filter issue? What do you think? I'd prefer to not spend the time/money on a new fuel filter if it's something else :)
grambles423
Automotive Engineer
VAGCOM It.....it could be WG Duty Cycle or slipping clutch. I think its the latter.
ns01gti
Have you tried data logging your incident?
Edit: Grambles in first lol
intoflatlines
You mean do a log session? What should I look for in the data? If you're just talking about codes, there are none :(
grambles423
Automotive Engineer
Yes, a log session. I would log the following
Fuel Pressure Specified
Fuel Pressure Actual
Boost Specified
Boost Actual
N75 Duty Cycle
MAF
RPM
Lambda
That should get you started. 3rd or 4th doesnt matter as long as you dont break traction during the run and you use it consistently.
veedoubleme
As a tip for future logging sessions, you can save each logging configuration so that you don't have to check the boxes every time. Taken from: Ross-Tech: VCDS Tour: Advanced Measuring Values
VCDS lets you save a list of Advanced Measuring Values, to be easily accessed later on. For instance, if you often log Vehicle Speed, Engine Speed, Intake Air Mass, and Ignition timing, then you can create a file to quickly load those selections again. To save a set of items, click on the VCDS logo found on the top left corner of the item selection window, and then select "Save selection to file":
I have the APR round 1-5 selections saved, as well as a few others I like. It may not help you this time, but it's a big time saver the next time you are going to do logging.
intoflatlines
Good idea, thanks for the tip! :thumbsup:
chinqutie
if that's a slipping clutch then that gives you more reason to make that group buy happen haha! :)
veedoubleme
Try out the attached set of files. They are my saved measuring block sets for APR's 5 round logging. All you should have to do is load one up for each round and you won't have to tick all the boxes. This should save you a lot of messing around between each round.
Let me know if they work for you since I've never tried to transfer from one VCDS user to another. It should work though — they are just text files with a .a01 file extension. If they work I'm going to post them in my VAG-COM thread.
Seems worth a try. :iono:
  • APR Measuring Blocks Sets.zip
allset
yes log 3-4 WOT runs on the same stretch of road one after another, Traction control off, windows up.
Then send to Grambles. he will decipher as he knows his shite.
Other logging block options as per APR:
ROUND 1 LOGGING:
Use for Boost and Fueling
Diagnosis Item # Vag-Com
Block # Description
*Not Applicable to EA888 TSI/TFSI Engines.
1 001-1 Engine Speed
2 014-3 Misfire Sum
3 031-1 Lambda, Current Value
4 054-3 Accelerator Pedal Position
5 054-4 Throttle Plate Angle
6 101-3 Injection Timing (Median)
7* 103-1* Current Fuel Pressure*
8 114-4 N75 Duty Cycle
9 115-3 Boost Pressure (Specified)
10 115-4 Boost Pressure (Actual)
11 230-1 Rail Pressure - Specified
12 230-2 Rail Pressure - Actual
ROUND 2 LOGGING:
Use for Boost and Timing
Block # Description
2 003-4 ignition Timing
3 020-1 Cylinder Ignition Angle Delay (cyl 1)
4 020-2 Cylinder Ignition Angle Delay (cyl 2)
5 020-3 Cylinder Ignition Angle Delay (cyl 3)
6 020-4 Cylinder Ignition Angle Delay (cyl 4)
7 031-1 Lambda, Current Value
8 054-3 Accelerator Pedal Position
9 101-3 Injection Timing (Median)
10 114-3 Engine Load (actual)
11 115-4 Boost Pressure (Actual)
ROUND 3 LOGGING:
MAF/Load-Specific Diagnosis Item # Vag-Com
Block # Description
2 003-2 Intake Air Mass
8 114-1 Engine Load (specified)
9 114-3 Engine Load (actual)
10 115-3 Boost Pressure (Specified)
ROUND 4 LOGGING:
Misfire-Specific Diagnosis Item # Vag-Com
Block # Description
3 015-1 Misfire Cyl 1
4 015-2 Misfire Cyl 2
5 015-3 Misfire Cyl 3
6 016-1 Misfire Cyl 4
7 054-3 Accelerator Pedal Position
8 054-4 Throttle Plate Angle
ROUND 5 LOGGING:
Use for Boost and Timing Item # Vag-Com
Block # Description
3 003-4 ignition Timing
4 020-1 Cylinder Ignition Angle Delay (cyl 1)
5 020-2 Cylinder Ignition Angle Delay (cyl 2)
6 020-3 Cylinder Ignition Angle Delay (cyl 3)
7 020-4 Cylinder Ignition Angle Delay (cyl 4)
8 031-1 Lambda, Current Value
9 054-4 Throttle Plate Angle
10 114-4 N75 Duty Cycle
11 115-3 Boost Pressure (Specified)
12 115-4 Boost Pressure (Actual)
allset
BTW- be sure to post what u find.
Sub'd
intoflatlines
Thanks guys. I'll try to load the files onto my computer later tonight.
Quick question (too lazy to search/do research): what do 3rd and 4th gears top out at in MPH? I need to find a good stretch of road for this that would hopefully not result in me getting ticketed/arrested.
