Ed's OEM-style HID replicas with 2013 JSW results
todd_fuller
New member
So, I've read a LOT on the forums lately. Both prior to buying the headlights from Ed and after I got them.
What I read was, 'all you have to do is install and turn off DRLs.' For my car, this did not work at all. I tried a lot of settings within the usual Golf and GTI NAR settings with limited success. I finally sat down and went though the list of possible byte 18 codes exhaustively so others can know how these behave on a 2013 JSW (CECM 5K0 937 084 J - lowline/baseline).
Below is a list of the byte 18 hex code and how it behaved on my JSW, check the 'byte18.pdf' for a description of what car the code belongs to:
02 - rear fog light bulb out error
03 - either parking lights or front side lights bulb out errors depending on DRL settings.
04 - left reverse light on constantly, no bulb out errors (possibly due to different wiring for GTI)
15 - rear fog light bulb out error
1E - back turn signals on w/ headlights but dimmer than when signaling
1F - either parking lights or front side lights bulb out errors depending on DRL settings.
20 - right reverse light on constantly, no bulb out errors
21 - right reverse light on constantly, no bulb out errors
22 - no bulb out errors, only right reverse light works when in reverse. Ed's LEDs on when lights are on, did not test if they operate as DRLs.
3F - either parking lights or front side lights bulb out errors depending on DRL settings.
40 - rear fog light bulb out error
41 - rear fog light bulb out error, left reverse light on
42 - rear fog light bulb out error
43 - rear fog light bulb out error
44 - left reverse light always on, no bulb out errors
45 - no bulb out errors, LEDs as DRLs but cannot configure to be on w/ lights.
I'm trying to decide between 22 and 45, these were the only two that worked the most with no errors. Other codes were more configurable but always had a bulb out or reverse light on.
Autoscan *after* installed Ed's lights but *prior* to messing with VCDS codes.
Code:
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 5K0 937 084 J    HW: 5K0 937 084 J
   Component: BCM PQ35 B    021 1068
   Revision: BG021001
   Coding: 6F380E1F802F3EC4008800C17000004449000086575D05F064802020A040
   Shop #: WSC 00066 000 00000
   VCID: 39731346B0DAEFD026B
   Subsystem 1 - Part No: 5K1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 03081  26  0512
   Coding: 009795
8 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 36
                    Mileage: 1995 km
                    Time Indication: 0
                    Date: 2000.14.25
                    Time: 11:21:43
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.40 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
00979 - Lamp for Low Beam; Right (M31)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 2
                    Reset counter: 36
                    Mileage: 1995 km
                    Time Indication: 0
                    Date: 2000.14.25
                    Time: 11:07:30
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.25 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01038 - Central Locking Thermal Protection
            000 -  -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 44
                    Mileage: 18 km
                    Time Indication: 0
                    Date: 2000.14.10
                    Time: 16:17:56
             Freeze Frame:
                        Term 15 Off
                    Voltage: 12.65 V
                        OFF
                        OFF
                        OFF
                        OFF
                        OFF
01493 - Bulb for Blinkers; Front Left (M5)
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 76
                    Mileage: 1995 km
                    Time Indication: 0
                    Date: 2000.14.25
                    Time: 10:30:14
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.35 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01495 - Bulb for High-Beams; Left (M30)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 76
                    Mileage: 1995 km
                    Time Indication: 0
                    Date: 2000.14.25
                    Time: 10:30:14
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.35 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01800 - Light Switch (E1)
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 61
                    Mileage: 1091 km
                    Time Indication: 0
                    Date: 2000.14.19
                    Time: 20:29:51
             Freeze Frame:
                        Term 15 Off
                    Voltage: 12.75 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
02745 - Bulb for Daytime Running Light; Left
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 36
                    Mileage: 1995 km
                    Time Indication: 0
                    Date: 2000.14.25
                    Time: 10:21:16
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.40 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
02746 - Bulb for Daytime Running Light; Right
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 36
                    Mileage: 1995 km
                    Time Indication: 0
                    Date: 2000.14.25
                    Time: 11:08:50
             Freeze Frame:
                        Term 15 Off
                    Voltage: 12.45 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
Wastegate13
If someone would return my cable I could get around to coding mine.......
toneman
rocket scientist
Mr. Fuller, you are the man of men for this. Thank you.
Golden State Warrior fans forgive you. :)
nickjames
New member
Hey i am a NOOB to the GTI world, jsut purchased my first one...j/w would I be able to put the 2013 head light w/ the led's on my 2011?
