Old 08-30-2012, 06:01 PM   #1
CTS Turbo
CTS Turbo's Avatar
Drives: 2012 Golf R, 2011 GTI, 996 Turbo
*** CTS Turbo Direct Fit Golf R FMIC Kits ***
The CTS MK6 Golf R 2.0T Direct Fit FMIC Kit is designed as a drop in replacement for the OEM front mounted intercooler (FMIC). That means you can install this kit without any trimming or modification of the bumper. The OEM FMIC is adequate for stock boost levels, however once boost levels are increased by way of ECU upgrades/chipping the OEM FMIC struggles to keep the charged air temperatures in check. Higher charged air temperatures can result in boost cut and timing pull, both reducing the amount of power your vehicle produces.
The CTS direct fit FMIC uses a high efficiency bar and plate intercooler core, which aids in reducing pressure drop. Reducing pressure drop means that your turbo will not have to work as hard to make a given level of boost. If your turbo makes 30psi of boost pressure in the turbocharger, and your intercooler has a 10psi pressure drop then the boost measured by your ECU would be (30psi - 10psi) = 20psi. With an efficient FMIC like the CTS direct fit FMIC your turbo does not have to work as hard to reach desired boost levels. This is beneficial in two ways, the turbo life expectancy is increased due to more efficient operation, and boost leaving the turbocharger is cooler and more dense resulting in more power to the ground.
Product Details:
- Efficient bar and plate construction
- Low pressure drop
- Maintains factory mounting points
- No trimming of bumper or crash supports
- Rated for power levels in excess of 600HP
- Core dimensions: 23.00 Length x 2.00" Tall x 16.5" Height
- Cast aluminium high efficiency end tanks
Click to order our 2.0T Direct Fit FMIC Kit $799.99 Shipped
Golf R with CTS Big Turbo Kit
MK5 GTI TSI:
MK5 GTI FSI with CTS Turbo Big Turbo Kit:
CTS Turbo is offline   Reply With Quote
Old 08-30-2012, 06:02 PM   #2
CTS Turbo
CTS Turbo's Avatar
PS: Use promo code "Laborfmic" for $100 off and free shipping until the end of the first week of September.
Old 09-18-2012, 10:49 AM   #3
CTS Turbo
CTS Turbo's Avatar
Shouts out to Shane, Phoenix and crew at our Hong Kong distributor Monster Garage (www.monstergarage.com.hk). Here are a few pics of Monster Garage in action installing our CTS Direct fit FMIC and flashing a new Scirocco with a Unitronic tune... Lucky customer and sweet car!!!!!!!
Old 10-10-2012, 12:19 AM   #4
CTS Turbo
CTS Turbo's Avatar
Here are a few pics of the CTS Turbo TSI Intake kit installed on Adams 2012 GTI:
Old 10-16-2012, 01:38 AM   #5
CTS Turbo
CTS Turbo's Avatar
We have some shiny new CTS MK6 2.0 TSI (Borg Warner) Turbo Upgrade kits in stock & ready to ship.
Have a look at these beauties in the photos below.
Old 10-16-2012, 10:18 PM   #6
Stifun
Drives: 2012 CW Golf R 4DR
Just installed my CTS Turbo FMIC recently for my Golf R so far very very happy with the fitment and the performance my car picked up.
Thanks CTS.
12' R
Mods: APR downpipe, APR HPFP, CTS Turbo Intake ,CTS Turbo FMIC, APR Stage 2+ Tune.
Stifun is offline   Reply With Quote
Old 10-17-2012, 10:32 PM   #7
CTS Turbo
CTS Turbo's Avatar
Thanks CTS.
Thanks for the feedback Alex!
Old 11-01-2012, 09:57 PM   #8
yoffer
Drives: 12' gti w/DSG, 13' Touareg TDI Lux
Bump for a great company and good people!!
12' GTI w/DSG, Revo stg 2, Stabila 25mm Rear Sway, ST Coils, AWE TOP, AWE Boost Vent Gauge, BBS LM Reps, Neuspeed Torque Insert, APR catback, SPM "Track" DP, Nitto NT05's, S3 IC
VW Technician
yoffer is offline   Reply With Quote
