#1 |
![]() Drives: Mkv Join Date: Dec 2011
Post your sub setups!
Subs or speakers..Specs too!
Kenwood KAC-9105D Mono class D, 1800 watt peak, 900RMSx2 @ 2ohms. The lights go perfect with the interior. 2 Kicker CompVR's, 400RMS. Cheap Fierce audio sealed box. (got it for $20). Stock speakers. ![]() |
#2 |
![]() Drives: 12 GTI, 97 Carrera 4S, 96 Audi A4 Join Date: Dec 2011
Factory RNS-315
Audison BitOne Zuki 4ch Eleets Zuki 5ch Hybrid Hertz MLK2 TW front/rear RE Audio SEX-104
2012 GTI Autobahn RNS-315, Audison BitOne, Arc Audio 4200SE front, Arc Audio 4200SE rear, Arc Audio 2150SE Sub, Hertz MLK2 TW front/rear, RE Audio SEX-104, Bilstein PSS-10, APR F/R Swaybars, APR TBE, APR Intake, APR Stage II, Concept C-8, Michelin Pilot Sports |
#3 |
![]() Drives: 2010 csg 6mt gti Join Date: Jul 2011
12" alpine type r alpine mrp500 amp polk audio ported box. Stock speakers and headunit
#4 |
![]() Drives: 2011 mk6 k04 gti m/t candy white 2D Join Date: Jun 2011
Lanzar VCTBS10 800 Watts Max 10-Inch Super Slim Active Subwoofer in hach
specs 10'' Slim woofer - Phase shift switch: 0 or 180° - Thermal, short and overload protection circuits - Slim woofer: 250Watt RCA low level input - Adjustable input sensitivity: 0.2V-3V - Fuse: 2x20A - Dimension: 15'' X11.8'' X 3'' High level input - 0 to +12dB variable Bass Boost (@45Hz) - Max power: 800 watt - Weight: 15.5 LBS. Green & red LED power status indicator - Low pass filter (50-150 Hz) - RMS Power: Remote level control - Soft delay remote turn-on - Amplifier: 100Watt
332whp 312wtq on 91oct FBO K04 UNITRONIC STAGE 2+ MY VIDS @ http://www.youtube.com/user/012zzge MY Build Thread http://golfmk6.com/forums/showthread...910#post857910 Last edited by trd420; 07-16-2012 at 01:09 PM. |
#5 |
![]() Drives: 2011 GTI Join Date: May 2011
Stock Dynaudio system
JL 10w6v2 sub in a stealthbox JL JX500/1D amp JL Audio XB-MFBU-ANL Master Fuse Block Scosche Loc80 2-Channel Adjustable Lineout Converter Rockford Fosgate RFK4I - 4 Gauge Power and Signal Installation Kit ![]() ![]() ![]() ![]() ![]() ![]() |
#6 |
Love that box..wish they made them for 12's for a decent price.
#7 |
![]() Drives: 2010 CW MK6 Manual Join Date: Apr 2011
Stock headunit feed into Memphis signal processor w/bass adjustment
2 JL 10W6V2 subs 4 JL C5 separates MCC204 - McIntosh 4/3/2 Ch 200 Watt MCC302 - McIntosh 2 Ch 600 Watt Stinger 2nd battery ![]()
#8 | |
![]() Drives: 2011 CW 4DR DSG Bahn pck Join Date: Apr 2012
I love it! so clean and still get the usable trunk space. How much Does a setup like that cost you?? |
#9 |
#10 |
Formula 2 Champion
![]() Drives: OO------OO Join Date: Jan 2012
lol i totally forgot you were a girl... i was like your boyfriend??
woahhhh.. didn't see that coming ![]() ![]() |
#11 |
#12 |
![]() Drives: 2010 2d black dsg GTI Join Date: Apr 2012
Pioneer premier head unit
JL audio front 6.5's, front & rear tweeters Alpine rear 6.5's JL audio 10w7 in a sealed box Hifonics 600w 2 channel amp (gettin more around 550w) no amp for the components yet, but everything still sounds 10x better than stock |
#13 |
![]() Drives: 2011 GTI 4-door DSG, Shadow Blue Join Date: Jul 2011
Base, RCD-310
SOT-976 harness AudioControl LC2i, under the passenger seat Rockford Fosgate T400-2, bridged, at 800RMSx1 @ 2-ohms, under the driver's seat Eclipse SW9122 Titanium DVC 12" sub, RMS: 750 watts, Peak: 1500 watts, in a Sonic Electronix 1.158 cubic ft. box Scosche EFX 4-gauge Amplifier Wiring Kit ![]()
2011 SB GTI DSG 4-door Neuspeed P-flo/AEM DryFlow - 40 ceramic tint - Interior LED's - LC2i/Rockford T400-2/Eclipse SW9122 Titanium 12" sub - Philips X-treme lows/PIAA city/Höen Endurance fogs/PIAA plate bulbs |
#14 |
![]() Drives: 2010 mk6 Join Date: Jul 2010
RCD 510
Alpine Type R 6.5 components front and rear Alpine Type R 10in Alpine PDXM6 Audio control LC6i ![]() ![]() ![]() Need to put the components on an amp one of these days and get a RNS315 |
#15 |
Wow, great job on that box, very nice.
#16 |
![]() Drives: 2012 Black DSG 4-Door Autobahn GTI Join Date: Aug 2011
Jensen power 900 watt amp
12" Kicker L3 - 400w RMS/800w Peak. Hits veryyy clean/accurate and bumps hard in the little open cabin If you open up the trunk port behind the backseat armrest, it makes a pretty solid difference in the amount of bass getting to you!
APR K04 Tune | AWE K04 Kit | AWE TOP | APR Carbonio Intake | Borla Cat-Back | Billy Boat Downpipe | Forge Twinter | 3000k Super Yellow Fogs | Plasti-dipped Emblems | Rasta Grille | VWR Springs | VMR Sunken Treasure V718s (18 x 8.5, ET 45 Front/ET 37 Rear) | CIM Boost Gauge | BSH TB Pipe | Coolingmist W/M Kit |
#17 |
![]() Drives: 2011 GTI DSG Autobahn Join Date: Jul 2011
My setup is pretty simple, but quite effective. Here's my thread on it: UBER-STEALTH Under Floor Sub Install
It isn't going to blow anybody's mind, but really mates up to the Dynaudio system perfect and has zero compromise on space and hatch utility. The whole thing ran between $600 and $700 (no labor, I did it all myself). If I did it again, I wouldn't change a thing. Sub enclosure: Uber-Stealth Audio Under Floor Box Sub: MB Quart RLP254 10" Sub Amp: JL Audio XD300/1 (300W @ 2Ω) using remote level control LOC/Signal Correction: Audio Control LC2i ![]() ![]() ![]()
2011 CSG GTI Autobahn DSG 4-Door — APR Stage 2 / APR Carbonio / 42DD Cat/Res DP / S3 IC / DG Springs / Brake Upgrades / Enkei Raijins / Uber-Stealth Sub 2009 Deep Black CC VR6 4-Motion — Stock List of Popular MKVI VAG-COM Tweaks |
#18 | |
![]() Drives: 2010 GTI Join Date: Aug 2010
I have a Micro-CAN cable for VAG-COM tweaks in DC. |
#19 |
![]() Drives: 2010 CW GTI 6sp Join Date: Sep 2010
just picked up a JL audio 10" w6, and an Alpine PDX-M6 amplifier.
#20 |
![]() Drives: 2012 VW Golf 2.5l Join Date: Sep 2011
See sig
2011 VW Golf 2.5 17" VW Classix Headunit: Pioneer DEH-80PRS Subs: Atomic AP8's Sub Amp: Soundstream RUB1.2500d |
| Thread Tools | Search this Thread |
| Display Modes | |
