Go Back   VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - Golfmk6.com > Off-Topic Discussions > General Car News and Discussions
Old 08-02-2012, 03:32 PM   #1
C4L
Drives: '10 GTI / '13 CC / '07 ZZR600
Gen-3 EA888 Motor Details
http://blog.caranddriver.com/audi-gi...rbo-diesel-v6/
C4L is offline   Reply With Quote
Old 08-02-2012, 05:13 PM   #2
MKVIFrank
Drives: MKVI 2013 GTI
Oh God that diesel V6 <3333
MKVIFrank is offline   Reply With Quote
Old 08-03-2012, 01:46 AM   #3
Halvie
Drives: 2010 Penalty Box
so does this turd pile have both an integrated exhaust manifold and an integrated fmic in the intake manifold?
Old 08-12-2012, 12:43 AM   #4
excelevant
excelevant's Avatar
Drives: '14 5.0 Track Pack
"Like some Toyota engines, this Audi powerplant family uses both direct and port injection. Direct injection is used to stabilize the idle and in full-load situations, while the port injectors are put to work under partial loads, where Audi engineers say port injection is better at mixing the fuel and air, with less soot produced and reduced CO2 emissions compared to direct injection. Unlike the Toyota setup, this engine operates either as a port-injected engine or a direct-injected one, and never uses both injectors simultaneously. The third-generation EA888 is said to be about 11 pounds lighter than the second gen, despite the wealth of new features."
excelevant is offline   Reply With Quote
Old 08-12-2012, 01:14 AM   #5
PRND[S]
PRND[S]'s Avatar
The best news is that it should drastically reduce carbon fouling on the intake valves.
Old 08-12-2012, 01:32 AM   #6
excelevant
excelevant's Avatar
Systematically eliminating all consequences of previous design.. are we going to be saying that we have EA888v.2/3 hybrids after this technology makes its way back to us, temporarily dedicated, MK6ers?
Old 08-12-2012, 08:34 AM   #7
Rolling_GTI
Rolling_GTI's Avatar
Drives: '12 GTI
^^ Time will tell. I'm thinking the same thing, but we never know till it's released.
2012 Carbon Steel Grey GTI 6MT w/ Sunroof & Nav
APR K04 | ESC Disabled | Carbonio | COBB TBE | RR Stage 3 clutch | Scarlet Red VMR 701's 18" | Black Unibrace UB & XB | VF Engine/Tranny mounts | DG Skid Plate | S3 Short Shifter | EBC Red Pads, Slotted Rotors | Filled Hood Notch | LED Tails | 35% Tint | Too many small mods to list
I've driven her 253,000 hard miles and still loving it! 27MPG Lifetime average
Rolling_GTI is offline   Reply With Quote
Old 08-12-2012, 10:16 AM   #8
Candy11
Candy11's Avatar
Drives: 2k11 DSG GTI Candy white
"The foundation of this new version, which is pictured above and marks the third generation of the EA888, is a 72-pound iron block. Audi engineers boast that the wall thickness is as little as 3 mm (0.1 inch), and they point out that a competitorís minimum iron-block wall thickness is nearly double that figure."
Who else still uses iron blocks?!
2k11 CW GTI DSG, 30% tint, AWE DP, APR Stg 2, APR Carbonio Stg 1, SPM intercooler, De-soundakatored.
Candy11 is offline   Reply With Quote
Old 08-13-2012, 04:12 PM   #9
C4L
Not many but VAG says that the iron block is stronger than aluminum, better at dissipating heat, and because it is stronger they can use less of it to decrease the weight and cost too.
Seems to work fine to me...
Old 08-13-2012, 04:17 PM   #10
maxtdi
GolfMK6 Elite
maxtdi's Avatar
Isn't it some weird iron too... gray iron or something like that...
Old 08-13-2012, 10:10 PM   #11
Rockchops
Rockchops's Avatar
Drives: a real hard game.
The iron block thing struck me as odd as well, even though they've been able to shave the walls and make it lighter that way.
Current list:
2004 rx8 (Shini's)
2007 Sky Redline
2004 Exploder
Rockchops is offline   Reply With Quote
Old 08-13-2012, 10:28 PM   #12
Candy11
Candy11's Avatar
It's some kinda alloy I forgot what all is in it. It all about cost. Aluminum is 1/3 the weight of iron roughly. You just need more aluminum to match the strength. It's always lighter regardless.
Old 08-14-2012, 04:24 PM   #13
RacingManiac
RacingManiac's Avatar
If you can cast iron in more intricate geometry to take weight out of it, you can make lighter cast iron parts than aluminum. But thats not necessarily cheaper.
Same reason why car companies are getting more high strength steel in chassis parts, they can make higher strength part with less material with the better strength properties of steel to overcome the density disadvantage.
