Old 10-06-2012, 12:10 PM   #29
the bruce
the bruce's Avatar
Drives: Mk.V GTI
Thoughts?
Definitely try all possible settings !!
(of course on a 4WD with 24/26 things are different)
PICS
Old 10-06-2012, 01:10 PM   #30
Noob_2.0T
Noob_2.0T's Avatar
Drives: 2012 UGM GTI
I read over this and I wanna get someone's opinion on this. I'm wanting to go with either apr front and rear sway bars or h&r front and rear sway bars. I'm looking for a set up that will improve my handling but not have too much over or under steer just a happy medium. Something for dd but something that would be good for taking around the ring. Thanks
APR - AIRLIFT - CTS - ROTIFORM
My UG Journal
IG: @mk6bheart
Noob_2.0T is offline   Reply With Quote
Old 10-06-2012, 07:30 PM   #31
the bruce
the bruce's Avatar
Drives: Mk.V GTI
Is T‹V approval somthing you need to consider?
PICS
Old 10-06-2012, 07:30 PM   #32
MMartel455
I feel that the 26 front soft and 24 rear stiff combo is very neutral overall. I can get the car to oversteer but you really have to cut the wheel hard...think very tight autocross courses....not something you are not going to do on a track.
MMartel455 is offline   Reply With Quote
Old 10-06-2012, 08:09 PM   #33
GunKata
MILFn00dzHunter.com
GunKata's Avatar
What have you seen from the MkV R32's, if at all? its the same setup, essentially. I am either going to do both at soft to start, or go front on firm, rear on soft, which I think i read somewhere is also fine. Iirc, the stock front bar is like 21.5 or 22mm, and the rear is 20.5 or something, so a huge change for the rear with going to 26mm.
Everybody knows GunKata > *.*
No GunKata, no care.
Chicago Car Network
I can haz 350z racecar?
Old 10-06-2012, 11:09 PM   #34
Noob_2.0T
Noob_2.0T's Avatar
I'm stationed in Germany not a national so I don't have to go by the T‹V
My UG Journal
IG: @mk6bheart
Old 10-07-2012, 06:08 PM   #35
the bruce
the bruce's Avatar
Drives: Mk.V GTI
Agree with Martel.
Both 27mm hollow APR/Hotchkis and H&R 26/24 mm solid are fine.
There will be a difference, but not a huge one.
Hollow bars are lightweight, solid bars most usually are more reliable.
GunKata,
yes, no doubt, if your A3 Quattro shares the same bars with R32 or
R36 (21.7 mm hollow with 3.0 or 3.6 mm wall thickness) or very
similar, which I think it does, the difference will be huge.
PICS
Old 10-09-2012, 03:46 AM   #36
crabb45
Drives: MK6 GTI
I got a PM asking about front sway bars and my answer might be of general interest:
I know many guys recommend a rear sway only, but I strongly believe they are wrong.
I tried it all on my own: stock sways, 24 mm rear and 28 + 24 mm front and rear with
all possible settings. No doubt both bars was best by far.
Possibly most guys never tried both bars and they parrot half-whisdom on the forums.
A common misconception I believe.
A front sway will reduce overall roll much more than the rear sway, improve steering
(in feel and quicker), turn in and make you car feel more stable. On the other hand it
slightly affects traction on bad roads, but not necessarily on good ones. I was wonde-
ring my self that I didn't have any increase in understeer. I even prefer the stiff setting
of the 28 mm front bar.
To make things short: If you already have a 24 mm rear sway I strongly recommend
at least a 24, 25 or 26 mm front sway bar.
We were talking about this already here:
http://www.golfmkv.com/forums/showthread.php?t=120841
(Keep in mind: Mk.V chassis = Mk.VI chassis)
Feel free to ask any questions, fellows !!
hi the bruce,
i've just installed my 28/24 HR sways... they are just great.. but mine is painted yellow.. wonder if they are genuine..
crabb45 is offline   Reply With Quote
Old 10-11-2012, 08:22 AM   #37
the bruce
the bruce's Avatar
Drives: Mk.V GTI
I've never seen yellow H&R bars. Take a picture of the end pieces and we'll possibly
recognize if they're made by H&R.
PICS
Old 10-11-2012, 09:23 AM   #38
rs999
rs999's Avatar
Originally Posted by crabb45 View Post
hi the bruce,
Where did you buy these yellow H&R bars?
Old 10-14-2012, 02:14 PM   #39
FLtrooper
FLtrooper's Avatar
Drives: No Mas VW! Hola Audi!
Great thread Bruce!
I have considered going with the hotchkis F/R.
When swapping out the front bar and dropping the subframe, what do you recommend to retain the alignment? If alignment is effected? I just had my alignment done after my Koni/DG/TT setup and its perfect now. Would hate to have to get it done again so soon.
Thanks.
My OEM+ K04 MK6 GLI
Sticking to two wheels from now on!
FLtrooper is offline   Reply With Quote
Old 10-14-2012, 07:23 PM   #40
the bruce
the bruce's Avatar
Drives: Mk.V GTI
Sadly I don't know the Mk.VI Jetta subframe on my own.
I'd clean everything and mark the position with a fineline Sharpie.
If steering wheel is straight everything is fine.
PICS
Old 10-18-2012, 06:21 PM   #41
troyguitar
FIA Formula 1 Champion
troyguitar's Avatar
So does anyone know how a 24mm solid (rear) bar compares in stiffness to the Hotchkis/APR 27mm hollow (rear) bar?
Old 10-18-2012, 07:08 PM   #42
corrado917
corrado917's Avatar
Drives: GTI CSG
Hollow is lighter,for sure some will find the 27mm. harsher for a daily.I do have one 24mm. rear and it is good as daily..
