Old 09-08-2012, 06:14 PM   #15
nadams5755
Drives: 2012 cw gti
Send a message via AIM to nadams5755
in case you wonder what the horns look like from the driver's seat, you can hardly see them but they sound amazing.
my stereo build thread
nadams5755 is offline   Reply With Quote
Old 09-09-2012, 09:19 PM   #16
nadams5755
Drives: 2012 cw gti
got everything pulled, t-nuts installed, painted, and carpeted. you folks know how carpeting goes but not how much i suck at it.
need to tweak the cap power cable and to sand out the cable openings in the PDU. they don't appear to be designed for heat shrink.
false floor works, need to trim around the hatch lip for the hatch sill. then carpet. won't be able to revisit this until the weekend. (damn school )
Old 09-09-2012, 09:23 PM   #17
plac
Guest
Posts: n/a
sick
Old 09-09-2012, 10:01 PM   #18
vdubbers
vdubbers's Avatar
Drives: '12 GTI 6MT Autobahn, Black
That is a properly awesome setup. Great work and great write up! I bet it sounds nice!
vdubbers is offline   Reply With Quote
Old 09-09-2012, 10:32 PM   #19
veedoubleme
veedoubleme's Avatar
Drives: 2014 MB C300
Holy shit dude! I am blown away.
Old 09-10-2012, 05:38 AM   #20
nadams5755
Drives: 2012 cw gti
Originally Posted by plac View Post
sick
thanks!
Old 04-15-2013, 09:06 PM   #21
nadams5755
Drives: 2012 cw gti
spent a couple hours today soldering led rope lights and mounting them in a bit of a recessed fashion under the false floor. i need to finish routing the cables and integration with the hatch switch. the hard part is done though: solder techflex, heat shrink, mounting.
i'll probably pull the whole false floor back out and paint the underside.
i've got a set of rear door puddle lights and rear footwell lights on the way, along with some extra door panel clips
Old 04-15-2013, 10:23 PM   #22
andy_uranium
andy_uranium's Avatar
Drives: 2011 mk6 GTI CW, 2004 Acura TSX
Cool! Looks good. Looking forward to seeing final pics.
my moderate build thread - http://golfmk6.com/forums/showthread.php?t=16739&page=2
2011 CW GTI - DSG, Leather, LED R tails, OEM front lip, color matched side markers, red footwell leds, klii plaid vinyl accents, DG springs, Unibrace XB, UB and RB - OZ supertourismo LMs - Hankook V12 evo
andy_uranium is offline   Reply With Quote
Old 04-20-2013, 12:55 AM   #23
hilld
hilld's Avatar
Drives: sold - 2012 Golf TDI
How are you liking those Soundstream amps?
hilld is offline   Reply With Quote
Old 04-24-2013, 10:19 PM   #24
nadams5755
Drives: 2012 cw gti
they're powerful. i love the minimal looks. i like the wiring terminals.
they're huge. i dislike the non-defeatable crossovers (but you can tune them out of the way).
i haven't been able to make them overheat yet, but i'm not pushing them terribly hard. my 4ch amp gets warmer than my sub amp, but the midbasses are 2-ohm and cover a wide frequency range.
Old 04-27-2013, 12:18 AM   #25
nadams5755
Drives: 2012 cw gti
i always felt like there was more headroom in my stereo than the rcd-310 was letting me hear. i asked other vw sound-nerds (like quality_sound) for opinions of rcd-510 sound quality, i knew i needed to look at the other radios available. i wanted to keep an oem radio for integration.
i picked up a used rns-315-b and installed it tonight. gps antenna is mounted above the center vents, like all the other cool kids do.
using the VAGCOM cable, i set the sound system to volkswagen sound system so it would lower output to line-level.
lower mid-range frequencies used to be disappointing with the rcd-310; baritones would start distorting at low volumes. so far, without any additional tuning, i have a bunch more headroom and the sound is cleaner.
it does need to be retuned now though.
Old 04-27-2013, 01:10 AM   #26
jansonchan226
Holy Fuck man.. you dont joke around..
jansonchan226 is offline   Reply With Quote
Old 04-27-2013, 09:09 PM   #27
nadams5755
Drives: 2012 cw gti
i installed the front door puddle lights last summer. installed the rear door puddle lights and back seat footwell lights today.
the oem footwell lights (from the front) fit in the back better, so i swapped the bold-sport ones to the front.
Old 05-10-2015, 05:20 PM   #28
nadams5755
Drives: 2012 cw gti
i wanted to install the bit ten's remote-control in the dash but wanted to close/hide it as well. it's angled back to be easier to use. however, i don't plan to use it much. (the bit ten will occasionally set its volume to 0, requiring a remote-control or laptop to return the volume back to normal.)
this meant adding a USB charging port as well. i bought a USB button socket, cigarette lighter socket, anker USB 4-port charger (2.1a/port, both android and iphone auto modes). i got an extra dash console from the forums.
i soldered and heat-shrunk things together, made it nice and safe, and installed everything. i attached everything to the carpet under the center console w/ velcro. the audison DRC is attached w/ double-sided tape.
i added the garage door opener earlier this year. the actual opener is under the right-side of the center console, so i can quickly remove it to swap batteries.
