Closed Thread
Old 08-14-2012, 02:35 PM   #29
C4L
Drives: '10 GTI / '13 CC / '07 ZZR600
Originally Posted by Chris@RevoTechnik View Post
There is technically no difference between an FSI and TSI engine as they are simply marketing labels that can be found on both engines.
ACTUALLY.
The TSI moved the location of the direct injectors to reduce the possibility of carbon build-up AND the TSI motor switched from a timing belt found on the FSI to a timing chain.
Those are the two major differences....
C4L is offline
Old 08-14-2012, 02:37 PM   #30
Chris@Revo USA
Drives: cars
Originally Posted by C4L View Post
ACTUALLY.
... you should read the thread
Chris@Revo USA is offline
Old 08-14-2012, 02:37 PM   #31
C4L
Current nomenclature is as I listed with TSI and FSI having no bearing on what physical engine lays under it. One is used by VW one is used by Audi and that is the only difference.
ACTUALLY...
The Audi (sans A3) uses the older FSI motor that has the old direct injection setup and still uses a timing belt.
The VW uses the newer TSI motor tha has the new direct injection setup and uses a timing chain now.
C4L is offline
Old 08-14-2012, 02:37 PM   #32
Chris@Revo USA
Drives: cars
ACTUALLY...
.... see above
Old 08-14-2012, 02:41 PM   #33
C4L
Maybe I am just confused now. Not on the differences between FSI (EA113) and TSI (EA888) but confused on what YOU are talking about.
It is NOT just merely a difference in nomenclature or marketing.
The Audi FSI (EA113) IS in fact different than the VW TSI (EA888)...
C4L is offline
Old 08-14-2012, 02:48 PM   #34
Chris@Revo USA
Drives: cars
FSI has nothing to do with EA113 and TSI has nothing to do with EA888.
Audi has EA888 engines labeled as (T)FSI
VW has EA113 engines labeled as TSI..
This is why FSI and TSI do not actually identify a physical engine.
The 100% exact same engine VW labels a TSI would be a TFSI in an Audi, regardless of their actual generation of engine.
It is like the AWD systems.
An A3 is haldex based and is labeled quattro. A golf R is also haldex based and is labeled 4 motion. It is just marketing names it does not designate any physical difference in the system.
VW has had torsen based AWD systems that were called 4 motion, Audi has AWD systems that are torsen based which are quattro.
Old 08-14-2012, 02:50 PM   #35
C4L
GUYS...
As for the TFSI and FSI confusion.
Audi uses the FSI to stand for Fuel Stratified Injection. It is used for ANY Audi motor that has direct injection, which is all of them. Audi THEN applies a preceding 'T' to the motors that utilize forced induction in addition to the direct (fuel stratified) injection.
Got it.
The MKV FSI motors were simply labeled 'FSI Turbo' on the engine cover as shown below. To denote both direct (fuel stratified) injection and a Turbo.
The older Audis that also used the EA113 motor were marked the same 'FSI Turbo'.
THEN, the newer Audis maintained the EA113 setup but added Audi Variable Valve Lift (Valvetronic) to them and simply dropped the 'FSI Turbo' nomenclature for 'TFSI'.
VW, moving from the EA113 (FSI Turbo) went to the EA888 which carried with it a TSI nomenclature.
FSI - denotes Audi direct injection
'T' - denotes Audi forced induction (Turbo or supercharged)
TSI - denotes VW direct injecton/forced induction
TFSI (Current Audi nomenclature for EA113) = FSI Turbo (Old VW/Audi nomenclature for EA113)
FSI (Current VW/Audi A3 EA888 nomenclature)
C4L is offline
Old 08-14-2012, 02:54 PM   #36
C4L
Thats not true. If so, provide an example of a VW and Audi using the same engine (either EA113 or EA888) that have different nomenclature.
You won't find one...
The ONLY EA888 equipped Audi is the A3 2.0T and that is labeled TSI.
There are no longer any EA113 equipped VW's but when there were (Pre-2008.5) they were labeled FSI Turbo (the engine cover of the MKV GTI).
The Golf R IS an exception to this as it is an EA113 car with TSI nomenclature
C4L is offline
Old 08-14-2012, 02:59 PM   #37
NOLA-Ron
NOLA-Ron's Avatar
Drives: 2012 CSG MT 5 Door
.... see above
Someone was sleeping in class before the pop quiz
You just brought all of it together for me. Thanks for the clarification and examples. Thanks for confirming your original point too. Now I'll correct my language in the future when talking about these topics
|APR|Carbonio|Conv&Sun|.:R Tails|
|OEM+|Rdash|Interlagos Wheels|DG Springs|
My Build Thread
NOLA-Ron is offline
Old 08-14-2012, 02:59 PM   #38
Chris@Revo USA
Drives: cars
really won't find one? one has not yet been posted in this thread by me and quoted on this page?
EA113 engine labeled as TSI still in production today for VW in the Golf R.
And an Audi EA888 engine not labeled TSI
Also the S3 and TT-S are the only Audis vehicles using EA113 based engines, the rest of 2.0 line is using EA888 based variants. (blanking on what they call the valve lift motors)
Old 08-14-2012, 03:09 PM   #39
C4L
For a full summary;
Audi
A3 - 2.0 TSI - EA888
A4, A5, A6, TT, TT-S - 2.0 TFSI - EA113 (w/ Valvetronic)
VW
GTI, GLI, Eos, Tiguan, CC, Beetle Turbo - 2.0 TSI - EA888
Golf R - 2.0 TSI - EA113
C4L is offline
Old 08-14-2012, 03:12 PM   #40
Chris@Revo USA
Drives: cars
I'm not going to quote you so that when you fix it I can't be blamed for allowing incorrect information to be left on this forum.
But there are serious mistakes in what you just listed and you should fix it.
Old 08-14-2012, 03:13 PM   #41
C4L
The Golf R IS the only exception. I did say that.
And what Audi is pictured there that you think has the EA888 motor?
The ONLY Audi that uses the EA888 is the A3 and it IS labeled TSI.
C4L is offline
Old 08-14-2012, 03:14 PM   #42
C4L
Then please tell me what you think those mistakes are...
C4L is offline
Closed Thread
