It all depends on what your wanting to do. If your worried about the tensioner replace the tensioner and the cover
Your timing chain tension isn't changed depending on what tune you have nor is it monitored through value blocks.
If you can't tell the difference between a timing chain tensioner and a camshaft adjuster you should not be giving advise/info on either.
Which VR6 are you referring to?So what does MB 213 in the VR6 (chain driven) measure smarty pants?
Why does the cover need to be replaced? Can you not just clean the sealant off the old one and reapply?
Also, is PN 06H109210Q the cover you are talking about?
I assume he's referring to the fact that it is a bear to get off, and is somewhat thin, so replacing it ensures you didn't bend any part of it enough to create a leakage issue.
As for 'official' procedure, you can clean it off, bolt it back on, tighten bolts to 8Nm, then check around the perimeter of the cover between it and the seating surface with a feeler gauge. Any gap of more than .2mm and the cover should be replaced.
The gap is exactly it, there is a small finger looking thing on the inside of the cover that will grind into spinning shit when assembled if it's not exactly perfect. We don't risk it ever, we replace it every time and warranty has never denied the claim to us because of it.
How long/ difficult of a job is that? Can we do it in a few hours, or is it a very laborious job?
I'm mechanically competent, however I would try to avoid a job that would take the better part of a whole day.
I'm not sure what book time is on it, but for a home mechanic with hand tools and jackstands, it would probably take several hours. And add time if you're going to do the chains and guides, as you will now have to take off the top cover as well.... For just getting down to the tensioner:
Jack up car
Remove RF wheel
Remove RF liner
Drain engine oil
Remove charge air pipe
Remove accessory drive belt
Remove crank damper bolt and damper
Support engine
Remove engine mount bolts
Remove engine mount bracket (need to lower engine a bit, not enough room between engine and frame rail for 3/8 drive with 3/8 drive triple square)
Remove dipstick tube
Remove cover.
Thank you for this info and your feedback!
Questions: If there weren't a failure and I wished to do this as a preventative, would/should the balance and cam sprockets or any others sprockets be changed as well?
I will do the chain, tensioner, guides and cover regardless, but just wanted to gain your opinion on this.
Aside from the harmonic balancer puller and cover, are there any other items/tools beyond the ECS kit that should be gathered before taking this on?
Another poster mentions a shop manual- I have a Bentley (going to dig into it tonight now!), but is a true tech manual what would be required?
The info on the intake cam being affected by tune came from Unitronic. Take it for what it is. I too didn't think this was true. Until my conversation earlier in the week.
Also- on a DIY difficulty scale how hard would this be? One poster mentions removing the engine and using a cradle, but another thread has a shot of the cast aluminum cover removed with the engine still in the car?
Question, how tough is it to pull the engine? I guess I should clarify that a bit, is there anything that is super involved that has to be disconnected to pull the engine? The worst thing I can think of, offhand is the AC which I would have to pay to get evacuated beforehand. For someone who is mechanically inclined and has all the tools needed, how long should it take?
There is no reason to pull the engine for this, that's ridiculous, it's a same day job that takes a few hours. And as I said before, replace the lower timing cover whenever it's removed.
