Old 12-19-2012, 08:16 AM   #15
O-III
O-III's Avatar
Drives: 2015 PW GTI 5DR DSG
Just happened to me yesterday. Started car in the morning, and see "ESP error" in the dash display, then disappeared. A bit worried but drove off carefully. About 15 minutes later in bumper-to-bumper traffic, car stalls. Try to restart, nothing - won't even crank. Put on four-ways, turn off all accessories. Remove key, reinsert, car starts fine. Weird; will check for error codes with VCDS later today. Car completely stock, never had a single issue before.
Have Micro-CAN cable for VCDS tweaks in Ottawa
MK7 GTI owner as of June 30, 2014!
O-III is offline   Reply With Quote
Old 12-20-2012, 09:28 AM   #16
Blackie
Drives: 2011 CW GTI
have you guys noticed when this happens that the steering wheel is unlocked? i think to prevent it , usually you have to jiggle the wheel a bit when turning it on, maybe we just have to make sure it locks when we turn the car off?
Blackie is offline   Reply With Quote
Old 12-20-2012, 10:53 AM   #17
nik
nik's Avatar
Drives: '12 CSG 6spd GTI 4DR
My 11's did this a few times... though it turned over on the second go. nothing with the '12 (knock on wood) and I see that all but one of you have '11s. Me thinks something to do with a bad batch of parts or coding for that model year.
2012 CSG GTI 6 spd - /// Dynaudio / Sunroof/ BBS RS861's/ neutered soundaktor/ custom mount bright a** LED trunk light/ Door warning lights/ USP Delrin shifter bushings/ S3 SS/ LED Tails
Need VAG-COM in the GTA? Shoot me a PM!
nik is offline   Reply With Quote
Old 08-31-2013, 11:25 AM   #18
AXO
AXO's Avatar
This happened to me this morning. I let the car sit for about 5 minutes. It restarted no problems. No more error, drives fine. I am hoping it is a fluke. Sometimes software gets corrupt and you get an error.
Life's a Garden, Dig It!
HOOKERS
Old 09-11-2013, 11:42 PM   #19
stynker
I had this happen to me tonight after I swapped out the stock shifter for the S3 short shifter. Originally tried to remove the battery so I'd have more room to work, but realized I didn't need to after I disconnected the wires. ESP Error popped up right when I started the car but went away as I was pulling out of the driveway for a test drive. Chalk it up to antitheft maybe?
stynker is offline   Reply With Quote
Old 09-11-2013, 11:57 PM   #20
UNFORGIVABLE
UNFORGIVABLE's Avatar
Drives: Black Mk6 GTI, and Mk5 Rabbit
Same, It happened alot when I had my spyder headlights and tailights.
UNFORGIVABLE is offline   Reply With Quote
Old 09-12-2013, 12:33 AM   #21
PRND[S]
PRND[S]'s Avatar
The car needed to relearn the steering wheel adaptations.
Old 09-12-2013, 10:51 AM   #22
Fordson
Fordson's Avatar
Drives: 2011 SB 4door MT GTI - Autobahn
Notice how these are all 2011 and one 2010? I think there was a steering column module reflash or some such that was available for these cars. I thought it was confined to cars like mine with KESSY, but maybe not so - ?
Have the dealer run your VINs...I think there was a campaign.
Stage I APR reflash - Modshack intake - splashguards
Clear Bra - Lamin-X on headlights and fogs
Fordson is offline   Reply With Quote
Old 09-12-2013, 10:58 AM   #23
Sethdude
Sethdude's Avatar
Drives: 2016 Sportwagen SE TSI, 1984 GTI
My 2012 had the steering column module fault code earlier this week when I had a coil go bad. I just cleared it, as it has not been giving me any trouble. So I'm not sure it's exclusive to 2010-2011 MY cars.
Sethdude is offline   Reply With Quote
Old 09-12-2013, 11:22 AM   #24
JhnR
Drives: Lemon mk6 GTI
I had this problem, turned out to be my battery
JhnR is offline   Reply With Quote
Old 12-02-2013, 11:38 PM   #25
aw614
Drives: 2011 CW MKVI GTI
I have a base model 2011, and I've had it happen twice recently, I can't replicate the error though. It happened last week on me at pepboys after I went to pick up a part and between 15 minutes it stalled out on me with the ESP error, started again and it started without issue. Really odd
Old 12-03-2013, 12:45 AM   #26
Jason3d
Jason3d's Avatar
Same here.
My Journal Thread
Old 12-16-2013, 12:24 PM   #27
dimonic
Drives: VW Golfwagen TDI
Problem over 3 years, always when driving
In our 3rd month of our 2011 TDI, it happened when driving in a suburban area - engine power died. We had it towed to a dealership, supposedly repaired. Then again at about 6 months - ESP error. Then this weekend, it died with ESP error a total of 7 times during the snowstorm. I remember the first time was a drizzly day - so perhaps moisture is a common factor. This morning it was cold and dry, and I drove into work without a stall.
In my case, it takes about 5 minutes before it will start again. In this area it is a significant safety issue what with having one of the busiest stretches of highway in North America as my daily commute. Tow trucks descended on me like vultures each time I drifted to a stop on the shoulder.
I am taking it in tomorrow. It is at 89,000 km, and the warranty is only 80,000. I am going to press the fact that it was supposedly repaired twice for the same fault when under warranty, so this is their problem.
dimonic is offline   Reply With Quote
Old 10-08-2014, 02:28 AM   #28
rx4brdm
rx4brdm's Avatar
Drives: 2011 GTI Shadow Blue 6 Speed
Sorry to revive a dead thread but when I try to turn the car on the lights flash on dash and headlights but the car won't start...
Then the ESP
rx4brdm is offline   Reply With Quote
