Old 10-22-2012, 03:31 PM   #57
MAD_GTI
MAD_GTI's Avatar
Drives: 2012 CSG GTI
My APR sway is squeaking like no other. Can anyone tell me how to re-grease using the zerk fitting?
MAD_GTI is offline   Reply With Quote
Old 10-22-2012, 07:28 PM   #58
the bruce
the bruce's Avatar
Drives: Mk.V GTI
You need a grease gun and use it twice a year.
PICS
Old 10-24-2012, 12:25 PM   #59
troyguitar
FIA Formula 1 Champion
troyguitar's Avatar
From Hotchkis:
We based it off of:
Front: 22mm solid OE
Rear: 18mm solid OE
Old 10-25-2012, 10:10 AM   #60
the bruce
the bruce's Avatar
Drives: Mk.V GTI
Thanks !!
Confusing answer though as there are no solid sways from factory except on Sharan and R36.
PICS
Old 10-26-2012, 07:26 PM   #61
the bruce
the bruce's Avatar
Drives: Mk.V GTI
Is anyone interested in 28 + 26 mm sways made by H&R?
PICS
Old 10-29-2012, 08:20 PM   #62
youngdoc
For the F/R 26/24 set up you promote, I assume you are using H&R bars? Did you try some/any of the other solid bars you profiled in the beginning?
I've been in my 2012 GTI, completely stock, for 4-6 wks now. I drive very "spiritedly" but also use the car as my daily driver. As of rt now, I don't want to change wheels, still like the factory Detroits, but definitely want better cornering. Still 26/24? Also would be game to change springs/go to coilovers, but that would be further down the road....still cool to run 26/24 until then?
Thanks
youngdoc is offline   Reply With Quote
Old 10-30-2012, 08:22 PM   #63
the bruce
the bruce's Avatar
Drives: Mk.V GTI
I'd suggest:
- H&R sways 26 + 24 mm
- DG springs (or stay with stock springs if you like the ride height)
- Bilstein B6/HD dampers
- S3 control arms bushes
- TT strut mounts
- Michelin PSS summer tires
PICS
Old 10-30-2012, 10:51 PM   #64
808bahn
Drives: 2012 DSG Autobahn GTI
Do you find that the H&R 26/24 set up is good for a DD? I currently have H&R 26/22 set at soft front and hard rear with DG springs on stock dampers, and it's perfect for DD, but still would like the car to be more flat during cornering, w/o compromising the DD aspect.
Originally Posted by the bruce View Post
I'd suggest:
- TT strut mounts
808bahn is offline   Reply With Quote
Old 10-30-2012, 11:15 PM   #65
the bruce
the bruce's Avatar
Drives: Mk.V GTI
It suits DD, but did you already try the front bar set to stiff?
I'd try that first just before spending money.
You'll know I'd be easy t swap the rear bar, but changing setup
is easier. Keep in mind the front bar effects body roll much more
than the rear bar. You'll notice the change.
PICS
Old 10-31-2012, 12:49 AM   #66
808bahn
Good point. I will do that first. Thanks.
Old 11-25-2012, 01:50 PM   #67
YellowC4S
Drives: 12 GTI, 97 Carrera 4S, 96 Audi A4
Happy Holidays all,
I have a 2012 GTI Autobahn, 6spd, Carbonio Stage II, APR tune Stage II and Bilstein PSS10 coilovers. I recently purchased the APR F/R sways and wanted to ask how to set these up for the most neutral handling. I don't want understeer or oversteer but a little oversteer would be ok. Also, How much should it cost total for installation? Would installation require an alignment? I have the Bilstein's settings at 7/7 F/R. Any advice on that?
Thank you all in advance,
Kevin
VAG-COM in Metro Detroit available
2012 GTI Autobahn
RNS-315, Audison BitOne, Arc Audio 4200SE front, Arc Audio 4200SE rear, Arc Audio 2150SE Sub, Hertz MLK2 TW front/rear, RE Audio SEX-104, Bilstein PSS-10, APR F/R Swaybars, APR TBE, APR Intake, APR Stage II, Concept C-8, Michelin Pilot SS, Sachs SRE Clutch
YellowC4S is offline   Reply With Quote
Old 11-25-2012, 07:40 PM   #68
the bruce
the bruce's Avatar
Drives: Mk.V GTI
Are you running snow tires in the winter?
If so I'd set both bars to soft in the winter and both to stiff with your PSS as a starting point.
Keep in mind contrary to stock and H&R/Eibach/KW/VWR bars that APR sways are both front
and rear same diameter giving a more rear based nature.
PICS
Old 11-26-2012, 05:23 AM   #69
YellowC4S
Nokian Hakka 7's winter, Michelin Pilot SS summer
2012 GTI Autobahn
Old 11-26-2012, 06:36 AM   #70
YellowC4S
Mr Bruce,
I need to pick your brain. I have been told that you are THE man to talk to about the PSS10 CO. I currently have mine set up 7 front and 7 rear. I intend to install my APR front and rear sways. I would like a setup that will allow me to put the power to the pavement and at the same time make the handling more neutral or slightly biased oversteer. What would you recommended settings for the coilovers and swaybars be?
Thank you in advance,
Kevin
2012 GTI Autobahn
