Old 06-17-2012, 07:21 PM   #1
nvturbo
nvturbo's Avatar
DIY: aftermarket siren (horn delete)
Just like most of the Golf GTI (MK6) owners out there, we've all grown tired of the horn beep when we lock/ARM our cars. I've looked around and the DIYs out there are vague and doesn't show much details. Since I had an extra siren, I decided to go ahead and replace the horn as well as document the work to share with others. I just recently had someone VAG-COM'd my car so it has LOCK(ARM)~UNLOCK(DISARM) confirmation chirps. This mod is waaay cheaper than sourcing the Euro spec siren. If you have any questions, feel free to pm me. Enjoy....
* * * VAG COM coding: BYTE 5 in Central Electronics Long Coding Helper --- Enable horn honking on unlock confirmation, check bit 4 * * *
Labor time: 30-45min
Tools/parts:
*** UPDATED *** no longer using the DEI siren
• Crimestopper CS-190 ~ 20 watt 125dB single-tone siren (heat & water resistant)
• Wire stripper
• Soldering pen w/ solder
• Electrical tape (3M brand)
• 1/4" wire loom (Harbor Freight)
• T-20 torx socket/screw bit
• 13mm box wrench or adjustable wrench
• 10mm socket
• 10mm bolt
• work light
1. Jack up the car and remove front passenger wheel.
2. Remove the (8) T-20 screws that hold the plastic fender liner. It's much easier to remove the entire liner for clearance.
3. Once liner is removed, look at the left side of the fender well and you will see the factory horn siren. Using the 13mm box wrench (or adjustable wrench), remove the bolt that holds the horn to the bracket. Then, unplug the black connector. If you look close, you can see "2" & "1" on one side of the connector. "2" is black/yellow (+) and "1" is brown (-)
4. On the DEI siren, bend the right mounting bracket to a 90 degree. You will need to open up the mounting hole to accommodate the 10mm bolt. I used the hole in front of the windshield reservoir cap/spout. Once the new siren is mounted, measure the wire so it can reach the black connector. After the wire length is determined and cut, cover the wires with the wire loom.
5. Route the wire loomed cover wires towards the connector. At the connector, peel off the tape (at the end of wire loom) and strip off a 1/4" section of both factory wires...at least 2" away from the connector. Solder the new wires onto those wires accordingly: RED --> black/yellow ...... BLACK ---> brown
Cover the connections with electrical tape. It is recommended to tape over the unused connector as well. Zip tie to secure in place.
6. Using your remote, test the new siren pressing the LOCK button. The panic button works as well.
**** Remember, DISARM/UNLOCK will not make a sound chirip until you program so with VAG-COM ****
7. Re-install the fender liner, mount wheels and wa-laaa.... No more lame horn beep!!!
....used to own a MK6 GTI
Old 06-17-2012, 09:40 PM   #2
cwGTIautobahn
cwGTIautobahn's Avatar
Drives: see sig...
Very cool...nice job.
Thanks!
~ 2012 VW GTI /// autobahn 4d dsg (white)
~ 2008 Porsche Targa 4S (white)
~ 2006 Mercedes Benz E55 (white)
~ 1972 Alfa Romeo Spider (red)
~ 1968 Dodge Dart GTS (red)
cwGTIautobahn is offline   Reply With Quote
Old 06-17-2012, 09:46 PM   #3
nvturbo
nvturbo's Avatar
Thanks. It was easier than I first anticipated. If I can get a hold of a someone local with vagcom, I'm going to enable the unlock chirp option.
Old 06-17-2012, 10:14 PM   #4
cwGTIautobahn
Drives: see sig...
I did have mine recoded and it drive me nuts with the stock horn. I'm in and out of my car 20/30 or more times a day. Can't wait to do this.
Is this the horn you used?
http://www.ebay.com/itm/514LM-Soft-C...#ht_1307wt_689
Old 06-18-2012, 06:11 AM   #5
nvturbo
nvturbo's Avatar
Yes, that's the one. I mistyped the part # in the original thread. If I'm not mistaken, the 514N is smaller than the 514LM but either one will work fine.
Trust me, I always hated the "horn beep" sound when I locked the doors.
Old 06-27-2012, 09:55 AM   #6
bubuski
El Moderador
bubuski's Avatar
Drives: MK6 GTI 5-door TR
Thread added to DIY sticky. Thanks for documenting your steps.
Old 06-27-2012, 11:07 AM   #7
phd-12v
phd-12v's Avatar
Drives: 2010 MK6 Gti
http://www.youtube.com/watch?v=TEc7AGf4ZHY
using the Alpine soft chirp siren
Jason---TECH SUPPORT GURU
2010 Gti w/DSG
2012 Jetta Se 2.5
phd-12v is offline   Reply With Quote
Old 06-27-2012, 11:48 AM   #8
nvturbo
nvturbo's Avatar
Thanks, bubuski. I just hope it will be helpful to those that have been wanting to do this mod.
Jason, I like the Alpine siren but since I had the extra DEI one, I decided to use that instead. The one I used was a soft chirp model so it's not that annoying.
Old 06-28-2012, 03:10 PM   #9
mikeleemk6
mikeleemk6's Avatar
Drives: Shadow Blue GTI MK6
Link to the alpine horn?
Old 06-29-2012, 06:42 AM   #10
nvturbo
nvturbo's Avatar
Jason's (phd-12v) link is given above. As for the Alpine siren, good luck trying to source one....especially one that is new.
Old 07-09-2012, 07:03 AM   #11
nvturbo
nvturbo's Avatar
UPDATE:
Since I'm going to install a catch can soon, I decided to relocate the siren to the right side of the windshield washer fluid tank (above the passenger foglight cover). The wire length remains the same but the location is more low key. All you have to do is mount the siren using the hole of the fender bracket. If you remove the fender liner, you will see what I'm referring to.
Old 07-09-2012, 10:19 AM   #12
Eugene23
Drives: w
Eugene23 is offline   Reply With Quote
Old 07-09-2012, 12:00 PM   #13
nvturbo
nvturbo's Avatar
what...an Alpine siren? Those are nearly impossible to get, especially new. Just grab a DEI one and call it a day.
Old 07-09-2012, 04:14 PM   #14
phd-12v
phd-12v's Avatar
i had a brand new case of them...........but i sent a bunch of them out to forum members. Sorry guys.
2010 Gti w/DSG
2012 Jetta Se 2.5
