Old 09-19-2015, 09:40 PM   #43
Tonybaloney
Drives: 2011 CSG 5-door DSG Autobahn
This happened to me too. I read the codes at a shop and they're similar ones that were posted before. I changed my battery already and that didn't help. There is one time that the car didn't let me shift with "p" flashing. Right now I just jade the CEL/catalytic converter light on but have seen the esp error message and TCS light so far. No ECP light (yet). I'm brining my car on Monday. How did others fix this issue? My car is still under the 5-year / 60k warranty so I'm wondering if it'll be fixed under that.
Tonybaloney is offline   Reply With Quote
Old 09-21-2015, 02:32 PM   #44
Tonybaloney
dealer inspected the car and said nothing is wrong with it. seems like everyone is getting the same answer from them. anyone else actually had parts replaced and problem going away permanently?
Old 09-21-2015, 03:57 PM   #45
The ESP sensor is part of the abs pump/module, the 09 cars have a similar issue so maybe that's it.
Old 09-21-2015, 05:38 PM   #46
Tonybaloney
i just picked up my car from the dealership. they said the codes showed "lost communication with the transmission" and we might need to replace the gearbox. it's not covered under 5-year/60k power train warranty but i can try to reach out to VW USA to see if anything can be done. Has anyone run into gearbox issues with their GTI before with only 45K miles?
Old 09-21-2015, 05:42 PM   #47
Tonybaloney
my abs light never came on so i'm not sure if it's a different issue. So far my symptoms are:
1. 5-6 times of "error: ESP" on MDI.
2. 2 times with CEL
3. 1 time with TCS light and flashing "p" on my shift knob area and not allowing me to shift.
all these happened within 2-3 weeks. everything goes back to normal after i restart the car. i'm starting to wonder if there is a loose connecting/grounding/wire somewhere that's causing this. I think this is a coincident but it started to happen after an oil change.
Old 09-21-2015, 09:47 PM   #48
The transmission is the very definition of powertrain. Sounds like they are trying to kick the can down the road. Talk to a manager.
Old 09-23-2015, 02:25 PM   #49
Tonybaloney
We'll see what happens. They're helpful and told me I can go back and they'll look at it again for free if anything comes up again. I consider the $150 diagnose fee worth a while to get on their record before my warranty expires. Hopefully I'll get lucky and won't see the error code ever again.
Old 09-23-2015, 03:35 PM   #50
ChrisB
ChrisB's Avatar
Drives: 2013 MKVI Driver's Ed German Fit
Last week, I had the ESP error, and a whole slew of others, after my battery voltage dropped to 12 volts. I was all prepared to change the battery, but I was able to get the resting voltage higher after a night on my smart charger. If or when it happens again, I'm going with an AGM replacement.
Unitronic: Stage 2 ECU, Stage 2 DSG, TBE
Other: Enkei PF01 17X8 ET50s with Pilot Super Sports; R8 coils; NGK BKR7EIX plugs
Audio: Kenwood DNX891HD; Audison BitOne; MMATS HIFI-6150D; Genesis Profile 16 components, run active of course; 10" Alpine Type R
ChrisB is offline   Reply With Quote
